Hi all,
I installed veracrypt by a "equo i veracrypt" after a "equo up".
Install is fine, but launching veracrypt result in a segfault. Is anyone having same issue?
Thanks
Veracrypt [Solved]
Veracrypt [Solved]
Re: Veracrypt
app-crypt/veracrypt is not in the repositories. I wonder how you installed it..
//edit: I will add it to the repositories.
Re: Veracrypt
veracrypt is in community repo.
I guess this version (in SCR) is not well compiled.
I install version you added in official repo, work great.
Thanks a lot!
Thanks a lot!
