Login loop as user after Rigo upgrade
ShadowOne333
Post by ShadowOne333 » Wed Jan 22, 2020 1:04
Good day.
First off, please forgive my intrusion if this is the wrong section to post this issue. Do let me know if it gets moved, please.
Just today I powered on a laptop I had with Sabayon, with the last upgrade being done like a year ago I believe.
I performed the system upgrade all through the Rigo package manager.
Everything went fine (after like 1191 processes). Once it finished it still had 6 preserved builds, but nothing out of the ordinary after that.
So I finished the upgrade, and rebooted the machine.
GDM started just fine, typed in my user and password, but to my surprise, the user's desktop doesn't appear.
Instead, I get brought back to the GDM login screen.
The user keeps doing the same thing over and over to no avail.
I tried doing something different, logging in through GDM with the root user and its password, just to see if I could get to the Desktop, and indeed with root I managed to enter just fine. WiFi and everything else working too.
So it's just the user that cannot seem to access the graphical interface.
Any clues as to what might be happening here?
I do have some experience with Gentoo, but I'm unsure how much config would differ from it compared to Sabayon.
Any help would be greatly appreciated!
Re: Login loop as user after Rigo upgrade
Post by sabayonino » Wed Jan 22, 2020 12:19
Check if you have anough /tmp free space or if your /home partition (if any) is full.
ShadowOne333
Post by ShadowOne333 » Wed Jan 22, 2020 15:15
Just checked, both /tmp and /home have plenty of free space still, so at least that can be ruled out.
I just find it really weird that root can get into Gnome Desktop just fine, but the user cannot.
If I do 'startx' as user in terminal, I also get brought back to the login screen.
ShadowOne333
Post by ShadowOne333 » Thu Jan 23, 2020 17:23
Here's my Xorg.1.log file for reference, maybe this will help shade a light on the issue.
From what I can see and gather, the problem might be related to logind from systemd, though I am still unsure as to how about possibly fixing it.
[   987.921] _XSERVTransSocketUNIXCreateListener: ...SocketCreateListener() failed
[   987.921] _XSERVTransMakeAllCOTSServerListeners: server already running
[   987.921] (--) Log file renamed from "/var/log/Xorg.pid-5012.log" to "/var/log/Xorg.1.log"
[   987.922]
X.Org X Server 1.20.5
X Protocol Version 11, Revision 0
[   987.922] Build Operating System: Linux 4.9.0-sabayon x86_64 Gentoo
[   987.922] Current Operating System: Linux Shadow 4.14.0-sabayon #1 SMP Sat Nov 2 02:26:37 UTC 2019 x86_64
[   987.922] Kernel command line: BOOT_IMAGE=/kernel-genkernel-x86_64-4.14.0-sabayon root=/dev/mapper/sabayon_shadow-root ro rd.lvm.lv=sabayon_shadow/swap dolvm rd.lvm.lv=sabayon_shadow/root splash resume=/dev/mapper/sabayon_shadow-swap quiet
[   987.922] Build Date: 30 October 2019  09:57:56PM
[   987.922]
[   987.922] Current version of pixman: 0.38.4
[   987.922] 	Before reporting problems, check http://wiki.x.org
	to make sure that you have the latest version.
[   987.922] Markers: (--) probed, (**) from config file, (==) default setting,
	(++) from command line, (!!) notice, (II) informational,
	(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
[   987.922] (==) Log file: "/var/log/Xorg.1.log", Time: Wed Jan 22 18:25:05 2020
[   987.923] (==) Using config directory: "/etc/X11/xorg.conf.d"
[   987.923] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[   987.924] (==) No Layout section.  Using the first Screen section.
[   987.924] (==) No screen section available. Using defaults.
[   987.924] (**) |-->Screen "Default Screen Section" (0)
[   987.924] (**) |   |-->Monitor "<default monitor>"
[   987.925] (==) No monitor specified for screen "Default Screen Section".
	Using a default monitor configuration.
[   987.925] (==) Automatically adding devices
[   987.925] (==) Automatically enabling devices
[   987.925] (==) Automatically adding GPU devices
[   987.925] (==) Max clients allowed: 256, resource mask: 0x1fffff
[   987.925] (WW) The directory "/usr/share/fonts/TTF/" does not exist.
[   987.925] 	Entry deleted from font path.
[   987.925] (WW) The directory "/usr/share/fonts/OTF/" does not exist.
[   987.925] (WW) The directory "/usr/share/fonts/Type1/" does not exist.
[   987.925] (WW) `fonts.dir' not found (or not valid) in "/usr/share/fonts/100dpi/".
[   987.925] 	(Run 'mkfontdir' on "/usr/share/fonts/100dpi/").
[   987.925] (WW) `fonts.dir' not found (or not valid) in "/usr/share/fonts/75dpi/".
[   987.925] 	(Run 'mkfontdir' on "/usr/share/fonts/75dpi/").
[   987.925] (==) FontPath set to:
	/usr/share/fonts/misc/
[   987.925] (**) ModulePath set to "/usr/lib64/xorg/modules"
[   987.925] (II) The server relies on udev to provide the list of input devices.
	If no devices become available, reconfigure udev or disable AutoAddDevices.
