x2go and KDE
msdobrescu
x2go and KDE
Post by msdobrescu » Mon Jun 11, 2018 7:37
I have something broken, probably, in the systems. I try to access remotely a desktop PC from a notebook, both having Sabayon to date.
It worked in the past, but now I see a black screen and a cursor, but nothing happens next, so no KDE session is setup correctly.
I have checked, the x2go database is OK, a session is added there too, the ssh user can login, but I can't find any logs of errors related to this.
What can I do? Is there a different reliable tool for this? pyhoca-gui is not available in the repos...
msdobrescu
Re: x2go and KDE
Post by msdobrescu » Wed Jun 13, 2018 4:45
Hi, I have found the following in the logs:
XSession-x2go: X session started for msdobrescu at Sunday 10 June 2018, 18:31:48 +0300
ERROR: Error querying enabled displays on GPU 0 (Missing Extension).
ERROR: Error querying connected displays on GPU 0 (Missing Extension).
startkde: Starting up...
dbus-update-activation-environment: warning: error sending to systemd: org.freedesktop.DBus.Error.Spawn.ChildExited: Process org.freedesktop.systemd1 exited with status 1
Cannot find 'org.kde.KSplash.setStage' in object /KSplash at org.kde.KSplash
KCrash: Application 'krunner' crashing...
KCrash: Attempting to start /usr/lib64/libexec/drkonqi from kdeinit
Xlib:  extension "XFree86-VidModeExtension" missing on display ":50".
Failure: Module initialization failed
WARNING 0,024355: [-1] oyranos_cmm_lcm2.c:424 lcm2CMMInit()  compile and run time version differ 1642868016 2080
WARNING 0,036236: oyOptions_s[121]="" oyranos_cmm_disp.c:915 oyX1Configs_Modify()
  Could not obtain XCM_X11 target(_xxx) information for :50.0
/usr/bin/oyranos-monitor-daemon: line 2:  8776 Segmentation fault      (core dumped) oyranos-monitor -s --daemon
(uint32 1,)
(bzr-notify:8744): Gtk-WARNING **: Theme parsing error: gtk.css:68:35: The style property GtkButton:child-displacement-x is deprecated and shouldn't be used anymore. It will be removed in a future version
(bzr-notify:8744): Gtk-WARNING **: Theme parsing error: gtk.css:69:35: The style property GtkButton:child-displacement-y is deprecated and shouldn't be used anymore. It will be removed in a future version
(bzr-notify:8744): Gtk-WARNING **: Theme parsing error: gtk.css:73:46: The style property GtkScrolledWindow:scrollbars-within-bevel is deprecated and shouldn't be used anymore. It will be removed in a future version
/usr/lib64/python2.7/site-packages/bzrlib/plugins/gtk/notify.py:19: PyGIWarning: Gtk was imported without specifying a version first. Use gi.require_version('Gtk', '3.0') before import to ensure that the right version gets loaded.
  from gi.repository import Gtk
/usr/lib64/python2.7/site-packages/gi/types.py:283: RuntimeWarning: Mixin class bzrlib.plugins.gtk.ui.ProgressContainerMixin is an old style class, please update this to derive from "object".
  RuntimeWarning)
/usr/bin/bzr-notify:23: PyGIWarning: Notify was imported without specifying a version first. Use gi.require_version('Notify', '0.7') before import to ensure that the right version gets loaded.
  from gi.repository import Notify
warning: File "/lib64/libthread_db-1.0.so" auto-loading has been declined by your `auto-load safe-path' set to "$debugdir:$datadir/auto-load".
warning: Unable to find libthread_db matching inferior's thread library, thread debugging will not be available.
[01mHP Linux Imaging and Printing System (ver. 3.17.10)[0m
[01mSystem Tray Status Service ver. 2.0[0m
Copyright (c) 2001-15 HP Development Company, LP
This software comes with ABSOLUTELY NO WARRANTY.
This is free software, and you are welcome to distribute it
under certain conditions. See COPYING file for more details.
[31;01merror: Unable to lock /home/msdobrescu/.hplip/hp-systray.lock. Is hp-systray already running?[0m
KCrash: Attempting to start /usr/bin/plasmashell from kdeinit
KCrash: Application 'plasmashell' crashing...
