Samba failed (Error NT_STATUS_HOST_UNREACHABLE) [Solved]
nomorelogic
Post by nomorelogic » Mon Feb 20, 2017 15:31
hi all
I've some problems when working with samba.
smbd and nmbd are started but I'm unable to connect with smb server.
e.g. using smbclient, I get this error
# smbclient -L //10.4.4.87
WARNING: Ignoring invalid value 'share' for parameter 'security'
smbclient: Can't load /etc/samba/smb.conf - run testparm to debug it
Enter nomorelogic's password:
Connection to 10.4.4.87 failed (Error NT_STATUS_HOST_UNREACHABLE)
some info:
# netstat -lntu
Active Internet connections (only servers)
Proto Recv-Q Send-Q Local Address           Foreign Address         State
tcp        0      0 0.0.0.0:139             0.0.0.0:*               LISTEN
tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN
tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN
tcp        0      0 0.0.0.0:445             0.0.0.0:*               LISTEN
tcp6       0      0 :::139                  :::*                    LISTEN
tcp6       0      0 :::22                   :::*                    LISTEN
tcp6       0      0 ::1:631                 :::*                    LISTEN
tcp6       0      0 :::445                  :::*                    LISTEN
udp        0      0 0.0.0.0:36639           0.0.0.0:*
udp        0      0 0.0.0.0:5353            0.0.0.0:*
udp        0      0 0.0.0.0:15905           0.0.0.0:*
udp        0      0 0.0.0.0:68              0.0.0.0:*
udp        0      0 10.4.4.255:137          0.0.0.0:*
udp        0      0 10.4.4.87:137           0.0.0.0:*
udp        0      0 0.0.0.0:137             0.0.0.0:*
udp        0      0 10.4.4.255:138          0.0.0.0:*
udp        0      0 10.4.4.87:138           0.0.0.0:*
udp        0      0 0.0.0.0:138             0.0.0.0:*
udp        0      0 0.0.0.0:631             0.0.0.0:*
udp6       0      0 :::35245                :::*
udp6       0      0 :::5353                 :::*
udp6       0      0 :::50213                :::*
and
# netstat --listen|grep samba
unix  2      [ ACC ]     STREAM     LISTENING     14320    /var/run/samba/nmbd/unexpected
my /etc/samba/smb.conf
# cat /etc/samba/smb.conf
# This is the main Samba configuration file. You should read the
# smb.conf(5) manual page in order to understand the options listed
# here. Samba has a huge number of configurable options (perhaps too
# many!) most of which are not shown in this example
# For a step to step guide on installing, configuring and using samba,
# read the Samba-HOWTO-Collection. This may be obtained from:
#  http://www.samba.org/samba/docs/Samba-HOWTO-Collection.pdf
# Many working examples of smb.conf files can be found in the
# Samba-Guide which is generated daily and can be downloaded from:
#  http://www.samba.org/samba/docs/Samba-Guide.pdf
# Any line which starts with a ; (semi-colon) or a # (hash)
# is a comment and is ignored. In this example we will use a #
# for commentry and a ; for parts of the config file that you
# may wish to enable
# NOTE: Whenever you modify this file you should run the command "testparm"
# to check that you have not made any basic syntactic errors.
#======================= Global Settings =====================================
[global]
# workgroup = NT-Domain-Name or Workgroup-Name, eg: MIDEARTH
   workgroup = WORKGROUP
# server string is the equivalent of the NT Description field
   server string = Samba Server
# Server role. Defines in which mode Samba will operate. Possible
# values are "standalone server", "member server", "classic primary
# domain controller", "classic backup domain controller", "active
# directory domain controller".
# Most people will want "standalone sever" or "member server".
# Running as "active directory domain controller" will require first
# running "samba-tool domain provision" to wipe databases and create a
# new domain.
   server role = standalone server
# This option is important for security. It allows you to restrict
# connections to machines which are on your local network. The
# following example restricts access to two C class networks and
# the "loopback" interface. For more examples of the syntax see
# the smb.conf man page
;   hosts allow = 192.168.1. 192.168.2. 127.