[   987.925] (II) Loader magic: 0x562bceb3bce0
[   987.925] (II) Module ABI versions:
[   987.925] 	X.Org ANSI C Emulation: 0.4
[   987.925] 	X.Org Video Driver: 24.0
[   987.925] 	X.Org XInput driver : 24.1
[   987.925] 	X.Org Server Extension : 10.0
[   987.930] (++) using VT number 3
[   987.937] (II) systemd-logind: took control of session /org/freedesktop/login1/session/_37
[   987.939] (II) xfree86: Adding drm device (/dev/dri/card0)
[   987.942] (II) systemd-logind: got fd for /dev/dri/card0 226:0 fd 12 paused 0
[   987.951] (--) PCI:*([email protected]:2:0) 8086:0046:1028:0428 rev 2, Mem @ 0xf0000000/4194304, 0xe0000000/268435456, I/O @ 0x00008080/8, BIOS @ 0x????????/131072
[   987.952] (II) LoadModule: "glx"
[   987.952] (II) Loading /usr/lib64/xorg/modules/extensions/libglx.so
[   987.958] (II) Module glx: vendor="X.Org Foundation"
[   987.959] 	compiled for 1.20.5, module version = 1.0.0
[   987.959] 	ABI class: X.Org Server Extension, version 10.0
[   987.959] (==) Matched intel as autoconfigured driver 0
[   987.959] (==) Matched modesetting as autoconfigured driver 1
[   987.959] (==) Matched fbdev as autoconfigured driver 2
[   987.959] (==) Matched vesa as autoconfigured driver 3
[   987.959] (==) Assigned the driver to the xf86ConfigLayout
[   987.959] (II) LoadModule: "intel"
[   987.960] (II) Loading /usr/lib64/xorg/modules/drivers/intel_drv.so
[   987.961] (II) Module intel: vendor="X.Org Foundation"
[   987.961] 	compiled for 1.20.5, module version = 2.99.917
[   987.961] 	Module class: X.Org Video Driver
[   987.961] 	ABI class: X.Org Video Driver, version 24.0
[   987.961] (II) LoadModule: "modesetting"
[   987.961] (II) Loading /usr/lib64/xorg/modules/drivers/modesetting_drv.so
[   987.962] (II) Module modesetting: vendor="X.Org Foundation"
[   987.962] 	compiled for 1.20.5, module version = 1.20.5
[   987.962] 	Module class: X.Org Video Driver
[   987.962] 	ABI class: X.Org Video Driver, version 24.0
[   987.962] (II) LoadModule: "fbdev"
[   987.962] (II) Loading /usr/lib64/xorg/modules/drivers/fbdev_drv.so
[   987.963] (II) Module fbdev: vendor="X.Org Foundation"
[   987.963] 	compiled for 1.20.5, module version = 0.5.0
[   987.963] 	Module class: X.Org Video Driver
[   987.963] 	ABI class: X.Org Video Driver, version 24.0
[   987.963] (II) LoadModule: "vesa"
[   987.963] (II) Loading /usr/lib64/xorg/modules/drivers/vesa_drv.so
[   987.964] (II) Module vesa: vendor="X.Org Foundation"
[   987.964] 	compiled for 1.20.5, module version = 2.4.0
[   987.964] 	Module class: X.Org Video Driver
[   987.964] 	ABI class: X.Org Video Driver, version 24.0
[   987.964] (II) intel: Driver for Intel(R) Integrated Graphics Chipsets:
	i810, i810-dc100, i810e, i815, i830M, 845G, 854, 852GM/855GM, 865G,
	915G, E7221 (i915), 915GM, 945G, 945GM, 945GME, Pineview GM,
	Pineview G, 965G, G35, 965Q, 946GZ, 965GM, 965GME/GLE, G33, Q35, Q33,
	GM45, 4 Series, G45/G43, Q45/Q43, G41, B43
[   987.966] (II) intel: Driver for Intel(R) HD Graphics
[   987.966] (II) intel: Driver for Intel(R) Iris(TM) Graphics
[   987.966] (II) intel: Driver for Intel(R) Iris(TM) Pro Graphics
[   987.966] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[   987.966] (II) FBDEV: driver for framebuffer: fbdev
[   987.966] (II) VESA: driver for VESA chipsets: vesa
[   987.966] (II) intel(0): Using Kernel Mode Setting driver: i915, version 1.6.0 20170818
[   987.979] (WW) Falling back to old probe method for modesetting
[   987.979] (WW) Falling back to old probe method for fbdev
[   987.979] (II) Loading sub module "fbdevhw"
[   987.979] (II) LoadModule: "fbdevhw"
[   987.980] (II) Loading /usr/lib64/xorg/modules/libfbdevhw.so
[   987.980] (II) Module fbdevhw: vendor="X.Org Foundation"
[   987.980] 	compiled for 1.20.5, module version = 0.0.2
[   987.980] 	ABI class: X.Org Video Driver, version 24.0
[   987.981] (--) intel(0): Integrated Graphics Chipset: Intel(R) HD Graphics
[   987.981] (--) intel(0): CPU: x86-64, sse2, sse3, ssse3, sse4.1, sse4.2; using a maximum of 2 threads
[   987.981] (II) intel(0): Creating default Display subsection in Screen section
	"Default Screen Section" for depth/fbbpp 24/32
[   987.981] (==) intel(0): Depth 24, (--) framebuffer bpp 32
[   987.981] (==) intel(0): RGB weight 888
[   987.981] (==) intel(0): Default visual is TrueColor
[   987.982] (II) intel(0): Output eDP1 has no monitor section
[   987.983] (**) intel(0): Found backlight control interface intel_backlight (type 'raw') for output eDP1
[   987.983] (II) intel(0): Enabled output eDP1
[   987.983] (II) intel(0): Output VGA1 has no monitor section
[   987.984] (II) intel(0): Enabled output VGA1
[   987.984] (II) intel(0): Output HDMI1 has no monitor section
[   987.984] (II) intel(0): Enabled output HDMI1
[   987.984] (II) intel(0): Output DP1 has no monitor section
[   987.984] (II) intel(0): Enabled output DP1
[   987.984] (II) intel(0): Output HDMI2 has no monitor section
[   987.985] (II) intel(0): Enabled output HDMI2
[   987.985] (II) intel(0): Output DP2 has no monitor section
[   987.985] (II) intel(0): Enabled output DP2
[   987.985] (--) intel(0): Using a maximum size of 256x256 for hardware cursors
[   987.985] (II) intel(0): Output VIRTUAL1 has no monitor section
[   987.985] (II) intel(0): Enabled output VIRTUAL1
[   987.985] (--) intel(0): Output eDP1 using initial mode 1366x768 on pipe 0
[   987.986] (==) intel(0): TearFree disabled
[   987.986] (==) intel(0): Using gamma correction (1.0, 1.0, 1.0)
[   987.986] (==) intel(0): DPI set to (96, 96)
[   987.986] (II) Loading sub module "dri3"
[   987.986] (II) LoadModule: "dri3"
[   987.986] (II) Module "dri3" already built-in
[   987.986] (II) Loading sub module "dri2"
[   987.986] (II) LoadModule: "dri2"
[   987.986] (II) Module "dri2" already built-in
[   987.986] (II) Loading sub module "present"
[   987.986] (II) LoadModule: "present"
[   987.986] (II) Module "present" already built-in
[   987.986] (II) UnloadModule: "modesetting"
[   987.986] (II) Unloading modesetting
[   987.986] (II) UnloadModule: "fbdev"
[   987.986] (II) Unloading fbdev
[   987.986] (II) UnloadSubModule: "fbdevhw"
[   987.986] (II) Unloading fbdevhw
[   987.987] (II) UnloadModule: "vesa"
[   987.987] (II) Unloading vesa
[   987.987] (II) intel(0): SNA initialized with Ironlake (gen5) backend
[   987.987] (==) intel(0): Backing store enabled
[   987.987] (==) intel(0): Silken mouse enabled
[   987.988] (II) intel(0): HW Cursor enabled
[   987.988] (==) intel(0): DPMS enabled
[   987.988] (==) intel(0): Display hotplug detection enabled
[   987.988] (II) intel(0): [XvMC] xvmc_vld driver initialized.