(tracker-miner-apps:8795): Tracker-WARNING **: Couldn't properly parse desktop file 'file:///home/msdobrescu/.local/share/applications/org.kde.krusader-2.desktop': 'Invalid key name: Path[$e]'
Unable to start Dr. Konqi
Re-raising signal for core dump handling.
(tracker-miner-apps:8795): Tracker-CRITICAL **:   (Sparql buffer) Error in task 5 (file:///usr/share/applications/ca.desrt.dconf-editor.desktop) of the array-update: UNIQUE constraint failed: nie:DataObject.nie:url
(tracker-miner-apps:8795): Tracker-CRITICAL **: Could not execute sparql: UNIQUE constraint failed: nie:DataObject.nie:url
(tracker-miner-apps:8795): Tracker-CRITICAL **:   (Sparql buffer) Error in task 8 (file:///usr/share/applications/gnome-user-accounts-panel.desktop) of the array-update: UNIQUE constraint failed: nie:DataObject.nie:url
(tracker-miner-apps:8795): Tracker-CRITICAL **:   (Sparql buffer) Error in task 9 (file:///usr/share/applications/gnome-universal-access-panel.desktop) of the array-update: UNIQUE constraint failed: nie:DataObject.nie:url
(tracker-miner-apps:8795): Tracker-CRITICAL **:   (Sparql buffer) Error in task 10 (file:///usr/share/applications/gnome-sound-panel.desktop) of the array-update: UNIQUE constraint failed: nie:DataObject.nie:url
(tracker-miner-apps:8795): Tracker-CRITICAL **:   (Sparql buffer) Error in task 11 (file:///usr/share/applications/gnome-sharing-panel.desktop) of the array-update: UNIQUE constraint failed: nie:DataObject.nie:url
(tracker-miner-apps:8795): Tracker-CRITICAL **:   (Sparql buffer) Error in task 12 (file:///usr/share/applications/gnome-search-panel.desktop) of the array-update: UNIQUE constraint failed: nie:DataObject.nie:url
(tracker-miner-apps:8795): Tracker-CRITICAL **:   (Sparql buffer) Error in task 13 (file:///usr/share/applications/gnome-region-panel.desktop) of the array-update: UNIQUE constraint failed: nie:DataObject.nie:url
(tracker-miner-apps:8795): Tracker-CRITICAL **:   (Sparql buffer) Error in task 14 (file:///usr/share/applications/gnome-privacy-panel.desktop) of the array-update: UNIQUE constraint failed: nie:DataObject.nie:url
(tracker-miner-apps:8795): Tracker-CRITICAL **:   (Sparql buffer) Error in task 15 (file:///usr/share/applications/gnome-printers-panel.desktop) of the array-update: UNIQUE constraint failed: nie:DataObject.nie:url
(tracker-miner-apps:8795): Tracker-CRITICAL **:   (Sparql buffer) Error in task 16 (file:///usr/share/applications/gnome-power-panel.desktop) of the array-update: UNIQUE constraint failed: nie:DataObject.nie:url
(tracker-miner-apps:8795): Tracker-CRITICAL **:   (Sparql buffer) Error in task 17 (file:///usr/share/applications/gnome-online-accounts-panel.desktop) of the array-update: UNIQUE constraint failed: nie:DataObject.nie:url
(tracker-miner-apps:8795): Tracker-CRITICAL **:   (Sparql buffer) Error in task 18 (file:///usr/share/applications/gnome-notifications-panel.desktop) of the array-update: UNIQUE constraint failed: nie:DataObject.nie:url
(tracker-miner-apps:8795): Tracker-CRITICAL **:   (Sparql buffer) Error in task 19 (file:///usr/share/applications/gnome-network-panel.desktop) of the array-update: UNIQUE constraint failed: nie:DataObject.nie:url
(tracker-miner-apps:8795): Tracker-CRITICAL **:   (Sparql buffer) Error in task 20 (file:///usr/share/applications/gnome-mouse-panel.desktop) of the array-update: UNIQUE constraint failed: nie:DataObject.nie:url
(tracker-miner-apps:8795): Tracker-CRITICAL **:   (Sparql buffer) Error in task 21 (file:///usr/share/applications/gnome-keyboard-panel.desktop) of the array-update: UNIQUE constraint failed: nie:DataObject.nie:url
(tracker-miner-apps:8795): Tracker-CRITICAL **:   (Sparql buffer) Error in task 22 (file:///usr/share/applications/gnome-info-panel.desktop) of the array-update: UNIQUE constraint failed: nie:DataObject.nie:url
