wrl/vrml
fbaggins
wrl/vrml
Post by fbaggins » Mon Jul 14, 2014 23:37
I'm trying to run view3dscene, but it needs libgdkglext-x11-1.0.so.0. This doesn't appear to be installed or in the repository's.
Does Sabayon have a vrml viewer? I can't find one using Rigo
Re: wrl/vrml
Post by albfneto » Tue Jul 15, 2014 23:06
your package ligdk is installed?
fbaggins
Re: wrl/vrml
Post by fbaggins » Wed Jul 16, 2014 0:00
Thanks for the reply, but no package by that name, or libgdk.
howard
Re: wrl/vrml
Post by Stupot » Wed Jul 16, 2014 17:00
Install gtkglext.
Fyi, you can find out this information from an equo search (which escapes my mind at the moment and I'm not home).
You can also find it by searching packages.sabayon.org.
https://packages.sabayon.org/quicksearc ... .0&x=0&y=0
Note the "Special searches" under the search box. Searching with the term "sop:libgdkglext-x11-1.0.so.0" tells it return the package that includes/provides that library.
fbaggins
Re: wrl/vrml
Post by fbaggins » Wed Jul 16, 2014 17:54
Thanks Stupot, that info will come in handy
Howard