[   987.988] (II) intel(0): [DRI2] Setup complete
[   987.988] (II) intel(0): [DRI2]   DRI driver: i965
[   987.989] (II) intel(0): [DRI2]   VDPAU driver: va_gl
[   987.989] (II) intel(0): direct rendering: DRI2 DRI3 enabled
[   987.989] (II) intel(0): hardware support for Present enabled
[   987.989] (II) Initializing extension Generic Event Extension
[   987.989] (II) Initializing extension SHAPE
[   987.989] (II) Initializing extension MIT-SHM
[   987.989] (II) Initializing extension XInputExtension
[   987.989] (II) Initializing extension XTEST
[   987.989] (II) Initializing extension BIG-REQUESTS
[   987.989] (II) Initializing extension SYNC
[   987.989] (II) Initializing extension XKEYBOARD
[   987.989] (II) Initializing extension XC-MISC
[   987.989] (II) Initializing extension XFIXES
[   987.989] (II) Initializing extension RENDER
[   987.989] (II) Initializing extension RANDR
[   987.989] (II) Initializing extension COMPOSITE
[   987.989] (II) Initializing extension DAMAGE
[   987.989] (II) Initializing extension MIT-SCREEN-SAVER
[   987.989] (II) Initializing extension DOUBLE-BUFFER
[   987.989] (II) Initializing extension RECORD
[   987.989] (II) Initializing extension DPMS
[   987.989] (II) Initializing extension Present
[   987.989] (II) Initializing extension DRI3
[   987.989] (II) Initializing extension X-Resource
[   987.989] (II) Initializing extension XVideo
[   987.989] (II) Initializing extension XVideo-MotionCompensation
[   987.989] (II) Initializing extension GLX
[   988.063] (II) AIGLX: Loaded and initialized i965
[   988.063] (II) GLX: Initialized DRI2 GL provider for screen 0
[   988.063] (II) Initializing extension XFree86-VidModeExtension
[   988.063] (II) Initializing extension XFree86-DGA
[   988.063] (II) Initializing extension XFree86-DRI
[   988.063] (II) Initializing extension DRI2
[   988.077] (II) intel(0): switch to mode [email protected] on eDP1 using pipe 0, position (0, 0), rotation normal, reflection none
[   988.096] (II) intel(0): Setting screen physical size to 361 x 203
[   988.242] (II) config/udev: Adding input device Power Button (/dev/input/event3)
[   988.242] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[   988.243] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[   988.243] (**) Power Button: Applying InputClass "joystick-all"
[   988.243] (**) Power Button: Applying InputClass "system-keyboard"
[   988.243] (II) LoadModule: "libinput"
[   988.243] (II) Loading /usr/lib64/xorg/modules/input/libinput_drv.so
[   988.245] (II) Module libinput: vendor="X.Org Foundation"
[   988.245] 	compiled for 1.20.5, module version = 0.29.0
[   988.245] 	Module class: X.Org XInput Driver
[   988.245] 	ABI class: X.Org XInput driver, version 24.1
[   988.245] (II) Using input driver 'libinput' for 'Power Button'
[   988.248] (II) systemd-logind: got fd for /dev/input/event3 13:67 fd 25 paused 0
[   988.248] (**) Power Button: always reports core events
[   988.248] (**) Option "Device" "/dev/input/event3"
[   988.249] (**) Option "_source" "server/udev"
[   988.255] (II) event3  - Power Button: is tagged by udev as: Keyboard
[   988.255] (II) event3  - Power Button: device is a keyboard
[   988.256] (II) event3  - Power Button: device removed
[   988.256] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input3/event3"
[   988.256] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 6)
[   988.256] (**) Option "xkb_layout" "latam,us"
[   988.256] (**) Option "xkb_variant" ","
[   988.330] (II) event3  - Power Button: is tagged by udev as: Keyboard
[   988.330] (II) event3  - Power Button: device is a keyboard
[   988.332] (II) config/udev: Adding input device Video Bus (/dev/input/event5)
[   988.332] (**) Video Bus: Applying InputClass "evdev keyboard catchall"
[   988.332] (**) Video Bus: Applying InputClass "libinput keyboard catchall"
[   988.332] (**) Video Bus: Applying InputClass "joystick-all"
[   988.332] (**) Video Bus: Applying InputClass "system-keyboard"
[   988.332] (II) Using input driver 'libinput' for 'Video Bus'
[   988.336] (II) systemd-logind: got fd for /dev/input/event5 13:69 fd 28 paused 0
[   988.336] (**) Video Bus: always reports core events
[   988.336] (**) Option "Device" "/dev/input/event5"
[   988.336] (**) Option "_source" "server/udev"
[   988.339] (II) event5  - Video Bus: is tagged by udev as: Keyboard
[   988.339] (II) event5  - Video Bus: device is a keyboard
[   988.339] (II) event5  - Video Bus: device removed
[   988.339] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:00/input/input6/event5"
[   988.339] (II) XINPUT: Adding extended input device "Video Bus" (type: KEYBOARD, id 7)
[   988.340] (**) Option "xkb_layout" "latam,us"
[   988.340] (**) Option "xkb_variant" ","
[   988.343] (II) event5  - Video Bus: is tagged by udev as: Keyboard
[   988.343] (II) event5  - Video Bus: device is a keyboard
[   988.344] (II) config/udev: Adding input device Power Button (/dev/input/event1)
[   988.345] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[   988.345] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[   988.345] (**) Power Button: Applying InputClass "joystick-all"
[   988.345] (**) Power Button: Applying InputClass "system-keyboard"
[   988.345] (II) Using input driver 'libinput' for 'Power Button'
[   988.348] (II) systemd-logind: got fd for /dev/input/event1 13:65 fd 29 paused 0
[   988.348] (**) Power Button: always reports core events
[   988.348] (**) Option "Device" "/dev/input/event1"
[   988.349] (**) Option "_source" "server/udev"
[   988.351] (II) event1  - Power Button: is tagged by udev as: Keyboard
[   988.351] (II) event1  - Power Button: device is a keyboard
[   988.352] (II) event1  - Power Button: device removed
[   988.352] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input1/event1"
[   988.352] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 8)
[   988.352] (**) Option "xkb_layout" "latam,us"
[   988.352] (**) Option "xkb_variant" ","
[   988.355] (II) event1  - Power Button: is tagged by udev as: Keyboard
[   988.355] (II) event1  - Power Button: device is a keyboard
[   988.357] (II) config/udev: Adding input device Lid Switch (/dev/input/event0)
[   988.357] (**) Lid Switch: Applying InputClass "joystick-all"
[   988.357] (II) No input driver specified, ignoring this device.
[   988.357] (II) This device may have been added with another device file.
[   988.358] (II) config/udev: Adding input device Sleep Button (/dev/input/event2)
[   988.358] (**) Sleep Button: Applying InputClass "evdev keyboard catchall"
[   988.358] (**) Sleep Button: Applying InputClass "libinput keyboard catchall"
[   988.358] (**) Sleep Button: Applying InputClass "joystick-all"
[   988.358] (**) Sleep Button: Applying InputClass "system-keyboard"
[   988.358] (II) Using input driver 'libinput' for 'Sleep Button'
[   988.362] (II) systemd-logind: got fd for /dev/input/event2 13:66 fd 30 paused 0
[   988.362] (**) Sleep Button: always reports core events
[   988.362] (**) Option "Device" "/dev/input/event2"
[   988.362] (**) Option "_source" "server/udev"
[   988.365] (II) event2  - Sleep Button: is tagged by udev as: Keyboard
[   988.365] (II) event2  - Sleep Button: device is a keyboard
[   988.366] (II) event2  - Sleep Button: device removed
[   988.366] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input2/event2"
[   988.366] (II) XINPUT: Adding extended input device "Sleep Button" (type: KEYBOARD, id 9)
[   988.366] (**) Option "xkb_layout" "latam,us"
[   988.366] (**) Option "xkb_variant" ","
[   988.369] (II) event2  - Sleep Button: is tagged by udev as: Keyboard
[   988.370] (II) event2  - Sleep Button: device is a keyboard
[   988.372] (II) config/udev: Adding input device HDA Digital PCBeep (/dev/input/event10)
[   988.373] (**) HDA Digital PCBeep: Applying InputClass "joystick-all"
[   988.373] (II) No input driver specified, ignoring this device.
