missing flatpak icons
messana
Post by messana » Mon Apr 08, 2019 8:04
Hi everyone, I installed flatpak using the community repository. Everything works perfectly but I have a problem with the menu icons. None of you use flatpak ?, do you have the same problem ?, have you solved it? Thanks in advance for your help.
[img2=]https://ibb.co/JrLRV0r[/img2]
Alexander88207
Re: missing flatpak icons
Post by Alexander88207 » Sat Apr 13, 2019 21:01
Hi @messana,
maybe not the best solution. but what about to open alacarte in the terminal and add the missing icons per hand to that applications?
How to create a sabayon uefi usb device: https://github.com/linuxerus/sabayon-st ... -device.md
messana
Post by messana » Mon Apr 15, 2019 4:12
Hi Alexander88207, thank you so much for your solution. Have a nice day. ;-)
