Sytem totally messsed up after kernel update
denijane
Post by denijane » Tue Dec 04, 2018 14:05
Note: I first posted this at Gentoo's forum, but I'm posting it also here in case anyone has an idea.
After my update to the latest revision for kernel 4.18.19, my laptop loads for 35 minutes. It's extremely slow and after logging in, the first attempts lasted about 5 minutes after log in, ending with a system freeze and once with the message "Warning, system failed to mount to "/" sysroot" (or something like this). Once while restarting I got a glimpse on the text launch screen and there were multiple dbus errors also some processes trying to start for 3-5 minutes.
Also trying to start one of the older kernels I have, I got dropped to a shell with the epic:
dracut: Warning: Failed to mount -t ext4  (blah blah) /dev/mapper/sabayon_sabayon-root /sysroot
Buffer I/0 error on dev sda1
On my last attempt, I did what this link suggested https://forums.gentoo.org/viewtopic-t-1090156.html, i.e. waited 35 minutes for everything to start and then wrote in the konsole:
ln -s /var/run/dbus /run/dbus
systemctl start systemd-logind.service
it helped to the extend that I can work with my laptop now (if I don't restart it), but it occasionally freezes for a minute and one should be really careful not to overload the system (meaning one should work reaally slowly and wait when something freezes).
I tried checking journalctl, dmesg and xorg. There are no obvious errors but for things showing totally weird output (as the long code snipped at the bottom).
The only error I found is this (from Xorg.0.log):
Code:
[   279.488] (EE) [drm] Failed to open DRM device for (null): -2
and in dmesg I have 300 entries of these:
Code:
[   85.552252] idma64 idma64.0: Found Intel integrated DMA 64-bit
[   92.297125] pstore: crypto_comp_decompress failed, ret = -22!
[   92.297127] pstore: decompression failed: -22
[   92.297456] pstore: crypto_comp_decompress failed, ret = -22!
[   92.297457] pstore: decompression failed: -22
[   92.297782] pstore: crypto_comp_decompress failed, ret = -22!
And one entry for:
Code:
[   97.718260] thermal thermal_zone3: failed to read out thermal zone (-61)
Apart from that I don't see obvious errors. If anyone is interested, I can also post my journalctl and dmesg here or somewhere.
Any suggestions as to how to debug this and find out what's wrong with my system will be greatly appreciated.
Code:
journalctl -b| tail -150
дек 04 13:44:19 sabayon.local org_kde_powerdevil[1234]: powerdevil: Can't contact ck
дек 04 13:44:19 sabayon.local org_kde_powerdevil[1234]: powerdevil: Scheduling inhibition from ":1.15" "/usr/bin/google-chrome-stable" with cookie 90 and reason "Playing video"
дек 04 13:44:19 sabayon.local org_kde_powerdevil[1234]: powerdevil: Scheduling inhibition from ":1.196" "/usr/bin/google-chrome-stable" with cookie 91 and reason "Playing video"
дек 04 13:44:24 sabayon.local org_kde_powerdevil[1234]: powerdevil: Enforcing inhibition from ":1.15" "/usr/bin/google-chrome-stable" with cookie 90 and reason "Playing video"
дек 04 13:44:24 sabayon.local org_kde_powerdevil[1234]: powerdevil: Added change screen settings
дек 04 13:44:24 sabayon.local org_kde_powerdevil[1234]: powerdevil: Added interrupt session
дек 04 13:44:24 sabayon.local org_kde_powerdevil[1234]: powerdevil: Disabling DPMS due to inhibition
