"Cannot mix incompatible Qt library" since last update [solved]
andreios
Post by andreios » Fri May 11, 2018 9:35
I'm using cinnamon and some KDE apps like Dolphin. When I start Dolphin it shows nothing but:
The process for the file protocol died unexpectedly.
And in the syslogs is this message:
kdeinit5[16683]: Cannot mix incompatible Qt library (version 0x50905) with this library (version 0x50904)
I'm updating weekly.
gentmixer
Re: "Cannot mix incompatible Qt library" since last update
Post by gentmixer » Mon May 14, 2018 0:43
KDE and Cinnamon are incompatible (compiled with different Qt version)... This is not a single package problem but all environment issue, seems to me. Use some manager from Cinnamon. Revert to the previous working version (KDE or Cinnamon) or maybe wait a bit for the upstream flow... File a bug eventually.
andreios
Post by andreios » Mon May 14, 2018 10:35
Why ever, but something updated it self and the problem vanished.
But don't see any problem in using KDE apps in other desktop environments. We all have to do this all the Time.
Image an Linux Mint without working KDE Apps, that would be strange.
gentmixer
Post by gentmixer » Mon May 14, 2018 14:57
So you are happy... The environments consists from many packages (sometimes sets of packages) upgraded usually in a few stages... Sometimes waiting would be a good solution.