[   988.373] (II) This device may have been added with another device file.
[   988.374] (II) config/udev: Adding input device HDA Intel MID Dock Mic (/dev/input/event11)
[   988.374] (**) HDA Intel MID Dock Mic: Applying InputClass "joystick-all"
[   988.374] (II) No input driver specified, ignoring this device.
[   988.374] (II) This device may have been added with another device file.
[   988.375] (II) config/udev: Adding input device HDA Intel MID Mic (/dev/input/event12)
[   988.376] (**) HDA Intel MID Mic: Applying InputClass "joystick-all"
[   988.376] (II) No input driver specified, ignoring this device.
[   988.376] (II) This device may have been added with another device file.
[   988.377] (II) config/udev: Adding input device HDA Intel MID Dock Line Out (/dev/input/event13)
[   988.377] (**) HDA Intel MID Dock Line Out: Applying InputClass "joystick-all"
[   988.377] (II) No input driver specified, ignoring this device.
[   988.377] (II) This device may have been added with another device file.
[   988.379] (II) config/udev: Adding input device HDA Intel MID Headphone (/dev/input/event14)
[   988.379] (**) HDA Intel MID Headphone: Applying InputClass "joystick-all"
[   988.379] (II) No input driver specified, ignoring this device.
[   988.379] (II) This device may have been added with another device file.
[   988.380] (II) config/udev: Adding input device HDA Intel MID HDMI/DP,pcm=3 (/dev/input/event15)
[   988.380] (**) HDA Intel MID HDMI/DP,pcm=3: Applying InputClass "joystick-all"
[   988.380] (II) No input driver specified, ignoring this device.
[   988.380] (II) This device may have been added with another device file.
[   988.382] (II) config/udev: Adding input device HDA Intel MID HDMI/DP,pcm=7 (/dev/input/event16)
[   988.382] (**) HDA Intel MID HDMI/DP,pcm=7: Applying InputClass "joystick-all"
[   988.382] (II) No input driver specified, ignoring this device.
[   988.382] (II) This device may have been added with another device file.
[   988.384] (II) config/udev: Adding input device USB Optical Mouse (/dev/input/event6)
[   988.385] (**) USB Optical Mouse: Applying InputClass "evdev pointer catchall"
[   988.385] (**) USB Optical Mouse: Applying InputClass "libinput pointer catchall"
[   988.385] (**) USB Optical Mouse: Applying InputClass "joystick-all"
[   988.385] (II) Using input driver 'libinput' for 'USB Optical Mouse'
[   988.389] (II) systemd-logind: got fd for /dev/input/event6 13:70 fd 31 paused 0
[   988.389] (**) USB Optical Mouse: always reports core events
[   988.389] (**) Option "Device" "/dev/input/event6"
[   988.389] (**) Option "_source" "server/udev"
[   988.394] (II) event6  - USB Optical Mouse: is tagged by udev as: Mouse
[   988.395] (II) event6  - USB Optical Mouse: device is a pointer
[   988.395] (II) event6  - USB Optical Mouse: device removed
[   988.396] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.2/2-1.2:1.0/0003:0461:4D81.0001/input/input7/event6"
[   988.396] (II) XINPUT: Adding extended input device "USB Optical Mouse" (type: MOUSE, id 10)
[   988.396] (**) Option "AccelerationScheme" "none"
[   988.396] (**) USB Optical Mouse: (accel) selected scheme none/0
[   988.396] (**) USB Optical Mouse: (accel) acceleration factor: 2.000
[   988.396] (**) USB Optical Mouse: (accel) acceleration threshold: 4
[   988.401] (II) event6  - USB Optical Mouse: is tagged by udev as: Mouse
[   988.401] (II) event6  - USB Optical Mouse: device is a pointer
[   988.404] (II) config/udev: Adding input device USB Optical Mouse (/dev/input/mouse0)
[   988.404] (**) USB Optical Mouse: Applying InputClass "joystick-all"
[   988.404] (II) No input driver specified, ignoring this device.
[   988.404] (II) This device may have been added with another device file.
[   988.406] (II) config/udev: Adding input device Dell WMI hotkeys (/dev/input/event8)
[   988.406] (**) Dell WMI hotkeys: Applying InputClass "evdev keyboard catchall"
[   988.406] (**) Dell WMI hotkeys: Applying InputClass "libinput keyboard catchall"
[   988.406] (**) Dell WMI hotkeys: Applying InputClass "joystick-all"
[   988.406] (**) Dell WMI hotkeys: Applying InputClass "system-keyboard"
[   988.406] (II) Using input driver 'libinput' for 'Dell WMI hotkeys'
[   988.410] (II) systemd-logind: got fd for /dev/input/event8 13:72 fd 32 paused 0
[   988.410] (**) Dell WMI hotkeys: always reports core events
[   988.410] (**) Option "Device" "/dev/input/event8"
[   988.410] (**) Option "_source" "server/udev"
[   988.415] (II) event8  - Dell WMI hotkeys: is tagged by udev as: Keyboard
[   988.415] (II) event8  - Dell WMI hotkeys: device is a keyboard
[   988.416] (II) event8  - Dell WMI hotkeys: device removed
[   988.416] (**) Option "config_info" "udev:/sys/devices/platform/PNP0C14:00/wmi_bus/wmi_bus-PNP0C14:00/9DBB5994-A997-11DA-B012-B622A1EF5492/input/input9/event8"
[   988.416] (II) XINPUT: Adding extended input device "Dell WMI hotkeys" (type: KEYBOARD, id 11)
[   988.416] (**) Option "xkb_layout" "latam,us"
[   988.416] (**) Option "xkb_variant" ","
[   988.421] (II) event8  - Dell WMI hotkeys: is tagged by udev as: Keyboard
[   988.421] (II) event8  - Dell WMI hotkeys: device is a keyboard
[   988.423] (II) config/udev: Adding input device AT Translated Set 2 keyboard (/dev/input/event4)
[   988.423] (**) AT Translated Set 2 keyboard: Applying InputClass "evdev keyboard catchall"
[   988.423] (**) AT Translated Set 2 keyboard: Applying InputClass "libinput keyboard catchall"
[   988.423] (**) AT Translated Set 2 keyboard: Applying InputClass "joystick-all"
[   988.423] (**) AT Translated Set 2 keyboard: Applying InputClass "system-keyboard"
