midnight commander: memory access error [partly Solved]
linuxfluesterer
Post by linuxfluesterer » Thu May 03, 2018 19:09
Hallo guys (repo maintainers).
I just upgraded my Sabayon 18.04 Plasma version as date of 02/05/2018. Plasma seems to work, upgraded modules also.
But when I start the midnight commander (mc) I receive an error:
memory access error, crash dump saved
And, I checked, mc was not upgraded, it's still the same version 4.8.20-r1.
So, it must be something else for reason. I don't know, if other programs or parts are effected by this phenomenon.
Anybody here, who can confirm this message? How can I solve this problem? I need mc.
Last edited by linuxfluesterer on Fri May 11, 2018 12:47, edited 2 times in total.
Re: midnight commander: memory access error
Post by joost » Thu May 03, 2018 20:42
I can confirm. Recompiled mc, it is in testing repo now.
linuxfluesterer
Post by linuxfluesterer » Fri May 04, 2018 10:40
joost wrote:I can confirm. Recompiled mc, it is in testing repo now.
Just update my sabayon.repo. No upgrade to be installed, 04/05/2018,10.57 UTC. But however, I reinstalled mc. But the problem is not solved anyway. Same attitude.
Before I posted, there was NO upgrade for mc in big upgrade. So I wonder, how a recompile should solve this memory access problem. I assume, the origin is somewhere else, something like memory management of Linux itself. Am I right?
gentmixer
Post by gentmixer » Fri May 04, 2018 21:11
Hi...
I have installed "mc-4.8.20-r2" from Gentoo and "plasma-18.04" from Sabayon.... No issues...
This problem is related to the incompatibility between old version "mc" and newer system.
Update:
of course "plasma-5.45.0"...
linuxfluesterer
Post by linuxfluesterer » Sat May 05, 2018 19:47
gentmixer wrote:Hi...
So, when is in Sabayon repo, the problem is fixed then?
How can I check, which plasma I have? When I enter:
plasmashel -v
then I receive
plasmashell 5.12.4
gentmixer
Post by gentmixer » Sun May 06, 2018 21:59
Sorry, I mechanically wrote out bad plasma number (repeated after your Sabayon version)... Should be of course "plasma-5.45.0", the newest in Sabayon and Gentoo...
linuxfluesterer
Post by linuxfluesterer » Tue May 08, 2018 10:41
Update: Made an Upgrade this morning. Now mc is of version:
╠  @@ Suche...
╠      @@ Paket: app-misc/mc-4.8.20-r2 Branch: 5, [sabayonlinux.org]
╠          Verfügbar:      Version: 4.8.20-r2 ~ tag: NoTag ~ Version: 0
╠          Installiert:    Version: 4.8.20-r2 ~ tag: NoTag ~ Version: 0
╠          Slot:           0
╠          Homepage:       https://www.midnight-commander.org
╠          Beschreibung:   GNU Midnight Commander is a text
╠                          based file manager
╠          Lizenz:         GPL-3
╠   Schlüsselwörter:  app-misc/mc-4.8.20-r2
╠   Gefunden:         1 Eintrag
Everything fine, mc works with more more error.
Thanks.
linuxfluesterer
Re: midnight commander: memory access error [Solved]
Post by linuxfluesterer » Fri May 11, 2018 12:46
Update: A friend just told me to check mc to work with mouse clicks, which I did now. And he is right, it is not possible to control mc with mouse.
So, mc is opened, ready to use, it is possible to use it with keys, but when using a mouse (e.g. to change a directory or activate a function), there is no reaction but in the lower line under the mc window, there are appearing control codes.
Any idea?
Re: midnight commander: memory access error [partly Solved]
Post by sabayonino » Fri May 11, 2018 16:47
Confirm this.
Told in IRC yesterday.
Upstream bug is open : https://bugs.gentoo.org/654870
Please be patient
