Webmin [Solved]
Webmin [Solved]
Postby B3rtm3n » Thu Apr 24, 2014 15:20
I am unable to use webmin since systemd got implemented in Sabayon.
I would like to know if anyone got webmin running because I tried everying and nothing works:
# /etc/init.d/webmin start|stop|restart
bash: stop: command not found
bash: restart: command not found
 * WARNING: webmin is already starting
# rc-update add webmin default
 * rc-update: webmin already installed in runlevel `default'; skipping
# /etc/init.d/webmin stop
 * ERROR: webmin stopped by something else
# /etc/init.d/webmin restart
# /etc/init.d/webmin status
 * You are attempting to run an openrc service on a
 * system which openrc did not boot.
 * You may be inside a chroot or you may have used
 * another initialization system to boot this system.
 * In this situation, you will get unpredictable results!
 * If you really want to do this, issue the following command:
 * touch /run/openrc/softlevel
B3rtm3n
Re: Webmin
Postby Stupot » Thu Apr 24, 2014 20:12
/etc/init.d/ was the OpenRC way of starting things. You aren't running OpenRC. It told you in that message:
Try the systemd way:
systemctl start webmin.service
To get it run on boot:
systemctl enable webmin.service
Re: Webmin
Postby B3rtm3n » Thu Apr 24, 2014 21:07
Thanks for your help!
However when I do:
I get the message:
Failed to issue method call: Unit webmin.service failed to load: No such file or directory.
B3rtm3n
Re: Webmin
Postby sabayonino » Fri Apr 25, 2014 0:09
webmin doesn't provide any .service for systemd but you can try this :
https://forums.gentoo.org/viewtopic-p-7479434.html
hope it helps you
Re: Webmin
Postby Stupot » Fri Apr 25, 2014 0:26
A bug should filed on bugs.gentoo.org to have that included. You could file a bug here and it would make it's way upstream as well.
But in the meantime, follow the post above and use that. Should be simple enough.
Re: Webmin
Postby B3rtm3n » Fri Apr 25, 2014 17:13
Thanks, I already found that thread before posting but did not understood what to do at the time.
You have to place a textfile called webmin.service in /etc/systemd/system/ with the text:
[Unit]
Description=Webmin Admin Tool
Requires=local-fs.target
After=basic.target
Before=smartd.service
DefaultDependencies=no
Conflicts=shutdown.target
[Service]
Type=oneshot
ExecStart=/usr/libexec/webmin/miniserv.pl /etc/webmin/miniserv.conf
RemainAfterExit=yes
PrivateTmp=true
[Install]
WantedBy=multi-user.target
and as sudo
A bug report was filed at bugs.sabayon on 24/8/2013 and I have waited since but this solved the issue indeed
B3rtm3n