# Uncomment this if you want a guest account, you must add this to /etc/passwd
# otherwise the user "nobody" is used
;  guest account = pcguest
# this tells Samba to use a separate log file for each machine
# that connects
   ; log file = /usr/local/samba/var/log.%m
   log file = /var/log/samba/local/log.%m
# Put a capping on the size of the log files (in Kb).
   max log size = 50
# Specifies the Kerberos or Active Directory realm the host is part of
;   realm = MY_REALM
# Backend to store user information in. New installations should
# use either tdbsam or ldapsam. smbpasswd is available for backwards
# compatibility. tdbsam requires no further configuration.
;   passdb backend = tdbsam
# Using the following line enables you to customise your configuration
# on a per machine basis. The %m gets replaced with the netbios name
# of the machine that is connecting.
# Note: Consider carefully the location in the configuration file of
#       this line.  The included file is read at that point.
;   include = /usr/local/samba/lib/smb.conf.%m
# Configure Samba to use multiple interfaces
# If you have multiple network interfaces then you must list them
# here. See the man page for details.
;   interfaces = 192.168.12.2/24 192.168.13.2/24
# Where to store roving profiles (only for Win95 and WinNT)
#        %L substitutes for this servers netbios name, %U is username
#        You must uncomment the [Profiles] share below
;   logon path = \\%L\Profiles\%U
# Windows Internet Name Serving Support Section:
# WINS Support - Tells the NMBD component of Samba to enable it's WINS Server
wins support = yes
# WINS Server - Tells the NMBD components of Samba to be a WINS Client
#	Note: Samba can be either a WINS Server, or a WINS Client, but NOT both
;   wins server = w.x.y.z
# WINS Proxy - Tells Samba to answer name resolution queries on
# behalf of a non WINS capable client, for this to work there must be
# at least one	WINS Server on the network. The default is NO.
;   wins proxy = yes
# DNS Proxy - tells Samba whether or not to try to resolve NetBIOS names
# via DNS nslookups. The default is NO.
   dns proxy = no
# These scripts are used on a domain controller or stand-alone
# machine to add or delete corresponding unix accounts
;  add user script = /usr/sbin/useradd %u
;  add group script = /usr/sbin/groupadd %g
;  add machine script = /usr/sbin/adduser -n -g machines -c Machine -d /dev/null -s /bin/false %u
;  delete user script = /usr/sbin/userdel %u
;  delete user from group script = /usr/sbin/deluser %u %g
;  delete group script = /usr/sbin/groupdel %g
#============================ Share Definitions ==============================
[homes]
   comment = Home Directories
   browseable = no
   writable = yes
# Un-comment the following and create the netlogon directory for Domain Logons
; [netlogon]
;   comment = Network Logon Service
;   path = /usr/local/samba/lib/netlogon
;   guest ok = yes
;   writable = no
;   share modes = no
# Un-comment the following to provide a specific roving profile share
# the default is to use the user's home directory
;[Profiles]
;    path = /usr/local/samba/profiles
;    browseable = no
;    guest ok = yes
# NOTE: If you have a BSD-style print system there is no need to
# specifically define each individual printer
[printers]
   comment = All Printers
   path = /usr/spool/samba
   browseable = no
# Set public = yes to allow user 'guest account' to print
   guest ok = no
   writable = no
   printable = yes
# This one is useful for people to share files
;[tmp]
;   comment = Temporary file space
;   path = /tmp
;   read only = no
;   public = yes
[bridge]
   comment = Condivisa map9
   path = /media/dati/bridge
   public = yes
   valid users = nomorelogic
   writeable = yes
   only guest = yes
   printable = no
# A publicly accessible directory, but read only, except for people in
# the "staff" group
;[public]
;   comment = Public Stuff
;   path = /home/samba
;   public = yes
;   writable = no
;   printable = no
;   write list = @staff
# Other examples.
# A private printer, usable only by fred. Spool data will be placed in fred's
# home directory. Note that fred must have write access to the spool directory,
# wherever it is.
;[fredsprn]
;   comment = Fred's Printer
;   valid users = fred
;   path = /homes/fred
;   printer = freds_printer
;   public = no
;   writable = no
;   printable = yes
# A private directory, usable only by fred. Note that fred requires write
# access to the directory.
;[fredsdir]
;   comment = Fred's Service
;   path = /usr/somewhere/private
;   public = no
;   writable = yes
;   printable = no
# a service which has a different directory for each machine that connects
# this allows you to tailor configurations to incoming machines. You could
# also use the %U option to tailor it by user name.
# The %m gets replaced with the machine name that is connecting.
;[pchome]
;  comment = PC Directories
;  path = /usr/pc/%m
;  public = no
;  writable = yes
# A publicly accessible directory, read/write to all users. Note that all files
# created in the directory by users will be owned by the default user, so
# any user with access can delete any other user's files. Obviously this
# directory must be writable by the default user. Another user could of course
# be specified, in which case all files would be owned by that user instead.
;[public]
;   path = /usr/somewhere/else/public
;   public = yes
;   only guest = yes
;   writable = yes
;   printable = no
# The following two entries demonstrate how to share a directory so that two
# users can place files there that will be owned by the specific users. In this
# setup, the directory should be writable by both users and should have the
# sticky bit set on it to prevent abuse. Obviously this could be extended to
# as many users as required.
;[myshare]
;   comment = Mary's and Fred's stuff
;   path = /usr/somewhere/shared
;   valid users = mary fred
;   public = no
;   writable = yes
;   printable = no
;   create mask = 0765
Edit: added testparm output
# testparm /etc/samba/smb.conf
Load smb config files from /etc/samba/smb.conf
rlimit_max: increasing rlimit_max (1024) to minimum Windows limit (16384)
Processing section "[homes]"
Processing section "[printers]"
Processing section "[bridge]"
Loaded services file OK.
Server role: ROLE_STANDALONE
Press enter to see a dump of your service definitions
# Global parameters
[global]
	max log size = 50
	dns proxy = No
	wins support = Yes
	idmap config * : backend = tdb
[homes]
	read only = No
	browseable = No
[printers]
	printable = Yes
	print ok = Yes
	browseable = No
[bridge]
	read only = No
	guest only = Yes
	guest ok = Yes
Re: Samba failed (Error NT_STATUS_HOST_UNREACHABLE)
Post by Fitzcarraldo » Thu Feb 23, 2017 16:59
Have you turned your firewall off to check if that is the cause?
If you are using Samba on a home network and it has around 15 or less devices, you don't need to use WINS at all; broadcast NetBIOS name resolution works fine on a home network: A correct method of configuring Samba for browsing SMB shares in a home network
nomorelogic
Post by nomorelogic » Thu Feb 23, 2017 18:41
about firewall: It's a fresh installed sabayon with kde, I never enabled a firewall, how I can check if firewall is on? :oops:
I'll read your link for home share.
thanks
nomorelogic
Post by joost » Thu Feb 23, 2017 18:59
systemctl stop firewalld
nomorelogic
Post by nomorelogic » Thu Feb 23, 2017 19:22
my fault, it was the firewall ...
thank you all
nomorelogic