дек 04 13:44:24 sabayon.local org_kde_powerdevil[1234]: powerdevil: Enforcing inhibition from ":1.196" "/usr/bin/google-chrome-stable" with cookie 91 and reason "Playing video"
дек 04 13:44:24 sabayon.local org_kde_powerdevil[1234]: powerdevil: Can't contact ck
дек 04 13:44:43 sabayon.local plasmashell[1203]: qt.qpa.xcb: QXcbConnection: XCB error: 2 (BadValue), sequence: 48708, resource id: 52428806, major code: 141 (Unknown), minor code: 3
дек 04 13:45:16 sabayon.local plasmashell[1203]: qt.qpa.xcb: QXcbConnection: XCB error: 2 (BadValue), sequence: 49611, resource id: 83886141, major code: 141 (Unknown), minor code: 3
дек 04 13:45:16 sabayon.local plasmashell[1203]: qt.qpa.xcb: QXcbConnection: XCB error: 2 (BadValue), sequence: 49628, resource id: 71303174, major code: 141 (Unknown), minor code: 3
дек 04 13:45:16 sabayon.local plasmashell[1203]: qt.qpa.xcb: QXcbConnection: XCB error: 2 (BadValue), sequence: 49631, resource id: 81788934, major code: 141 (Unknown), minor code: 3
дек 04 13:45:17 sabayon.local plasmashell[1203]: qt.qpa.xcb: QXcbConnection: XCB error: 2 (BadValue), sequence: 49639, resource id: 85983268, major code: 141 (Unknown), minor code: 3
дек 04 13:45:17 sabayon.local plasmashell[1203]: qt.qpa.xcb: QXcbConnection: XCB error: 2 (BadValue), sequence: 49648, resource id: 90177537, major code: 141 (Unknown), minor code: 3
дек 04 13:45:17 sabayon.local plasmashell[1203]: qt.qpa.xcb: QXcbConnection: XCB error: 2 (BadValue), sequence: 49727, resource id: 85983268, major code: 141 (Unknown), minor code: 3
дек 04 13:45:17 sabayon.local plasmashell[1203]: qt.qpa.xcb: QXcbConnection: XCB error: 2 (BadValue), sequence: 49739, resource id: 83886141, major code: 141 (Unknown), minor code: 3
дек 04 13:45:17 sabayon.local plasmashell[1203]: qt.qpa.xcb: QXcbConnection: XCB error: 2 (BadValue), sequence: 49769, resource id: 83886097, major code: 141 (Unknown), minor code: 3
дек 04 13:45:18 sabayon.local plasmashell[1203]: qt.qpa.xcb: QXcbConnection: XCB error: 2 (BadValue), sequence: 49881, resource id: 83886141, major code: 141 (Unknown), minor code: 3
дек 04 13:45:58 sabayon.local org_kde_powerdevil[1234]: powerdevil: Releasing inhibition with cookie  91
дек 04 13:45:58 sabayon.local org_kde_powerdevil[1234]: powerdevil: Releasing inhibition with cookie  90
дек 04 13:45:58 sabayon.local org_kde_powerdevil[1234]: powerdevil: Restoring DPMS features after inhibition release
дек 04 13:45:58 sabayon.local org_kde_powerdevil[1234]: powerdevil: Can't contact ck
дек 04 13:46:07 sabayon.local org_kde_powerdevil[1234]: powerdevil: Scheduling inhibition from ":1.15" "/usr/bin/google-chrome-stable" with cookie 92 and reason "Playing video"
дек 04 13:46:07 sabayon.local org_kde_powerdevil[1234]: powerdevil: Scheduling inhibition from ":1.198" "/usr/bin/google-chrome-stable" with cookie 93 and reason "Playing video"
дек 04 13:46:12 sabayon.local org_kde_powerdevil[1234]: powerdevil: Enforcing inhibition from ":1.15" "/usr/bin/google-chrome-stable" with cookie 92 and reason "Playing video"
дек 04 13:46:12 sabayon.local org_kde_powerdevil[1234]: powerdevil: Added change screen settings
дек 04 13:46:12 sabayon.local org_kde_powerdevil[1234]: powerdevil: Added interrupt session
