Windows 10 RDP? [Solved]
msdobrescu
Post by msdobrescu » Wed Apr 04, 2018 17:21
I have connected to a Windows 10 for years now, using KRDC.
After reinstalling the Windows machine, I can't connect anymore.
I have disabled the NLA as usual, I can connect to it from Android and Windows 10, but not from my Sabayon - also up-to date.
The behaviour is as follows: KRDC asks for the credentials, opens some blue window for a fraction of a second, then closes it and KRDC displays the connection as done.
What happens and how can I fix this?
Thank you.
Trash Panda
Re: Windows 10 RDP?
Post by Trash Panda » Wed Apr 04, 2018 17:33
hello
RDP support in Remote Desktop Connection depends on xfreerdp (FreeRDP). Make sure that you have installed this runtime dependency.
# equo search freerdp
╠  @@ Recherche...
╠      @@ Paquet: net-misc/freerdp-2.0.0_rc0 branche: 5, [sabayonlinux.org]
╠          Disponible:       version: 2.0.0_rc0 ~ tag: NoTag ~ révision: 0
╠          Installé:         version: Pas installé ~ tag: n/a ~ révision: n/a
╠          entaille:         0
╠          Page d'accueil:   http://www.freerdp.com/
╠          Description:      Free implementation of the Remote
╠                            Desktop Protocol
╠          License:          Apache-2.0
╠   Mots-clé:  freerdp
╠   Trouvé:    1 entry
also check in setting -> configure KRDC make sure you have remember password kwallet
msdobrescu
Re: Windows 10 RDP?
Post by msdobrescu » Wed Apr 04, 2018 18:48
Hello, seems I have run into this.
I have added this and works now for me:
/sec:tls