(tracker-miner-apps:8795): Tracker-CRITICAL **:   (Sparql buffer) Error in task 23 (file:///usr/share/applications/gnome-display-panel.desktop) of the array-update: UNIQUE constraint failed: nie:DataObject.nie:url
(tracker-miner-apps:8795): Tracker-CRITICAL **:   (Sparql buffer) Error in task 24 (file:///usr/share/applications/gnome-datetime-panel.desktop) of the array-update: UNIQUE constraint failed: nie:DataObject.nie:url
(tracker-miner-apps:8795): Tracker-CRITICAL **:   (Sparql buffer) Error in task 25 (file:///usr/share/applications/gnome-control-center.desktop) of the array-update: UNIQUE constraint failed: nie:DataObject.nie:url
(tracker-miner-apps:8795): Tracker-CRITICAL **:   (Sparql buffer) Error in task 26 (file:///usr/share/applications/gnome-color-panel.desktop) of the array-update: UNIQUE constraint failed: nie:DataObject.nie:url
(tracker-miner-apps:8795): Tracker-CRITICAL **:   (Sparql buffer) Error in task 27 (file:///usr/share/applications/gnome-bluetooth-panel.desktop) of the array-update: UNIQUE constraint failed: nie:DataObject.nie:url
(tracker-miner-apps:8795): Tracker-CRITICAL **:   (Sparql buffer) Error in task 28 (file:///usr/share/applications/gnome-background-panel.desktop) of the array-update: UNIQUE constraint failed: nie:DataObject.nie:url
akonadi.collectionattributetable                   OK
akonadi.collectionmimetyperelation                 OK
akonadi.collectionpimitemrelation                  OK
akonadi.collectiontable                            OK
akonadi.flagtable                                  OK
akonadi.mimetypetable                              OK
akonadi.parttable                                  OK
akonadi.parttypetable                              OK
akonadi.pimitemflagrelation                        OK
akonadi.pimitemtable                               OK
akonadi.pimitemtagrelation                         OK
akonadi.relationtable                              OK
akonadi.relationtypetable                          OK
akonadi.resourcetable                              OK
akonadi.schemaversiontable                         OK
akonadi.tagattributetable                          OK
akonadi.tagremoteidresourcerelationtable           OK
akonadi.tagtable                                   OK
akonadi.tagtypetable                               OK
(tracker-miner-apps:8795): Tracker-CRITICAL **:   (Sparql buffer) Error in task 0 (file:///home/msdobrescu/.local/share/applications/wine-extension-ctm.desktop) of the array-update: UNIQUE constraint failed: nie:DataObject.nie:url
(tracker-miner-apps:8795): Tracker-CRITICAL **:   (Sparql buffer) Error in task 1 (file:///home/msdobrescu/.local/share/applications/wine-extension-ctg.desktop) of the array-update: UNIQUE constraint failed: nie:DataObject.nie:url
(tracker-miner-apps:8795): Tracker-CRITICAL **:   (Sparql buffer) Error in task 4 (file:///home/msdobrescu/.local/share/applications/JDownloader%20(M).desktop) of the array-update: UNIQUE constraint failed: nie:DataObject.nie:url
(tracker-miner-apps:8795): Tracker-CRITICAL **:   (Sparql buffer) Error in task 5 (file:///home/msdobrescu/.local/share/applications/wine-extension-ctf.desktop) of the array-update: UNIQUE constraint failed: nie:DataObject.nie:url
(tracker-miner-apps:8795): Tracker-CRITICAL **:   (Sparql buffer) Error in task 0 (file:///home/msdobrescu/.local/share/applications/q4wine/Default/system/WinMergeU.desktop) of the array-update: UNIQUE constraint failed: nie:DataObject.nie:url
(tracker-miner-apps:8795): Tracker-CRITICAL **:   (Sparql buffer) Error in task 1 (file:///home/msdobrescu/.local/share/applications/q4wine/Default/system/Creative%20Cloud.desktop) of the array-update: UNIQUE constraint failed: nie:DataObject.nie:url
(tracker-miner-apps:8795): Tracker-CRITICAL **:   (Sparql buffer) Error in task 2 (file:///home/msdobrescu/.local/share/applications/q4wine/Default/system/ExtendScript%20Toolkit.desktop) of the array-update: UNIQUE constraint failed: nie:DataObject.nie:url