дек 04 13:46:12 sabayon.local org_kde_powerdevil[1234]: powerdevil: Disabling DPMS due to inhibition
дек 04 13:46:12 sabayon.local org_kde_powerdevil[1234]: powerdevil: Enforcing inhibition from ":1.198" "/usr/bin/google-chrome-stable" with cookie 93 and reason "Playing video"
дек 04 13:46:12 sabayon.local org_kde_powerdevil[1234]: powerdevil: Can't contact ck
дек 04 13:46:26 sabayon.local org_kde_powerdevil[1234]: powerdevil: Releasing inhibition with cookie  93
дек 04 13:46:26 sabayon.local org_kde_powerdevil[1234]: powerdevil: Releasing inhibition with cookie  92
дек 04 13:46:26 sabayon.local org_kde_powerdevil[1234]: powerdevil: Restoring DPMS features after inhibition release
дек 04 13:46:26 sabayon.local org_kde_powerdevil[1234]: powerdevil: Can't contact ck
дек 04 13:46:26 sabayon.local org_kde_powerdevil[1234]: powerdevil: Scheduling inhibition from ":1.15" "/usr/bin/google-chrome-stable" with cookie 94 and reason "Playing video"
дек 04 13:46:26 sabayon.local org_kde_powerdevil[1234]: powerdevil: Scheduling inhibition from ":1.200" "/usr/bin/google-chrome-stable" with cookie 95 and reason "Playing video"
дек 04 13:46:31 sabayon.local org_kde_powerdevil[1234]: powerdevil: Enforcing inhibition from ":1.15" "/usr/bin/google-chrome-stable" with cookie 94 and reason "Playing video"
дек 04 13:46:31 sabayon.local org_kde_powerdevil[1234]: powerdevil: Added change screen settings
дек 04 13:46:31 sabayon.local org_kde_powerdevil[1234]: powerdevil: Added interrupt session
дек 04 13:46:31 sabayon.local org_kde_powerdevil[1234]: powerdevil: Disabling DPMS due to inhibition
дек 04 13:46:31 sabayon.local org_kde_powerdevil[1234]: powerdevil: Enforcing inhibition from ":1.200" "/usr/bin/google-chrome-stable" with cookie 95 and reason "Playing video"
дек 04 13:46:31 sabayon.local org_kde_powerdevil[1234]: powerdevil: Can't contact ck
дек 04 13:47:20 sabayon.local plasmashell[1203]: qt.qpa.xcb: QXcbConnection: XCB error: 2 (BadValue), sequence: 51532, resource id: 83886097, major code: 141 (Unknown), minor code: 3
дек 04 13:47:20 sabayon.local plasmashell[1203]: qt.qpa.xcb: QXcbConnection: XCB error: 2 (BadValue), sequence: 51545, resource id: 81788934, major code: 141 (Unknown), minor code: 3
дек 04 13:47:20 sabayon.local plasmashell[1203]: qt.qpa.xcb: QXcbConnection: XCB error: 2 (BadValue), sequence: 51553, resource id: 71303174, major code: 141 (Unknown), minor code: 3
дек 04 13:47:20 sabayon.local plasmashell[1203]: qt.qpa.xcb: QXcbConnection: XCB error: 2 (BadValue), sequence: 51558, resource id: 12582918, major code: 141 (Unknown), minor code: 3
дек 04 13:47:20 sabayon.local plasmashell[1203]: qt.qpa.xcb: QXcbConnection: XCB error: 2 (BadValue), sequence: 51567, resource id: 83886141, major code: 141 (Unknown), minor code: 3
дек 04 13:47:20 sabayon.local plasmashell[1203]: qt.qpa.xcb: QXcbConnection: XCB error: 2 (BadValue), sequence: 51571, resource id: 83886097, major code: 141 (Unknown), minor code: 3
дек 04 13:47:20 sabayon.local plasmashell[1203]: qt.qpa.xcb: QXcbConnection: XCB error: 2 (BadValue), sequence: 51573, resource id: 65011718, major code: 141 (Unknown), minor code: 3
дек 04 13:47:20 sabayon.local plasmashell[1203]: qt.qpa.xcb: QXcbConnection: XCB error: 2 (BadValue), sequence: 51578, resource id: 56623110, major code: 141 (Unknown), minor code: 3
