Graphic glitches with chromium since update [Solved]
andreios
Post by andreios » Sat Jun 01, 2019 14:55
Has anybody else graphic problems with chromium since last update? Here it is pretty much unusable.
Using an AMD APU with Radeon graphics.
mesa-19.0.5
chromium-72.0.3626.121
Alexander88207
Re: Graphic glitches with chromium since update
Post by Alexander88207 » Sat Jun 08, 2019 16:30
Hi andreios,
this is a bug of Mesa 19.0.5 and is already fixed in 19.1.0-rc4, but dont worry an update to the 19.0 stable branch is coming :).
In the meantime, you can disable the hardware acceleration in Chromium.
Source: https://bugs.freedesktop.org/show_bug.cgi?id=110721
How to create a sabayon uefi usb device: https://github.com/linuxerus/sabayon-st ... -device.md
andreios
Post by andreios » Sat Jun 08, 2019 17:08
Yes I know already doing chromium-browser --disable-gpu works as a workaround. But why not just use 19.0.4 in the mean time? Would be much easier for many.
Alexander88207
Post by Alexander88207 » Sat Jun 08, 2019 19:15
Mesa 19.0.6 is out, that fixes this bug!
here is the request:
https://bugs.sabayon.org/show_bug.cgi?id=5800
andreios
Post by andreios » Tue Jun 11, 2019 14:28
Solved with Mesa 19.0.6. :)