(tracker-miner-apps:8795): Tracker-CRITICAL **:   (Sparql buffer) Error in task 3 (file:///home/msdobrescu/.local/share/applications/q4wine/Default/system/Illustrator%2010.desktop) of the array-update: UNIQUE constraint failed: nie:DataObject.nie:url
(tracker-miner-apps:8795): Tracker-CRITICAL **:   (Sparql buffer) Error in task 4 (file:///home/msdobrescu/.local/share/applications/q4wine/Default/system/CUE_Splitter.desktop) of the array-update: UNIQUE constraint failed: nie:DataObject.nie:url
(tracker-miner-apps:8795): Tracker-CRITICAL **:   (Sparql buffer) Error in task 5 (file:///home/msdobrescu/.local/share/applications/q4wine/Default/system/pidgin-portable.desktop) of the array-update: UNIQUE constraint failed: nie:DataObject.nie:url
(tracker-miner-apps:8795): Tracker-CRITICAL **:   (Sparql buffer) Error in task 6 (file:///home/msdobrescu/.local/share/applications/q4wine/Default/system/WhereIsIt.desktop) of the array-update: UNIQUE constraint failed: nie:DataObject.nie:url
(tracker-miner-apps:8795): Tracker-CRITICAL **:   (Sparql buffer) Error in task 7 (file:///home/msdobrescu/.local/share/applications/q4wine/Default/system/wordpad.desktop) of the array-update: UNIQUE constraint failed: nie:DataObject.nie:url
(tracker-miner-apps:8795): Tracker-CRITICAL **:   (Sparql buffer) Error in task 8 (file:///home/msdobrescu/.local/share/applications/q4wine/Default/system/eject.desktop) of the array-update: UNIQUE constraint failed: nie:DataObject.nie:url
(tracker-miner-apps:8795): Tracker-CRITICAL **:   (Sparql buffer) Error in task 9 (file:///home/msdobrescu/.local/share/applications/q4wine/Default/system/explorer.desktop) of the array-update: UNIQUE constraint failed: nie:DataObject.nie:url
(tracker-miner-apps:8795): Tracker-CRITICAL **:   (Sparql buffer) Error in task 10 (file:///home/msdobrescu/.local/share/applications/q4wine/Default/system/regedit.desktop) of the array-update: UNIQUE constraint failed: nie:DataObject.nie:url
(tracker-miner-apps:8795): Tracker-CRITICAL **:   (Sparql buffer) Error in task 11 (file:///home/msdobrescu/.local/share/applications/q4wine/Default/system/uninstaller.desktop) of the array-update: UNIQUE constraint failed: nie:DataObject.nie:url
(tracker-miner-apps:8795): Tracker-CRITICAL **:   (Sparql buffer) Error in task 12 (file:///home/msdobrescu/.local/share/applications/q4wine/Default/system/console.desktop) of the array-update: UNIQUE constraint failed: nie:DataObject.nie:url
(tracker-miner-apps:8795): Tracker-CRITICAL **:   (Sparql buffer) Error in task 13 (file:///home/msdobrescu/.local/share/applications/q4wine/Default/system/winecfg.desktop) of the array-update: UNIQUE constraint failed: nie:DataObject.nie:url
(tracker-miner-apps:8795): Tracker-CRITICAL **:   (Sparql buffer) Error in task 14 (file:///home/msdobrescu/.local/share/applications/q4wine/Default/system/freac.desktop) of the array-update: UNIQUE constraint failed: nie:DataObject.nie:url
(tracker-miner-apps:8795): Tracker-CRITICAL **:   (Sparql buffer) Error in task 15 (file:///home/msdobrescu/.local/share/applications/wine/Programs/Where%20Is%20It/Uninstall%20WhereIsIt.desktop) of the array-update: UNIQUE constraint failed: nie:DataObject.nie:url
(tracker-miner-apps:8795): Tracker-CRITICAL **:   (Sparql buffer) Error in task 16 (file:///home/msdobrescu/.local/share/applications/wine/Programs/Where%20Is%20It/Description%20API.desktop) of the array-update: UNIQUE constraint failed: nie:DataObject.nie:url
(tracker-miner-apps:8795): Tracker-CRITICAL **:   (Sparql buffer) Error in task 17 (file:///home/msdobrescu/.local/share/applications/wine/Programs/Where%20Is%20It/Frequently%20Asked%20Questions.desktop) of the array-update: UNIQUE constraint failed: nie:DataObject.nie:url