[   988.423] (II) Using input driver 'libinput' for 'AT Translated Set 2 keyboard'
[   988.427] (II) systemd-logind: got fd for /dev/input/event4 13:68 fd 33 paused 0
[   988.427] (**) AT Translated Set 2 keyboard: always reports core events
[   988.427] (**) Option "Device" "/dev/input/event4"
[   988.427] (**) Option "_source" "server/udev"
[   988.432] (II) event4  - AT Translated Set 2 keyboard: is tagged by udev as: Keyboard
[   988.432] (II) event4  - AT Translated Set 2 keyboard: device is a keyboard
[   988.434] (II) event4  - AT Translated Set 2 keyboard: device removed
[   988.434] (**) Option "config_info" "udev:/sys/devices/platform/i8042/serio0/input/input4/event4"
[   988.434] (II) XINPUT: Adding extended input device "AT Translated Set 2 keyboard" (type: KEYBOARD, id 12)
[   988.434] (**) Option "xkb_layout" "latam,us"
[   988.434] (**) Option "xkb_variant" ","
[   988.438] (II) event4  - AT Translated Set 2 keyboard: is tagged by udev as: Keyboard
[   988.439] (II) event4  - AT Translated Set 2 keyboard: device is a keyboard
[   988.442] (II) config/udev: Adding input device AlpsPS/2 ALPS GlidePoint (/dev/input/event9)
[   988.442] (**) AlpsPS/2 ALPS GlidePoint: Applying InputClass "evdev touchpad catchall"
[   988.442] (**) AlpsPS/2 ALPS GlidePoint: Applying InputClass "libinput touchpad catchall"
[   988.442] (**) AlpsPS/2 ALPS GlidePoint: Applying InputClass "joystick-all"
[   988.442] (**) AlpsPS/2 ALPS GlidePoint: Applying InputClass "touchpad catchall"
[   988.442] (**) AlpsPS/2 ALPS GlidePoint: Applying InputClass "Default clickpad buttons"
[   988.443] (II) LoadModule: "synaptics"
[   988.443] (II) Loading /usr/lib64/xorg/modules/input/synaptics_drv.so
[   988.443] (II) Module synaptics: vendor="X.Org Foundation"
[   988.443] 	compiled for 1.20.5, module version = 1.9.1
[   988.443] 	Module class: X.Org XInput Driver
[   988.443] 	ABI class: X.Org XInput driver, version 24.1
[   988.443] (II) Using input driver 'synaptics' for 'AlpsPS/2 ALPS GlidePoint'
[   988.447] (II) systemd-logind: got fd for /dev/input/event9 13:73 fd 34 paused 0
[   988.447] (**) AlpsPS/2 ALPS GlidePoint: always reports core events
[   988.447] (**) Option "Device" "/dev/input/event9"
[   988.447] (II) synaptics: AlpsPS/2 ALPS GlidePoint: ignoring touch events for semi-multitouch device
[   988.447] (--) synaptics: AlpsPS/2 ALPS GlidePoint: x-axis range 0 - 2000 (res 0)
[   988.447] (--) synaptics: AlpsPS/2 ALPS GlidePoint: y-axis range 0 - 1400 (res 0)
[   988.447] (--) synaptics: AlpsPS/2 ALPS GlidePoint: pressure range 0 - 127
[   988.447] (II) synaptics: AlpsPS/2 ALPS GlidePoint: device does not report finger width.
[   988.447] (--) synaptics: AlpsPS/2 ALPS GlidePoint: buttons: left right middle double triple
[   988.447] (--) synaptics: AlpsPS/2 ALPS GlidePoint: Vendor 0x2 Product 0x8
[   988.447] (--) synaptics: AlpsPS/2 ALPS GlidePoint: invalid finger width range.  defaulting to 0 - 15
[   988.448] (--) synaptics: AlpsPS/2 ALPS GlidePoint: touchpad found
[   988.448] (**) AlpsPS/2 ALPS GlidePoint: always reports core events
[   988.448] (**) Option "config_info" "udev:/sys/devices/platform/i8042/serio1/input/input10/event9"
[   988.448] (II) XINPUT: Adding extended input device "AlpsPS/2 ALPS GlidePoint" (type: TOUCHPAD, id 13)
[   988.448] (**) synaptics: AlpsPS/2 ALPS GlidePoint: (accel) MinSpeed is now constant deceleration 2.5
[   988.448] (**) synaptics: AlpsPS/2 ALPS GlidePoint: (accel) MaxSpeed is now 1.75
[   988.448] (**) synaptics: AlpsPS/2 ALPS GlidePoint: (accel) AccelFactor is now 0.082
[   988.448] (**) AlpsPS/2 ALPS GlidePoint: (accel) keeping acceleration scheme 1
[   988.448] (**) AlpsPS/2 ALPS GlidePoint: (accel) acceleration profile 1
[   988.449] (**) AlpsPS/2 ALPS GlidePoint: (accel) acceleration factor: 2.000
[   988.449] (**) AlpsPS/2 ALPS GlidePoint: (accel) acceleration threshold: 4
[   988.449] (--) synaptics: AlpsPS/2 ALPS GlidePoint: touchpad found
[   988.450] (II) config/udev: Adding input device AlpsPS/2 ALPS GlidePoint (/dev/input/mouse1)
[   988.450] (**) AlpsPS/2 ALPS GlidePoint: Ignoring device from InputClass "touchpad ignore duplicates"
[   988.452] (II) config/udev: Adding input device PC Speaker (/dev/input/event7)
[   988.452] (**) PC Speaker: Applying InputClass "joystick-all"
[   988.452] (II) No input driver specified, ignoring this device.
[   988.452] (II) This device may have been added with another device file.
[   989.627] (II) intel(0): EDID vendor "AUO", prod id 9708
[   989.627] (II) intel(0): Printing DDC gathered Modelines:
[   989.627] (II) intel(0): Modeline "1366x768"x0.0   69.00  1366 1398 1422 1426  768 771 775 806 +hsync -vsync (48.4 kHz eP)
[   989.627] (II) intel(0): Modeline "1366x768"x0.0   46.00  1366 1398 1422 1426  768 771 775 806 +hsync -vsync (32.3 kHz e)
[ 55762.547] (**) Option "fd" "25"
[ 55762.565] (II) event3  - Power Button: device removed
[ 55762.568] (**) Option "fd" "28"
[ 55762.568] (II) event5  - Video Bus: device removed
[ 55762.569] (**) Option "fd" "29"
[ 55762.569] (II) event1  - Power Button: device removed
[ 55762.570] (**) Option "fd" "30"
[ 55762.570] (II) event2  - Sleep Button: device removed
[ 55762.570] (**) Option "fd" "31"
[ 55762.570] (II) event6  - USB Optical Mouse: device removed
[ 55762.571] (**) Option "fd" "32"
[ 55762.571] (II) event8  - Dell WMI hotkeys: device removed
[ 55762.573] (**) Option "fd" "33"
[ 55762.573] (II) event4  - AT Translated Set 2 keyboard: device removed
[ 55762.900] (II) AIGLX: Suspending AIGLX clients for VT switch
[ 55762.999] (II) systemd-logind: got pause for 226:0
[ 55763.000] (II) systemd-logind: got pause for 13:66
[ 55763.000] (II) systemd-logind: got pause for 13:65
