New kernels and WinNT
abs
Post by abs » Fri Mar 20, 2020 21:37
Hi all,
Since january +/- I'm having a persistent problem installing or updating new kernels. The installation script does not search windows partitions, and I don't have windows on grub menu, even mounting it before kernel install.
My system has an ssd disk for win10 + ssd disk for sabayon. Ir worked fine before...
Re: New kernels and WinNT
Post by fiorello » Sun Mar 22, 2020 8:41
Make sure you have mounted the partition where Windows is located, then give this command:
# equo i sys-boot/os-prober
# grub2-mkconfig -o /boot/grub/grub.cfg
Tchao.
# && fotoabc.it &&