(tracker-miner-apps:8795): Tracker-CRITICAL **:   (Sparql buffer) Error in task 18 (file:///home/msdobrescu/.local/share/applications/wine/Programs/Where%20Is%20It/Release%20Notes.desktop) of the array-update: UNIQUE constraint failed: nie:DataObject.nie:url
(tracker-miner-apps:8795): Tracker-CRITICAL **:   (Sparql buffer) Error in task 19 (file:///home/msdobrescu/.local/share/applications/wine/Programs/Where%20Is%20It/Readme.desktop) of the array-update: UNIQUE constraint failed: nie:DataObject.nie:url
(tracker-miner-apps:8795): Tracker-CRITICAL **:   (Sparql buffer) Error in task 20 (file:///home/msdobrescu/.local/share/applications/wine/Programs/Where%20Is%20It/WhereIsIt%20Help.desktop) of the array-update: UNIQUE constraint failed: nie:DataObject.nie:url
(tracker-miner-apps:8795): Tracker-CRITICAL **:   (Sparql buffer) Error in task 21 (file:///home/msdobrescu/.local/share/applications/wine/Programs/Where%20Is%20It/WhereIsIt.desktop) of the array-update: UNIQUE constraint failed: nie:DataObject.nie:url
(tracker-miner-apps:8795): Tracker-CRITICAL **:   (Sparql buffer) Error in task 1 (file:///home/msdobrescu/.local/share/desktop-directories/wine-Programs-Where%20Is%20It.directory) of the array-update: UNIQUE constraint failed: nie:DataObject.nie:url
KCrash: Application 'drkonqi' crashing...
Here follows a long lst of crashes like:
Then:
tracker-miner-fs:8801): Tracker-CRITICAL **: Could not set mount point in database 'urn:nepomuk:datasource:fd1a5016-1cca-4676-988e-041abcd6883b', GDBus.Error:org.freedesktop.Tracker1.SparqlError.Internal: database is locked (strerror of errno (not necessarily related): Resource temporarily unavailable)
... and again the same crashes repeatedly...
(tracker-miner-fs:8801): Tracker-CRITICAL **: Could not set mount point in database 'urn:nepomuk:datasource:051e8dff-7b73-4298-aaf9-0171dc886706', GDBus.Error:org.freedesktop.Tracker1.SparqlError.Internal: database is locked (strerror of errno (not necessarily related): Resource temporarily unavailable)
...some wine errors, for each wine item, like:
(tracker-miner-apps:8795): Tracker-CRITICAL **:   (Sparql buffer) Error in task 0 (file:///home/msdobrescu/.local/share/applications/q4wine/Default/system/console.desktop) of the array-update: UNIQUE constraint failed: nie:DataObject.nie:url
Also, a crash is reported:
Application: krunner (krunner), signal: Aborted
[KCrash Handler]
#6  0x00007f3d7171f2ac in raise () from /lib64/libc.so.6
#7  0x00007f3d717210f5 in abort () from /lib64/libc.so.6
#8  0x00007f3d71f83c43 in QMessageLogger::fatal(char const*, ...) const () from /usr/lib64/libQt5Core.so.5
#9  0x00007f3d539e7a1a in ?? () from /usr/lib64/qt5/plugins/xcbglintegrations/libqxcb-glx-integration.so
#10 0x00007f3d539e4e56 in ?? () from /usr/lib64/qt5/plugins/xcbglintegrations/libqxcb-glx-integration.so
#11 0x00007f3d5ac5e870 in QXcbIntegration::createPlatformOpenGLContext(QOpenGLContext*) const () from /usr/lib64/libQt5XcbQpa.so.5
#12 0x00007f3d7272bc20 in QOpenGLContext::create() () from /usr/lib64/libQt5Gui.so.5
#13 0x00007f3d539e8236 in ?? () from /usr/lib64/qt5/plugins/xcbglintegrations/libqxcb-glx-integration.so
#14 0x00007f3d539e8891 in ?? () from /usr/lib64/qt5/plugins/xcbglintegrations/libqxcb-glx-integration.so
#15 0x00007f3d750ae8db in QSGRenderLoop::instance() () from /usr/lib64/libQt5Quick.so.5
#16 0x00007f3d75132c0a in QQuickWindowPrivate::init(QQuickWindow*, QQuickRenderControl*) () from /usr/lib64/libQt5Quick.so.5
#17 0x00007f3d75c2b4bb in PlasmaQuick::Dialog::Dialog(QQuickItem*) () from /usr/lib64/libKF5PlasmaQuick.so.5
#18 0x0000560721e6d46a in ?? ()
#19 0x0000560721e6b896 in ?? ()
#20 0x00007f3d7170910d in __libc_start_main () from /lib64/libc.so.6
#21 0x0000560721e6b9ba in _start ()
I've reinstalled x2go, plasma, nvidia drivers, mesa on both computers, but the errors keep to come.
