Tox.im client
notzippy
Tox.im client
Post by notzippy » Tue Jan 27, 2015 18:37
Hi
Anyone using https://tox.im/ ? What clients are you using ?
There is a gentoo overlay for utox https://wiki.tox.im/UTox#Gentoo , although the precompilied binary for uTox seems to work as well (although the I am not sure if noise cancellation is working). There is also qTox which I haven't been able to get working, it requires QT5 to compile..
If you are using tox.im, which clients are you using ?
Nz
shade304
Re: Tox.im client
Post by shade304 » Fri Jan 30, 2015 2:18
I tried, but I couldn't get a response from my friend, so I figured it wasn't working..
BobStockdale
Re: Tox.im client
Post by BobStockdale » Wed Feb 21, 2018 21:08
I installed uTox and do not care for it. I had been using qTox on Calculate Linux and like it very much. However, Calculate got trashed during an upgrade on my laptop. I've been trying to get qTox installed on Sabayon through git to no avail. I installed QT5 through there website download. The issue I currently have is that it can't find toxcore even though it is installed. The scripts actually finds it and performs several operations with it and then can't find it later. I sure wish there was an ebuild for qTox.
Re: Tox.im client
Post by sabayonino » Wed Feb 21, 2018 21:24
Portage :
* net-im/qtox
     Available versions:  (~)1.8.1 (~)1.11.0 **9999 {X gtk test}
     Homepage:            https://github.com/qTox/qTox
     Description:         Most feature-rich GUI for net-libs/tox using Qt5
Cheers
