Update vs Upgrade
popeye
Update vs Upgrade
Post by popeye » Sun Mar 06, 2016 17:21
What is the difference between update and upgrade in sabayon??
I have just switched from Fedora/Korora... update and upgrade serve different functions there..
Re: Update vs Upgrade
Post by sabayonino » Sun Mar 06, 2016 19:35
see equo --help
# equo --help | tail -n6
Post by Stupot » Mon Mar 07, 2016 5:56
The quick response is update means to download the latest list of available packages from the remote repository.
Upgrade takes all of your currently installed packages and installs newer ones that your system knows about.
So you'll always want to update and then upgrade.
popeye
Post by popeye » Sat Mar 12, 2016 9:59
@stupot
Thanks for the info...