дек 04 13:47:20 sabayon.local plasmashell[1203]: qt.qpa.xcb: QXcbConnection: XCB error: 2 (BadValue), sequence: 51581, resource id: 54525958, major code: 141 (Unknown), minor code: 3
дек 04 13:47:20 sabayon.local plasmashell[1203]: qt.qpa.xcb: QXcbConnection: XCB error: 2 (BadValue), sequence: 51631, resource id: 52428806, major code: 141 (Unknown), minor code: 3
дек 04 13:47:20 sabayon.local plasmashell[1203]: qt.qpa.xcb: QXcbConnection: XCB error: 2 (BadValue), sequence: 51635, resource id: 65011718, major code: 141 (Unknown), minor code: 3
дек 04 13:47:20 sabayon.local plasmashell[1203]: qt.qpa.xcb: QXcbConnection: XCB error: 2 (BadValue), sequence: 51638, resource id: 58720262, major code: 141 (Unknown), minor code: 3
дек 04 13:47:20 sabayon.local plasmashell[1203]: qt.qpa.xcb: QXcbConnection: XCB error: 2 (BadValue), sequence: 51643, resource id: 56623110, major code: 141 (Unknown), minor code: 3
дек 04 13:47:24 sabayon.local plasmashell[1203]: qt.qpa.xcb: QXcbConnection: XCB error: 2 (BadValue), sequence: 51731, resource id: 54525958, major code: 141 (Unknown), minor code: 3
дек 04 13:47:25 sabayon.local plasmashell[1203]: qt.qpa.xcb: QXcbConnection: XCB error: 2 (BadValue), sequence: 51779, resource id: 52428806, major code: 141 (Unknown), minor code: 3
дек 04 13:47:41 sabayon.local plasmashell[1203]: qt.qpa.xcb: QXcbConnection: XCB error: 2 (BadValue), sequence: 51993, resource id: 54525958, major code: 141 (Unknown), minor code: 3
дек 04 13:47:41 sabayon.local plasmashell[1203]: qt.qpa.xcb: QXcbConnection: XCB error: 2 (BadValue), sequence: 52006, resource id: 65011718, major code: 141 (Unknown), minor code: 3
дек 04 13:47:41 sabayon.local plasmashell[1203]: qt.qpa.xcb: QXcbConnection: XCB error: 2 (BadValue), sequence: 52017, resource id: 58720262, major code: 141 (Unknown), minor code: 3
дек 04 13:47:41 sabayon.local plasmashell[1203]: qt.qpa.xcb: QXcbConnection: XCB error: 2 (BadValue), sequence: 52032, resource id: 65011718, major code: 141 (Unknown), minor code: 3
дек 04 13:47:42 sabayon.local plasmashell[1203]: qt.qpa.xcb: QXcbConnection: XCB error: 2 (BadValue), sequence: 52055, resource id: 83886097, major code: 141 (Unknown), minor code: 3
дек 04 13:47:42 sabayon.local plasmashell[1203]: qt.qpa.xcb: QXcbConnection: XCB error: 2 (BadValue), sequence: 52123, resource id: 71303174, major code: 141 (Unknown), minor code: 3
дек 04 13:47:42 sabayon.local plasmashell[1203]: qt.qpa.xcb: QXcbConnection: XCB error: 2 (BadValue), sequence: 52129, resource id: 12582918, major code: 141 (Unknown), minor code: 3
дек 04 13:47:42 sabayon.local plasmashell[1203]: qt.qpa.xcb: QXcbConnection: XCB error: 2 (BadValue), sequence: 52134, resource id: 83886141, major code: 141 (Unknown), minor code: 3
дек 04 13:47:42 sabayon.local plasmashell[1203]: qt.qpa.xcb: QXcbConnection: XCB error: 2 (BadValue), sequence: 52137, resource id: 83886097, major code: 141 (Unknown), minor code: 3
дек 04 13:47:42 sabayon.local plasmashell[1203]: qt.qpa.xcb: QXcbConnection: XCB error: 2 (BadValue), sequence: 52142, resource id: 65011718, major code: 141 (Unknown), minor code: 3
дек 04 13:47:42 sabayon.local plasmashell[1203]: qt.qpa.xcb: QXcbConnection: XCB error: 2 (BadValue), sequence: 52147, resource id: 56623110, major code: 141 (Unknown), minor code: 3