[ 55763.000] (II) systemd-logind: got pause for 13:67
[ 55763.000] (II) systemd-logind: got pause for 13:73
[ 55763.000] (II) systemd-logind: got pause for 13:68
[ 55763.000] (II) systemd-logind: got pause for 13:72
[ 55763.000] (II) systemd-logind: got pause for 13:69
[ 55763.000] (II) systemd-logind: got pause for 13:70
[ 55763.688] (II) systemd-logind: got resume for 226:0
[ 55763.688] (II) AIGLX: Resuming AIGLX clients after VT switch
[ 55763.689] (II) intel(0): switch to mode [email protected] on eDP1 using pipe 0, position (0, 0), rotation normal, reflection none
[ 55763.815] (II) systemd-logind: got resume for 13:66
[ 55763.876] (II) event2  - Sleep Button: is tagged by udev as: Keyboard
[ 55763.876] (II) event2  - Sleep Button: device is a keyboard
[ 55763.879] (II) systemd-logind: got resume for 13:65
[ 55763.881] (II) event1  - Power Button: is tagged by udev as: Keyboard
[ 55763.881] (II) event1  - Power Button: device is a keyboard
[ 55763.882] (II) systemd-logind: got resume for 13:67
[ 55763.885] (II) event3  - Power Button: is tagged by udev as: Keyboard
[ 55763.885] (II) event3  - Power Button: device is a keyboard
[ 55763.886] (II) systemd-logind: got resume for 13:73
[ 55763.886] (--) synaptics: AlpsPS/2 ALPS GlidePoint: touchpad found
[ 55763.887] (II) systemd-logind: got resume for 13:68
[ 55763.890] (II) event4  - AT Translated Set 2 keyboard: is tagged by udev as: Keyboard
[ 55763.891] (II) event4  - AT Translated Set 2 keyboard: device is a keyboard
[ 55763.893] (II) systemd-logind: got resume for 13:72
[ 55763.897] (II) event8  - Dell WMI hotkeys: is tagged by udev as: Keyboard
[ 55763.897] (II) event8  - Dell WMI hotkeys: device is a keyboard
[ 55763.899] (II) systemd-logind: got resume for 13:69
[ 55763.901] (II) event5  - Video Bus: is tagged by udev as: Keyboard
[ 55763.902] (II) event5  - Video Bus: device is a keyboard
[ 55763.903] (II) systemd-logind: got resume for 13:70
[ 55763.909] (II) event6  - USB Optical Mouse: is tagged by udev as: Mouse
[ 55763.909] (II) event6  - USB Optical Mouse: device is a pointer
[ 55946.659] (**) Option "fd" "29"
[ 55946.659] (II) event3  - Power Button: device removed
[ 55946.665] (**) Option "fd" "33"
[ 55946.665] (II) event5  - Video Bus: device removed
[ 55946.669] (**) Option "fd" "28"
[ 55946.670] (II) event1  - Power Button: device removed
[ 55946.676] (**) Option "fd" "25"
[ 55946.676] (II) event2  - Sleep Button: device removed
[ 55946.680] (**) Option "fd" "74"
[ 55946.680] (II) event6  - USB Optical Mouse: device removed
[ 55946.685] (**) Option "fd" "32"
[ 55946.685] (II) event8  - Dell WMI hotkeys: device removed
[ 55946.691] (**) Option "fd" "31"
[ 55946.691] (II) event4  - AT Translated Set 2 keyboard: device removed
[ 55946.698] (II) AIGLX: Suspending AIGLX clients for VT switch
[ 55946.791] (II) systemd-logind: got pause for 226:0
[ 55946.791] (II) systemd-logind: got pause for 13:66
[ 55946.791] (II) systemd-logind: got pause for 13:65
[ 55946.791] (II) systemd-logind: got pause for 13:67
[ 55946.791] (II) systemd-logind: got pause for 13:73
[ 55946.791] (II) systemd-logind: got pause for 13:68
[ 55946.791] (II) systemd-logind: got pause for 13:72
[ 55946.791] (II) systemd-logind: got pause for 13:69
[ 55946.791] (II) systemd-logind: got pause for 13:70
[ 56098.250] (II) systemd-logind: got resume for 226:0
[ 56098.251] (II) AIGLX: Resuming AIGLX clients after VT switch
[ 56098.251] (II) intel(0): switch to mode [email protected] on eDP1 using pipe 0, position (0, 0), rotation normal, reflection none
[ 56098.396] (II) systemd-logind: got resume for 13:66
[ 56098.400] (II) event2  - Sleep Button: is tagged by udev as: Keyboard
[ 56098.400] (II) event2  - Sleep Button: device is a keyboard
[ 56098.403] (II) systemd-logind: got resume for 13:65
[ 56098.406] (II) event1  - Power Button: is tagged by udev as: Keyboard
[ 56098.406] (II) event1  - Power Button: device is a keyboard
[ 56098.407] (II) systemd-logind: got resume for 13:67
[ 56098.409] (II) event3  - Power Button: is tagged by udev as: Keyboard
[ 56098.409] (II) event3  - Power Button: device is a keyboard
[ 56098.410] (II) systemd-logind: got resume for 13:73
[ 56098.411] (--) synaptics: AlpsPS/2 ALPS GlidePoint: touchpad found
[ 56098.412] (II) systemd-logind: got resume for 13:68
[ 56098.415] (II) event4  - AT Translated Set 2 keyboard: is tagged by udev as: Keyboard
[ 56098.416] (II) event4  - AT Translated Set 2 keyboard: device is a keyboard
[ 56098.418] (II) systemd-logind: got resume for 13:72
[ 56098.422] (II) event8  - Dell WMI hotkeys: is tagged by udev as: Keyboard
[ 56098.422] (II) event8  - Dell WMI hotkeys: device is a keyboard
[ 56098.424] (II) systemd-logind: got resume for 13:69
[ 56098.426] (II) event5  - Video Bus: is tagged by udev as: Keyboard
[ 56098.427] (II) event5  - Video Bus: device is a keyboard
[ 56098.428] (II) systemd-logind: got resume for 13:70
[ 56098.433] (II) event6  - USB Optical Mouse: is tagged by udev as: Mouse
[ 56098.433] (II) event6  - USB Optical Mouse: device is a pointer
[ 56395.979] (II) config/udev: removing device USB Optical Mouse
[ 56395.980] (**) Option "fd" "34"
[ 56395.980] (II) event6  - USB Optical Mouse: device removed
[ 56396.014] (II) UnloadModule: "libinput"
[ 56396.014] (II) systemd-logind: releasing fd for 13:70
[ 56396.016] (EE) systemd-logind: failed to release device: Device not taken
[ 56398.759] (II) config/udev: Adding input device USB Optical Mouse (/dev/input/mouse0)
[ 56399.042] (**) USB Optical Mouse: Applying InputClass "joystick-all"
[ 56399.043] (II) No input driver specified, ignoring this device.
[ 56399.043] (II) This device may have been added with another device file.
