Redshift issue [Solved]
christophe60_fr
Post by christophe60_fr » Sun May 06, 2018 17:10
Hi everyone,
I just installed Sabayon 18.05 amd64 Xfce.
I have a small problem when i run Redshift : a popup displays : "Failed to run Redshift, Trying location provider 'manual', etc..."
I read a lot about it, but without finding a solution.
Does anyone have a one or is it an unresolved bug?
Thanks.
svantoviit
Re: Redshift issue
Post by svantoviit » Mon May 07, 2018 13:19
Redshift + XFCE runs OK here. Seems you have not configured it yet.
Has been already mentioned in the forums: Redshift Won't Start in XFCE
Just create ~/.config/redshift.conf and configure the basics:
[redshift]
location-provider=manual
[manual]
lat=32.7
lon=-117.2
More info: Running redshift under xfce
More on config options: Redshift
christophe60_fr
Re: Redshift issue
Post by christophe60_fr » Mon May 07, 2018 15:15
Well, I don't understand. I already read the post you mentioned and tried to create this configuration file, without ever getting there.
I have just tried again and I have been able to do it now without problem !
I also tried for example to get inspired by the archlinux wiki (https://wiki.archlinux.org/index.php/Re ... o_geoclue2), etc...
Anyway, it works and I thank you. I guess I had to go wrong somewhere..