дек 04 13:47:42 sabayon.local plasmashell[1203]: qt.qpa.xcb: QXcbConnection: XCB error: 2 (BadValue), sequence: 52149, resource id: 54525958, major code: 141 (Unknown), minor code: 3
дек 04 13:47:42 sabayon.local plasmashell[1203]: qt.qpa.xcb: QXcbConnection: XCB error: 2 (BadValue), sequence: 52154, resource id: 52428806, major code: 141 (Unknown), minor code: 3
дек 04 13:47:42 sabayon.local plasmashell[1203]: qt.qpa.xcb: QXcbConnection: XCB error: 2 (BadValue), sequence: 52156, resource id: 50331654, major code: 141 (Unknown), minor code: 3
дек 04 13:47:43 sabayon.local plasmashell[1203]: qt.qpa.xcb: QXcbConnection: XCB error: 2 (BadValue), sequence: 52265, resource id: 48234502, major code: 141 (Unknown), minor code: 3
дек 04 13:47:44 sabayon.local plasmashell[1203]: qt.qpa.xcb: QXcbConnection: XCB error: 2 (BadValue), sequence: 52323, resource id: 37748742, major code: 141 (Unknown), minor code: 3
дек 04 13:48:11 sabayon.local plasmashell[1203]: qt.qpa.xcb: QXcbConnection: XCB error: 2 (BadValue), sequence: 52637, resource id: 46137351, major code: 141 (Unknown), minor code: 3
дек 04 13:48:11 sabayon.local plasmashell[1203]: qt.qpa.xcb: QXcbConnection: XCB error: 2 (BadValue), sequence: 52666, resource id: 58720262, major code: 141 (Unknown), minor code: 3
дек 04 13:48:11 sabayon.local plasmashell[1203]: qt.qpa.xcb: QXcbConnection: XCB error: 2 (BadValue), sequence: 52674, resource id: 56623110, major code: 141 (Unknown), minor code: 3
дек 04 13:48:22 sabayon.local plasmashell[1203]: qt.qpa.xcb: QXcbConnection: XCB error: 2 (BadValue), sequence: 52896, resource id: 54525958, major code: 141 (Unknown), minor code: 3
дек 04 13:48:22 sabayon.local plasmashell[1203]: qt.qpa.xcb: QXcbConnection: XCB error: 2 (BadValue), sequence: 52903, resource id: 37748742, major code: 141 (Unknown), minor code: 3
дек 04 13:48:22 sabayon.local plasmashell[1203]: qt.qpa.xcb: QXcbConnection: XCB error: 2 (BadValue), sequence: 52908, resource id: 46137351, major code: 141 (Unknown), minor code: 3
дек 04 13:48:22 sabayon.local plasmashell[1203]: qt.qpa.xcb: QXcbConnection: XCB error: 2 (BadValue), sequence: 52913, resource id: 48234502, major code: 141 (Unknown), minor code: 3
дек 04 13:48:22 sabayon.local plasmashell[1203]: qt.qpa.xcb: QXcbConnection: XCB error: 2 (BadValue), sequence: 52916, resource id: 50331654, major code: 141 (Unknown), minor code: 3
дек 04 13:48:22 sabayon.local plasmashell[1203]: qt.qpa.xcb: QXcbConnection: XCB error: 2 (BadValue), sequence: 52919, resource id: 52428806, major code: 141 (Unknown), minor code: 3
дек 04 13:49:23 sabayon.local org_kde_powerdevil[1234]: powerdevil: Releasing inhibition with cookie  95
дек 04 13:49:24 sabayon.local org_kde_powerdevil[1234]: powerdevil: Releasing inhibition with cookie  94
дек 04 13:49:24 sabayon.local org_kde_powerdevil[1234]: powerdevil: Restoring DPMS features after inhibition release
дек 04 13:49:24 sabayon.local org_kde_powerdevil[1234]: powerdevil: Can't contact ck
дек 04 13:49:24 sabayon.local org_kde_powerdevil[1234]: powerdevil: Scheduling inhibition from ":1.15" "/usr/bin/google-chrome-stable" with cookie 96 and reason "Playing video"
дек 04 13:49:24 sabayon.local org_kde_powerdevil[1234]: powerdevil: Scheduling inhibition from ":1.202" "/usr/bin/google-chrome-stable" with cookie 97 and reason "Playing video"
