Wine doesn't work [Solved]
Duskmourn
Post by Duskmourn » Fri Feb 21, 2020 20:40
So I have a fresh install of Sabayon here, installed from a daily iso, and wine doesn't seem to work at all. I get this error when I try to run just "wine" in the terminal
/usr/bin/wine: line 2: /usr/lib/wine-staging-5.0/bin/wine: No such file or directory
And then running "winecfg" gives me this error
/usr/lib/wine-staging-5.0/bin/winecfg: line 47: /usr/lib/wine-staging-5.0/bin/wine: No such file or directory
I have wine 0-r7 and wine-staging 5.0-0 packages installed from the sabayon-weekly repo for reference. Anyone else having this issue or is something on my system just broken?
Re: Wine doesn't work
Post by Stupot » Fri Feb 21, 2020 20:44
I do not have that problem, although I have app-emulation/wine-staging-4.16 instead of wine-stanging-5.0-0 installed. Try seeing if wine-staging-4.16 runs for you. If so, maybe the problem is wine-staging-5 ?
Duskmourn
Post by Duskmourn » Fri Feb 21, 2020 20:54
No, that didn't work either.
/usr/bin/wine: line 2: /usr/lib/wine-staging-4.16/bin/wine: No such file or directory
/usr/lib/wine-staging-4.16/bin/winecfg: line 47: /usr/lib/wine-staging-4.16/bin/wine: No such file or directory
Post by Stupot » Mon Feb 24, 2020 15:38
If you attempt to cd to get to e.g. /usr/lib/wine-staging-4.16/bin can you? If not, where do you get stuck? If you don't get stuck, what is in that directory? Do an
ls -la
if you get there.
Duskmourn
Post by Duskmourn » Tue Feb 25, 2020 0:22
The daily iso I installed from turned out to have a broken symlink between /lib32 and /lib64, so multilib was broken, which caused wine, a 32 bit program, to not work in turn. Enlik helped me figure this out and added it to the bug tracker. Marking as solved.
Re: Wine doesn't work [Solved]
Post by Stupot » Tue Feb 25, 2020 19:35
That's exactly what I was wondering was happening. Glad you got things sorted out.
Post by sabayonino » Tue Feb 25, 2020 20:23
New daily was build from stage3 and new profile 17.1 , so /lib is not a symlink points to /lib64 anymore.
Some applications could be rebuild
see https://groups.google.com/forum/#!topic ... 3zfbFJcGls