I have no idea what is happening. There are lots of Gnome errors, while I open a KDE session.
I use some Gnome apps, like GParted, but no gnome itself.
What could I do?
msdobrescu
Re: x2go and KDE
Post by msdobrescu » Wed Jun 13, 2018 4:57
For reference, my xorg.conf:
# nvidia-xconfig: X configuration file generated by nvidia-xconfig
# nvidia-xconfig:  version 355.11  ([email protected])  Wed Aug 26 17:15:49 PDT 2015
Section "ServerLayout"
    Identifier     "Main Layout"
    Screen      0  "Screen 0" 0 0
    InputDevice    "Keyboard0" "CoreKeyboard"
    InputDevice    "Mouse0" "CorePointer"
EndSection
Section "Module"
    SubSection     "extmod"
        Option         "omit xfree86-dga"
    EndSubSection
    Load           "i2c"
    Load           "ddc"
    Load           "vbe"
    Load           "dri"
    Load           "glx"
    Load           "synaptics"
EndSection
Section "ServerFlags"
    Option         "AllowMouseOpenFail" "true"
EndSection
Section "InputDevice"
    # generated from default
    Identifier     "Keyboard0"
    Driver         "keyboard"
EndSection
    # generated from data in "/etc/conf.d/gpm"
    Identifier     "Mouse0"
    Driver         "mouse"
    Option         "Protocol"
    Option         "Device" "/dev/input/mice"
    Option         "Emulate3Buttons" "no"
    Option         "ZAxisMapping" "4 5"
EndSection
Section "Monitor"
    Identifier     "Generic Monitor"
    HorizSync       28.0 - 80.0
    VertRefresh     43.0 - 60.0
EndSection
Section "Device"
    #Option "RenderAccel" "on"
    #Option "XAANoOffscreenPixmaps"
    #Option "BusType" "PCI"
    #Option "ColorTiling" "on"
    #Option "EnablePageFlip" "on"
    # UseEvents is causing segmentation faults with
    # NVIDIA 6xxx, 7xxx and >=275.xx.xx drivers
    #Option "UseEvents" "True"
    Identifier     "SabayonVga0"
    Driver         "nvidia"
    BusID          "PCI:2:0:0"
EndSection
Section "Screen"
    Identifier     "Screen 0"
    Device         "SabayonVga0"
    Monitor        "Generic Monitor"
    DefaultDepth    24
    Option         "AddARGBGLXVisuals" "true"
    Option         "RegistryDwords" "EnableBrightnessControl=1"
    Option         "metamodes" "nvidia-auto-select +0+0 { ForceFullCompositionPipeline = On }"
    Option         "LogoPath" "/usr/share/backgrounds/sabayonlinux-nvidia.png"
    SubSection     "Display"
        #Modes		"1024x768" "800x600" "640x480"
        Viewport    0 0
        Depth       8
    EndSubSection
        Viewport    0 0
        Depth       16
    EndSubSection
        Viewport    0 0
        Depth       24
    EndSubSection
EndSection
Section "DRI"
    Mode 0777
EndSection
Weird comments in the first lines, as I have installed nvidia again and I have nvidia-drivers-390.42#4.16.0-sabayon (due to my 560Ti OC that is supported up to this driver), removing the xorg.conf file previously.
There is also an Xresources file:
! basic settings for infinality
Xft.antialias:  1
Xft.autohint:   0
Xft.dpi:        96
Xft.hinting:    1
Xft.hintstyle:  hintfull
Xft.lcdfilter:  lcddefault
Xft.rgba:       rgb