дек 04 13:49:29 sabayon.local org_kde_powerdevil[1234]: powerdevil: Enforcing inhibition from ":1.15" "/usr/bin/google-chrome-stable" with cookie 96 and reason "Playing video"
дек 04 13:49:29 sabayon.local org_kde_powerdevil[1234]: powerdevil: Added change screen settings
дек 04 13:49:29 sabayon.local org_kde_powerdevil[1234]: powerdevil: Added interrupt session
дек 04 13:49:29 sabayon.local org_kde_powerdevil[1234]: powerdevil: Disabling DPMS due to inhibition
дек 04 13:49:29 sabayon.local org_kde_powerdevil[1234]: powerdevil: Enforcing inhibition from ":1.202" "/usr/bin/google-chrome-stable" with cookie 97 and reason "Playing video"
дек 04 13:49:29 sabayon.local org_kde_powerdevil[1234]: powerdevil: Can't contact ck
дек 04 13:49:54 sabayon.local org_kde_powerdevil[1234]: powerdevil: Releasing inhibition with cookie  97
дек 04 13:49:54 sabayon.local org_kde_powerdevil[1234]: powerdevil: Releasing inhibition with cookie  96
дек 04 13:49:54 sabayon.local org_kde_powerdevil[1234]: powerdevil: Restoring DPMS features after inhibition release
дек 04 13:49:54 sabayon.local org_kde_powerdevil[1234]: powerdevil: Can't contact ck
дек 04 13:49:54 sabayon.local org_kde_powerdevil[1234]: powerdevil: Scheduling inhibition from ":1.15" "/usr/bin/google-chrome-stable" with cookie 98 and reason "Playing video"
дек 04 13:49:54 sabayon.local org_kde_powerdevil[1234]: powerdevil: Scheduling inhibition from ":1.204" "/usr/bin/google-chrome-stable" with cookie 99 and reason "Playing video"
дек 04 13:49:58 sabayon.local org_kde_powerdevil[1234]: powerdevil: Releasing inhibition with cookie  99
дек 04 13:49:58 sabayon.local org_kde_powerdevil[1234]: powerdevil: It was only scheduled for inhibition but not enforced yet, just discarding it
дек 04 13:49:58 sabayon.local org_kde_powerdevil[1234]: powerdevil: Releasing inhibition with cookie  98
дек 04 13:49:58 sabayon.local org_kde_powerdevil[1234]: powerdevil: Scheduling inhibition from ":1.15" "/usr/bin/google-chrome-stable" with cookie 100 and reason "Playing video"
дек 04 13:49:58 sabayon.local org_kde_powerdevil[1234]: powerdevil: Scheduling inhibition from ":1.206" "/usr/bin/google-chrome-stable" with cookie 101 and reason "Playing video"
дек 04 13:49:59 sabayon.local org_kde_powerdevil[1234]: powerdevil: Enforcing inhibition from ":1.15" "/usr/bin/google-chrome-stable" with cookie 98 and reason "Playing video"
дек 04 13:49:59 sabayon.local org_kde_powerdevil[1234]: powerdevil: By the time we wanted to enforce the inhibition it was already gone; discarding it
дек 04 13:49:59 sabayon.local org_kde_powerdevil[1234]: powerdevil: Enforcing inhibition from ":1.204" "/usr/bin/google-chrome-stable" with cookie 99 and reason "Playing video"
дек 04 13:50:01 sabayon.local org_kde_powerdevil[1234]: powerdevil: Releasing inhibition with cookie  101
дек 04 13:50:01 sabayon.local org_kde_powerdevil[1234]: powerdevil: It was only scheduled for inhibition but not enforced yet, just discarding it
дек 04 13:50:01 sabayon.local org_kde_powerdevil[1234]: powerdevil: Releasing inhibition with cookie  100
дек 04 13:50:01 sabayon.local org_kde_powerdevil[1234]: powerdevil: Scheduling inhibition from ":1.15" "/usr/bin/google-chrome-stable" with cookie 102 and reason "Playing video"
дек 04 13:50:01 sabayon.local org_kde_powerdevil[1234]: powerdevil: Scheduling inhibition from ":1.208" "/usr/bin/google-chrome-stable" with cookie 103 and reason "Playing video"
