I have two AMD-ATI boards. But only the onboard is in use...
Post by albfneto » Fri Nov 09, 2018 0:33
In one of my comps,i have two video boards, both are AMD-ATI, see:
$ lspci | grep -e VGA -e 3D
01:05.0 VGA compatible controller: Advanced Micro Devices, Inc. [AMD/ATI] RS880 [Radeon HD 4250]
02:00.0 VGA compatible controller: Advanced Micro Devices, Inc. [AMD/ATI] Cedar [Radeon HD 5000/6000/7350/8350 Series]
I'm using the driver free, xf86-video-ati. 3D accel is working, but the system only using my small "onboard" card, slot PCI is 01:05.0
However, my monitor is pluged in my offboard video card...
i want to activate the "major" card, the off board..... the slot PCI is 02:00.0, but this is not activated...
With other Command:
# lspci -k | grep -A 2 -i "VGA"
        Subsystem: ASUSTeK Computer Inc. M5A88-V EVO
        Kernel driver in use: radeon
        Subsystem: XFX Pine Group Inc. Cedar [Radeon HD 5000/6000/7350/8350 Series]
I see that both my boards are using the Driver Radeon (free driver)
when i modify the xorg.conf file to change the board, example, modify this:
Section "Device"
  Identifier "ATI Video"
   driver "radeon"
  I ADDED THIS TO CHANGE THE DEFAULT BOARD :  BusID          "PCI:02:00.0"
  Option     "SwapbuffersWait"       "false"
EndSection
I have no more X...
How to change the ATI board to "Cedar [Radeon HD 5000/6000/7350/8350 Series]" and use the same driver?
