qtcreator 'type_traits' file not found
linuxfluesterer
Post by linuxfluesterer » Sat Mar 10, 2018 21:54
Hallo guys.
I try to learn (a little) qml with qt creator to finally build a plasmoid. So before using qtcreator I found this kde.org website, where was shown the principle structure of a qm program (app):
https://techbase.kde.org/Development/Tu ... ingStarted
I have Plasma 5.12.1 with qt (5.6, I assume, how to check it?).
When I create all the example files and then change into the directory ".../contents/ui" and start the command:
qmlscene main.qml
then I receive a small app window with "Hello world in Plasma 5".
When I now copy the code of main.qml into the qtcreator window and let it run, then I receive a final error, which is:
!'type_traits' file not found
#  include <type_traits>
/usr/include/qt5/QtCore/qglobal.h
and there is no small window with "Hello world in Plasma 5".
This <type_traits> is called by /usr/include/qt5/QtCore/global.h:
#ifdef __cplusplus
#  include <cstddef>
#  include <utility>
#endif
So, my question is, where is this "type_traits" file in Sabayon repo and why can I execute the same qmlcode with qmlscene main.qml] without errors?
Thank you in advance.
Re: qtcreator 'type_traits' file not found
Post by joost » Sun Mar 11, 2018 10:50
I think you should make sure you have BOTH sys-devel/base-gcc and sys-devel/gcc installed on your system.
linuxfluesterer
Post by linuxfluesterer » Sun Mar 11, 2018 12:15
joost wrote:I think you should make sure you have BOTH sys-devel/base-gcc and sys-devel/gcc installed on your system.
Thank you, Joost. I just installed the missing sys-devel/gcc-6.4.0-r1 package. The other(s) where already installed.
Then I started the qtcreator again, trying to run the simple main.qml with the content:
import QtQuick 2.0
import org.kde.plasma.components 2.0 as PlasmaComponents
PlasmaComponents.Label {
    text: "Hello world in Plasma 5 ";
but instead a proper result, I receive more errors than before:
I have no idea for the (new) errors appearing.
To emphasize: When I simply change into the project directory containingg the simply main.qml and just simply enter:
qmlscene main.qml
then I do not receive any error. I receive a window and after closing this window, the command line prompt is back.
Post by sabayonino » Sun Mar 11, 2018 15:19
a quick check :
$ sudo find /usr/ -name crti*
Password:
/usr/lib32/crti.o
/usr/lib64/crti.o
[email protected] ~ $ equo q belongs /usr/lib32/crti.o
╠  @@ Ricerca Appartenenza
╠      @@ Pacchetto: sys-libs/glibc-2.25-r10 branch: 5, [__system__]
╠          Installato:    versione: 2.25-r10 ~ tag: NoTag ~ revisione: 0
╠          Slot:          2.2
╠          Homepage:      https://www.gnu.org/software/libc/libc.html
╠          Descrizione:   GNU libc6 (also called glibc2)
╠                         C library
╠          Licenza:       BSD HPND ISC LGPL-2.1+ PCRE inner-net rc
╠   Keyword:  /usr/lib32/crti.o
╠   Trovati:  1 voce
linuxfluesterer
Post by linuxfluesterer » Sun Mar 11, 2018 16:38
Thank you again.
I already have installed glibc-2.25-r10 package.
Anyway, when I start to run and build, I receive another error result:
I haven't found much about "lgcc" or "-lgcc" in Google. Could be a missing lib of Android? But why? I just have chosen 'local of type 'Desktop' pc' as my device.
And the locate or find commands don't find anything with lgcc on my system.
Post by Stupot » Mon Mar 12, 2018 16:58
linuxfluesterer
Post by linuxfluesterer » Mon Mar 12, 2018 23:18
Thank you. I'm honest, I found something of Ubuntu to solve this problem before, so, I searched for:
gcc-4.4-multilib
The main point I have with solutions for Ubuntu topics,is, the packages for Ubuntu I often cannot find in Sabayon repo, e.g. gcc-4.4-multilib.
Either the packages don't exist in Sabayon repo or they have another name. I would really like to know, which sub packages (programs, libs and so on) I can find in Sabayon and in which package.
And: btw, is there a simple way to install all components for qtcreator and a complete qt mainline in Sabayon?
Post by sabayonino » Tue Mar 13, 2018 0:18
All packages are build with multilibs support.
/usr/lib64 and /usr/lib32
so no need of "multi-lib" suffix .
GCC Useflags
USE flag:         -altivec -awt -cilk -debug -doc
╠                            -fixed-point -gcj -jit -libssp
╠                            -mpx -pgo -regression-test -vanilla
╠                            abi_x86_64 amd64 big-endian cxx
╠                            elibc_glibc fortran go graphite
╠                            hardened kernel_linux multilib
╠                            nls nptl objc objc++ objc-gc openmp
╠                            pch pie sanitize ssp userland_GNU
╠                            vtv
linuxfluesterer
Post by linuxfluesterer » Tue Mar 13, 2018 20:00
sabayonino wrote:All packages are build with multilibs support.
Thank you, Sabayonino. But finally, the multilib did not solve my problem...
I fear, when solved one error message, then the next one appears. And this for such a very, very little qml source.
Post by Stupot » Thu Mar 15, 2018 3:37
The more I've dug, the more it looks like something might be up with the way it's compiled.
https://bugreports.qt.io/browse/QTCREATORBUG-19260
That's the bug I'm stuck on when I try to create a new project in qt-creator.