[ 56399.045] (II) config/udev: Adding input device USB Optical Mouse (/dev/input/event6)
[ 56399.045] (**) USB Optical Mouse: Applying InputClass "evdev pointer catchall"
[ 56399.045] (**) USB Optical Mouse: Applying InputClass "libinput pointer catchall"
[ 56399.045] (**) USB Optical Mouse: Applying InputClass "joystick-all"
[ 56399.045] (II) Using input driver 'libinput' for 'USB Optical Mouse'
[ 56399.101] (II) systemd-logind: got fd for /dev/input/event6 13:70 fd 71 paused 0
[ 56399.101] (**) USB Optical Mouse: always reports core events
[ 56399.101] (**) Option "Device" "/dev/input/event6"
[ 56399.101] (**) Option "_source" "server/udev"
[ 56399.107] (II) event6  - USB Optical Mouse: is tagged by udev as: Mouse
[ 56399.107] (II) event6  - USB Optical Mouse: device is a pointer
[ 56399.108] (II) event6  - USB Optical Mouse: device removed
[ 56399.108] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.2/2-1.2:1.0/0003:0461:4D81.0002/input/input18/event6"
[ 56399.108] (II) XINPUT: Adding extended input device "USB Optical Mouse" (type: MOUSE, id 10)
[ 56399.111] (**) Option "AccelerationScheme" "none"
[ 56399.115] (**) USB Optical Mouse: (accel) selected scheme none/0
[ 56399.115] (**) USB Optical Mouse: (accel) acceleration factor: 2.000
[ 56399.115] (**) USB Optical Mouse: (accel) acceleration threshold: 4
[ 56399.120] (II) event6  - USB Optical Mouse: is tagged by udev as: Mouse
[ 56399.120] (II) event6  - USB Optical Mouse: device is a pointer
[ 56437.901] (**) Option "fd" "29"
[ 56437.901] (II) event3  - Power Button: device removed
[ 56437.902] (**) Option "fd" "33"
[ 56437.902] (II) event5  - Video Bus: device removed
[ 56437.903] (**) Option "fd" "25"
[ 56437.903] (II) event1  - Power Button: device removed
[ 56437.909] (**) Option "fd" "74"
[ 56437.909] (II) event2  - Sleep Button: device removed
[ 56437.915] (**) Option "fd" "32"
[ 56437.915] (II) event8  - Dell WMI hotkeys: device removed
[ 56437.924] (**) Option "fd" "31"
[ 56437.924] (II) event4  - AT Translated Set 2 keyboard: device removed
[ 56437.934] (**) Option "fd" "71"
[ 56437.934] (II) event6  - USB Optical Mouse: device removed
[ 56437.937] (II) AIGLX: Suspending AIGLX clients for VT switch
[ 56437.958] (II) systemd-logind: got pause for 226:0
[ 56437.958] (II) systemd-logind: got pause for 13:66
[ 56437.958] (II) systemd-logind: got pause for 13:65
[ 56437.958] (II) systemd-logind: got pause for 13:67
[ 56437.958] (II) systemd-logind: got pause for 13:73
[ 56437.958] (II) systemd-logind: got pause for 13:68
[ 56437.958] (II) systemd-logind: got pause for 13:72
[ 56437.959] (II) systemd-logind: got pause for 13:69
[ 56437.959] (II) systemd-logind: got pause for 13:70
[ 56622.137] (II) systemd-logind: got resume for 226:0
[ 56622.138] (II) AIGLX: Resuming AIGLX clients after VT switch
[ 56622.138] (II) intel(0): switch to mode [email protected] on eDP1 using pipe 0, position (0, 0), rotation normal, reflection none
[ 56622.224] (II) systemd-logind: got resume for 13:66
[ 56622.228] (II) event2  - Sleep Button: is tagged by udev as: Keyboard
[ 56622.229] (II) event2  - Sleep Button: device is a keyboard
[ 56622.236] (II) systemd-logind: got resume for 13:65
[ 56622.240] (II) event1  - Power Button: is tagged by udev as: Keyboard
[ 56622.240] (II) event1  - Power Button: device is a keyboard
[ 56622.244] (II) systemd-logind: got resume for 13:67
[ 56622.247] (II) event3  - Power Button: is tagged by udev as: Keyboard
[ 56622.247] (II) event3  - Power Button: device is a keyboard
[ 56622.250] (II) systemd-logind: got resume for 13:73
[ 56622.250] (--) synaptics: AlpsPS/2 ALPS GlidePoint: touchpad found
[ 56622.253] (II) systemd-logind: got resume for 13:68
[ 56622.257] (II) event4  - AT Translated Set 2 keyboard: is tagged by udev as: Keyboard
[ 56622.257] (II) event4  - AT Translated Set 2 keyboard: device is a keyboard
[ 56622.261] (II) systemd-logind: got resume for 13:72
[ 56622.265] (II) event8  - Dell WMI hotkeys: is tagged by udev as: Keyboard
[ 56622.266] (II) event8  - Dell WMI hotkeys: device is a keyboard
[ 56622.269] (II) systemd-logind: got resume for 13:69
[ 56622.272] (II) event5  - Video Bus: is tagged by udev as: Keyboard
[ 56622.272] (II) event5  - Video Bus: device is a keyboard
[ 56622.274] (II) systemd-logind: got resume for 13:70
[ 56622.278] (II) event6  - USB Optical Mouse: is tagged by udev as: Mouse
[ 56622.279] (II) event6  - USB Optical Mouse: device is a pointer
[ 56834.005] (II) config/udev: removing device USB Optical Mouse
[ 56834.006] (**) Option "fd" "68"
[ 56834.006] (II) event6  - USB Optical Mouse: device removed
[ 56834.048] (II) UnloadModule: "libinput"
[ 56834.048] (II) systemd-logind: releasing fd for 13:70
[ 56834.050] (EE) systemd-logind: failed to release device: Device not taken
[ 56835.264] (II) config/udev: Adding input device USB Optical Mouse (/dev/input/mouse0)
[ 56835.264] (**) USB Optical Mouse: Applying InputClass "joystick-all"
[ 56835.264] (II) No input driver specified, ignoring this device.
[ 56835.264] (II) This device may have been added with another device file.
