Is anybody using Firefox with some Sabayon compatible theme?
msdobrescu
Post by msdobrescu » Sun May 06, 2018 6:57
I use Firefox, under Sabayon 64 bit fully up to date.
Under Sabayon, I have Breeze Dark theme.
Regardless Firefox's stock theme chosen, Default, Dark or Light, I have big issues with readability.
It seems to set default colours in a way that some pages have the same text color as the background, like white over white or blck over dark gray or black.
Also, some extensions seem to have trouble with it, Conex menu, for example, being almost unreadable due to light light grey over white.
Is there some solution to this?
Re: Is anybody using Firefox with some Sabayon compatible th
Post by albfneto » Tue May 08, 2018 18:05
Do You tried change the Theme?
Because I have two Sabayon installations and i changes the theme and/or personas many times, with no problem.
when i choosed a Theme that not visible, ex. because of the colors, simply i changed it again.
msdobrescu
Post by msdobrescu » Tue May 08, 2018 20:50
Yes, I've changed between Dark, Light and Default. No change.
Post by albfneto » Wed May 09, 2018 0:50
Do you tried download and install a new Theme, using the Firefox Add-Ons Manager?
CRTL+SHIFT+A, Add-Ons Manager, "Themes" search download and use a new Firefox Theme or Persona.
msdobrescu
Post by msdobrescu » Wed May 09, 2018 6:41
Hello, yes, I have several supplemental themes.
msdobrescu
Post by msdobrescu » Wed May 09, 2018 9:24
Then, although I have KDE, I also use some GTK-based apps, so GTK settings might apply to Firefox also. Could this be a reason?
msdobrescu
Post by msdobrescu » Sat May 12, 2018 7:08
Hi, testing, proves that GTK theme chosen under KDE Settings is the cause of this.
I use there same theme as in KDE, Breeze-Dark.
Ryuno-Ki
Post by Ryuno-Ki » Thu May 17, 2018 20:36
in my experience this happens most likely because the author of that website set the text color (to black, for example), but not the background-color (which is transparent by default, but appears white on most default settings).
You can easier define user styles (with the Stylish Firefox Addon, for example).
There ought to be a userChrome.css, but it's not guaranteed, that it will be respected in the future.
Best is to write the webmaster an email and attaching a screenshot on how it looks like for you.
(This way I convinced Lea Verou to update her website!).
msdobrescu
Post by msdobrescu » Fri May 18, 2018 17:30
There are also addons having this problem.
