VLC keeps crashing
msdobrescu
VLC keeps crashing
Post by msdobrescu » Sat Oct 28, 2017 21:15
Since last update bunch VLC closes/silently crashes when I try to change the current position in the video or to restore the playback time.
Am I the only one with this problem?
What happens, how to fix this, is it a bug?
Regards.
flexoron
Re: VLC keeps crashing
Post by flexoron » Mon Oct 30, 2017 9:31
This is true. VLC keeps crashing.
When started from the GUI(gnome), it just plays one video.mp4 and then crashes.
Different from the behavior you describe, it is possible to change the current position of the video via slider but not via rewind button.
When started in a shell(the same command: # vlc ...) it works fine.
See:
VLC player core dump after this week's weekly-update.
(Software in General, Sep 26, 2017)
msdobrescu
Post by msdobrescu » Mon Oct 30, 2017 9:35
Mine crashes when I change the current position via the slider too, when it resumes the video, when I change the current TV channel.
Post by joost » Mon Oct 30, 2017 12:52
Not here. Without a log nobody is going to be able to help you.
msdobrescu
Post by msdobrescu » Sun Dec 24, 2017 6:30
Still happening and no clue.
It seems to be related to specific codecs, but for some encoding versions crash and for some not.
Don't know what to look for. Any clues?
Post by sabayonino » Sun Dec 24, 2017 10:15
you can try to reset vlc configuration removing vlc configuration. It is stored in ~/.config/vlc folder
$ mv ~/.config/vlc ~/.config/vlc.bak
restart vlc
Mr.Sabyon
Post by Mr.Sabyon » Sun Dec 24, 2017 13:27
Same here. Latest 2 months VLC crashes constantly. Mkv, mp4, iptv streams, its just hang or crash. I cleared all configurations, reinstalled VLC without effect. Im running latest KDE5 with all the updates available. Using nvidia 1050 with official nvidia blob drivers with 4.14.0-sabayon #1 SMP Wed Dec 20 20:56:33 UTC 2017 x86_64.
$ vlc
VLC media player 2.2.8 Weatherwax (revision 2.2.7-14-g3cc1d8cba9)
[000056532d13e148] core libvlc: Spouštím přehrávač VLC s výchozím rozhraním. Přejete-li si spouštět přehrávač VLC bez rozhraní, použijte příkaz 'cvlc'.
kf5.kio.core: KLocalSocket(0x7f31cc606660) Jumbo packet of 40022 bytes
Couldn't load kfileaudiopreview "The shared library was not found."
No accelerated IMDCT transform found
[00007f31a0c0cd98] avcodec decoder: Using NVIDIA VDPAU Driver Shared Library 387.34 Tue Nov 21 02:08:49 PST 2017 for hardware decoding.
[h264 @ 0x7f31a0c376f0] co located POCs unavailable
[h264 @ 0x7f31a0ca7e70] co located POCs unavailable
[h264 @ 0x7f31a0c45d30] Missing reference picture, default is 65878
[h264 @ 0x7f31a0c45d30] co located POCs unavailable
[h264 @ 0x7f31a0c45d30] mmco: unref short failure
QObject::~QObject: Timers cannot be stopped from another thread
Post by sabayonino » Sun Dec 24, 2017 13:47
kfileaudiopreview library --> /usr/lib64/kde4/kfileaudiopreview.so
$ equo q belongs /usr/lib64/kde4/kfileaudiopreview.so -qv
kde-frameworks/kdelibs-4.14.37
or
quo q files kde-frameworks/kdelibs-4.14.37 | grep kfileaudio
╠  ### /usr/lib64/kde4/kfileaudiopreview.so
Try to reinstall kdelibs
# equo i kde-frameworks/kdelibs
Mr.Sabyon
Post by Mr.Sabyon » Sun Dec 24, 2017 14:14
thx for quick reply...do I need restart KDE, after kdelibs reinstall?
msdobrescu
Post by msdobrescu » Sun Dec 24, 2017 16:19
Mine looks like this:
vlc
[0000564100949148] core libvlc: Running vlc with the default interface. Use 'cvlc' to use vlc without interface.
[00007f0f78c5fdd8] avcodec decoder: Using NVIDIA VDPAU Driver Shared Library  387.34  Tue Nov 21 02:08:49 PST 2017 for hardware decoding.
[00007f0f6007a2b8] deinterlace filter error: unsupported chroma VDV0
[00007f0f792fb4a8] avcodec decoder: Using NVIDIA VDPAU Driver Shared Library  387.34  Tue Nov 21 02:08:49 PST 2017 for hardware decoding.
[00007f0f60010d18] deinterlace filter error: unsupported chroma VDV0
[00007f0f6c019da8] avcodec decoder: Using NVIDIA VDPAU Driver Shared Library  387.34  Tue Nov 21 02:08:49 PST 2017 for hardware decoding.
Segmentation fault (core dumped)
