Question - Deptest
kholyphoenix1
Question - Deptest
Post by kholyphoenix1 » Fri Dec 08, 2017 19:02
I'm using an 'equo deptest' command to fix some problems. When I make use of this command it says to me: Packages not found.
How can I solve this?
sabayon linux # equo deptest
╠  @@ Executando teste de dependências...
╠  @@ Estas dependências não foram encontradas:
╠    # ~app-crypt/pinentry-base-0.9.7
╠       # Requisitado por:
╠       # app-crypt/pinentry-qt4-0.9.7-r1
╠    # =dev-lang/perl-5.22*;~perl-core/ExtUtils-Command-1.200.0?
╠       # virtual/perl-ExtUtils-Command-1.200.0
╠    # >=dev-python/six-1.5[python_targets_python2_7,python_targets_python3_4,-python_single_target_python2_7,-python_single_target_python3_3,-python_single_target_python3_4,-python_single_target_pypy]
╠       # dev-python/python-dateutil-2.4.2-r1
╠    # ~app-arch/file-roller-3.20.2
╠       # gnome-extra/nautilus-file-roller-3.20.2
╠    # dev-lang/python:3.4
╠  @@ Instalando pacotes disponíveis em 10 segundos ...
☢ Pacotes não encontrados.
sabayon linux #
Re: Question - Deptest
Post by sabayonino » Sat Dec 09, 2017 1:32
dev-python/python-dateutil-2.4.2-r1 is no longer mantained
Latest version is :
# equo s dev-python/python-dateutil -qv
dev-python/python-dateutil-2.6.1
if you don't need about this package , you can run
# equo upgrade --purge --ask
to remove the packages that are not available on the repositories anymore...
please check twice and make sure you don't really need them
Post by joost » Sun Dec 10, 2017 10:44
First update your Entropy database.
equo update
(If correct Entropy informs you about your old Entropy database)