[ 56835.375] (II) config/udev: Adding input device USB Optical Mouse (/dev/input/event6)
[ 56835.375] (**) USB Optical Mouse: Applying InputClass "evdev pointer catchall"
[ 56835.375] (**) USB Optical Mouse: Applying InputClass "libinput pointer catchall"
[ 56835.375] (**) USB Optical Mouse: Applying InputClass "joystick-all"
[ 56835.375] (II) Using input driver 'libinput' for 'USB Optical Mouse'
[ 56835.425] (II) systemd-logind: got fd for /dev/input/event6 13:70 fd 71 paused 0
[ 56835.425] (**) USB Optical Mouse: always reports core events
[ 56835.425] (**) Option "Device" "/dev/input/event6"
[ 56835.425] (**) Option "_source" "server/udev"
[ 56835.433] (II) event6  - USB Optical Mouse: is tagged by udev as: Mouse
[ 56835.433] (II) event6  - USB Optical Mouse: device is a pointer
[ 56835.434] (II) event6  - USB Optical Mouse: device removed
[ 56835.434] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.2/2-1.2:1.0/0003:0461:4D81.0003/input/input19/event6"
[ 56835.434] (II) XINPUT: Adding extended input device "USB Optical Mouse" (type: MOUSE, id 10)
[ 56835.438] (**) Option "AccelerationScheme" "none"
[ 56835.443] (**) USB Optical Mouse: (accel) selected scheme none/0
[ 56835.443] (**) USB Optical Mouse: (accel) acceleration factor: 2.000
[ 56835.443] (**) USB Optical Mouse: (accel) acceleration threshold: 4
[ 56835.448] (II) event6  - USB Optical Mouse: is tagged by udev as: Mouse
[ 56835.449] (II) event6  - USB Optical Mouse: device is a pointer
[ 56896.213] (II) config/udev: removing device USB Optical Mouse
[ 56896.213] (**) Option "fd" "71"
[ 56896.213] (II) event6  - USB Optical Mouse: device removed
[ 56896.248] (II) UnloadModule: "libinput"
[ 56896.248] (II) systemd-logind: releasing fd for 13:70
[ 56896.250] (EE) systemd-logind: failed to release device: Device not taken
[ 56899.984] (**) Option "fd" "30"
[ 56899.984] (II) event3  - Power Button: device removed
[ 56899.989] (**) Option "fd" "34"
[ 56899.989] (II) event5  - Video Bus: device removed
[ 56899.994] (**) Option "fd" "25"
[ 56899.994] (II) event1  - Power Button: device removed
[ 56900.000] (**) Option "fd" "74"
[ 56900.000] (II) event2  - Sleep Button: device removed
[ 56900.004] (**) Option "fd" "33"
[ 56900.004] (II) event8  - Dell WMI hotkeys: device removed
[ 56900.010] (**) Option "fd" "32"
[ 56900.010] (II) event4  - AT Translated Set 2 keyboard: device removed
[ 56900.015] (II) AIGLX: Suspending AIGLX clients for VT switch
[ 56900.038] (II) systemd-logind: got pause for 226:0
[ 56900.038] (II) systemd-logind: got pause for 13:66
[ 56900.039] (II) systemd-logind: got pause for 13:65
[ 56900.039] (II) systemd-logind: got pause for 13:67
[ 56900.039] (II) systemd-logind: got pause for 13:73
[ 56900.039] (II) systemd-logind: got pause for 13:68
[ 56900.039] (II) systemd-logind: got pause for 13:72
[ 56900.039] (II) systemd-logind: got pause for 13:69
[ 56934.412] (II) systemd-logind: got resume for 226:0
[ 56934.412] (II) AIGLX: Resuming AIGLX clients after VT switch
[ 56934.412] (II) intel(0): switch to mode [email protected] on eDP1 using pipe 0, position (0, 0), rotation normal, reflection none
[ 56934.538] (II) systemd-logind: got resume for 13:66
[ 56934.542] (II) event2  - Sleep Button: is tagged by udev as: Keyboard
[ 56934.542] (II) event2  - Sleep Button: device is a keyboard
[ 56934.547] (II) systemd-logind: got resume for 13:65
[ 56934.552] (II) event1  - Power Button: is tagged by udev as: Keyboard
[ 56934.552] (II) event1  - Power Button: device is a keyboard
[ 56934.555] (II) systemd-logind: got resume for 13:67
[ 56934.558] (II) event3  - Power Button: is tagged by udev as: Keyboard
[ 56934.558] (II) event3  - Power Button: device is a keyboard
[ 56934.561] (II) systemd-logind: got resume for 13:73
[ 56934.561] (--) synaptics: AlpsPS/2 ALPS GlidePoint: touchpad found
[ 56934.562] (II) systemd-logind: got resume for 13:68
[ 56934.566] (II) event4  - AT Translated Set 2 keyboard: is tagged by udev as: Keyboard
[ 56934.567] (II) event4  - AT Translated Set 2 keyboard: device is a keyboard
[ 56934.569] (II) systemd-logind: got resume for 13:72
[ 56934.573] (II) event8  - Dell WMI hotkeys: is tagged by udev as: Keyboard
[ 56934.573] (II) event8  - Dell WMI hotkeys: device is a keyboard
[ 56934.575] (II) systemd-logind: got resume for 13:69
[ 56934.577] (II) event5  - Video Bus: is tagged by udev as: Keyboard
[ 56934.578] (II) event5  - Video Bus: device is a keyboard
[ 56954.722] (II) config/udev: Adding input device USB Optical Mouse (/dev/input/mouse0)
[ 56954.722] (**) USB Optical Mouse: Applying InputClass "joystick-all"
[ 56954.723] (II) No input driver specified, ignoring this device.
[ 56954.723] (II) This device may have been added with another device file.
[ 56954.807] (II) config/udev: Adding input device USB Optical Mouse (/dev/input/event6)
[ 56954.807] (**) USB Optical Mouse: Applying InputClass "evdev pointer catchall"
[ 56954.807] (**) USB Optical Mouse: Applying InputClass "libinput pointer catchall"
[ 56954.807] (**) USB Optical Mouse: Applying InputClass "joystick-all"
[ 56954.807] (II) Using input driver 'libinput' for 'USB Optical Mouse'
[ 56954.867] (II) systemd-logind: got fd for /dev/input/event6 13:70 fd 77 paused 0
[ 56954.868] (**) USB Optical Mouse: always reports core events
[ 56954.868] (**) Option "Device" "/dev/input/event6"
[ 56954.868] (**) Option "_source" "server/udev"
[ 56954.875] (II) event6  - USB Optical Mouse: is tagged by udev as: Mouse
[ 56954.875] (II) event6  - USB Optical Mouse: device is a pointer
[ 56954.876] (II) event6  - USB Optical Mouse: device removed
[ 56954.877] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.2/2-1.2:1.0/0003:0461:4D81.0004/input/input20/event6"
[ 56954.877] (II) XINPUT: Adding extended input device "USB Optical Mouse" (type: MOUSE, id 10)
[ 56954.883] (**) Option "AccelerationScheme" "none"
[ 56954.890] (**) USB Optical Mouse: (accel) selected scheme none/0
[ 56954.890] (**) USB Optical Mouse: (accel) acceleration factor: 2.000
[ 56954.890] (**) USB Optical Mouse: (accel) acceleration threshold: 4
[ 56954.896] (II) event6  - USB Optical Mouse: is tagged by udev as: Mouse
[ 56954.896] (II) event6  - USB Optical Mouse: device is a pointer
Post by albfneto » Sat Jan 25, 2020 0:14
Please, even with or without the graphical interface,
log as Root in command line, and execute this command. Post the output:
# systemctl status systemd-logind.service
the expected is the service load and active
ShadowOne333
Post by ShadowOne333 » Mon Jan 27, 2020 15:30
Ran the command as root in terminal, this is the output.:
● systemd-logind.service - Login Service
   Loaded: loaded (/lib/systemd/system/systemd-logind.service; static; vendor p>
   Active: active (running) since Fri 2020-01-24 16:21:43 MST; 2 days ago
     Docs: man:systemd-logind.service(8)
           man:logind.conf(5)
           https://www.freedesktop.org/wiki/Software/systemd/logind
           https://www.freedesktop.org/wiki/Software/systemd/multiseat
 Main PID: 795 (systemd-logind)
   Status: "Processing requests..."
    Tasks: 1 (limit: 4455)
   Memory: 2.1M
   CGroup: /system.slice/systemd-logind.service
           └─795 /lib/systemd/systemd-logind
Jan 24 16:21:41 Shadow systemd-logind[795]: Watching system buttons on /dev/inp>
Jan 24 16:21:42 Shadow systemd-logind[795]: Watching system buttons on /dev/inp>
Jan 24 16:21:43 Shadow systemd[1]: Started Login Service.
Jan 24 16:21:53 Shadow systemd-logind[795]: New session c1 of user gdm.
Jan 24 16:22:28 Shadow systemd-logind[795]: New session 1 of user Shadow.
Jan 24 16:22:54 Shadow systemd-logind[795]: Session 1 logged out. Waiting for p>
Jan 24 16:23:01 Shadow systemd-logind[795]: Removed session 1.
Jan 24 16:23:02 Shadow systemd-logind[795]: New session 2 of user root.