дек 04 13:50:03 sabayon.local org_kde_powerdevil[1234]: powerdevil: Enforcing inhibition from ":1.15" "/usr/bin/google-chrome-stable" with cookie 100 and reason "Playing video"
дек 04 13:50:03 sabayon.local org_kde_powerdevil[1234]: powerdevil: By the time we wanted to enforce the inhibition it was already gone; discarding it
дек 04 13:50:03 sabayon.local org_kde_powerdevil[1234]: powerdevil: Enforcing inhibition from ":1.206" "/usr/bin/google-chrome-stable" with cookie 101 and reason "Playing video"
дек 04 13:50:04 sabayon.local org_kde_powerdevil[1234]: powerdevil: Releasing inhibition with cookie  103
дек 04 13:50:04 sabayon.local org_kde_powerdevil[1234]: powerdevil: It was only scheduled for inhibition but not enforced yet, just discarding it
дек 04 13:50:04 sabayon.local org_kde_powerdevil[1234]: powerdevil: Releasing inhibition with cookie  102
дек 04 13:50:06 sabayon.local org_kde_powerdevil[1234]: powerdevil: Enforcing inhibition from ":1.15" "/usr/bin/google-chrome-stable" with cookie 102 and reason "Playing video"
дек 04 13:50:06 sabayon.local org_kde_powerdevil[1234]: powerdevil: By the time we wanted to enforce the inhibition it was already gone; discarding it
дек 04 13:50:06 sabayon.local org_kde_powerdevil[1234]: powerdevil: Enforcing inhibition from ":1.208" "/usr/bin/google-chrome-stable" with cookie 103 and reason "Playing video"
дек 04 13:50:06 sabayon.local org_kde_powerdevil[1234]: powerdevil: Releasing inhibition with cookie  85
дек 04 13:50:06 sabayon.local org_kde_powerdevil[1234]: powerdevil: Can't contact ck
дек 04 13:50:09 sabayon.local plasmashell[1203]: qt.qpa.xcb: QXcbConnection: XCB error: 2 (BadValue), sequence: 54273, resource id: 54525958, major code: 141 (Unknown), minor code: 3
дек 04 13:50:09 sabayon.local plasmashell[1203]: qt.qpa.xcb: QXcbConnection: XCB error: 2 (BadValue), sequence: 54286, resource id: 46137351, major code: 141 (Unknown), minor code: 3
дек 04 13:50:09 sabayon.local plasmashell[1203]: qt.qpa.xcb: QXcbConnection: XCB error: 2 (BadValue), sequence: 54296, resource id: 48234502, major code: 141 (Unknown), minor code: 3
дек 04 13:50:20 sabayon.local plasmashell[1203]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationDelegate.qml:113: ReferenceError: appIcon is not defined
дек 04 13:50:25 sabayon.local plasmashell[1203]: qt.qpa.xcb: QXcbConnection: XCB error: 2 (BadValue), sequence: 54739, resource id: 50331654, major code: 141 (Unknown), minor code: 3
дек 04 13:50:25 sabayon.local plasmashell[1203]: qt.qpa.xcb: QXcbConnection: XCB error: 2 (BadValue), sequence: 54836, resource id: 48234502, major code: 141 (Unknown), minor code: 3
дек 04 13:50:26 sabayon.local plasmashell[1203]: qt.qpa.xcb: QXcbConnection: XCB error: 2 (BadValue), sequence: 54959, resource id: 46137351, major code: 141 (Unknown), minor code: 3
denijane
Re: Sytem totally messsed up after kernel update
Post by denijane » Tue Dec 04, 2018 20:44
Additional Info I just posted in the other forum, my system seems to think I have only 1 core and 1 thread available, even though it recognises the i7 CPU. That's very very weird!
Post by joost » Wed Dec 05, 2018 10:52
Have you checked for the /var/run problem?
viewtopic.php?f=86&t=34902&hilit=%2Frun#p182998
