intelij idea
intelij idea
Postby roelof » Thu Apr 24, 2014 13:56
For study I need the intelij idea.
Can someone make this happen or can I better download the tarball and install it myself.
Roelof
roelof
Re: intelij idea
Postby Stupot » Thu Apr 24, 2014 20:16
It would be much better to install it via a portage overlay than installing the tarball yourself:
http://gpo.zugaina.org/dev-util/idea
Re: intelij idea
Postby roelof » Thu Apr 24, 2014 20:48
Oke,
and how do I do this ?
Roelof
roelof
Re: intelij idea
Postby Stupot » Fri Apr 25, 2014 0:37
Re: intelij idea
Postby roelof » Fri Apr 25, 2014 20:54
I thought mixing up portage and equo is bad.
Roelof
roelof
Re: intelij idea
Postby roelof » Sat Apr 26, 2014 9:04
I did all the steps but see this output:
- dev-util/idea-13.1.1.135.480::fw-overlay (masked by: corruption)
- dev-util/idea-13.1.0.135.475::fw-overlay (masked by: corruption)
- dev-util/idea-13.0.2.133.696::fw-overlay (masked by: corruption)
- dev-util/idea-13.0.1.133.331::fw-overlay (masked by: corruption)
- dev-util/idea-13.0.0.133.193::fw-overlay (masked by: corruption)
- dev-util/idea-12.1.6.129.1359::fw-overlay (masked by: corruption)
- dev-util/idea-12.1.5.129.1328::fw-overlay (masked by: corruption)
- dev-util/idea-12.1.4.129.713::fw-overlay (masked by: corruption)
- dev-util/idea-12.1.3.129.451::fw-overlay (masked by: corruption)
- dev-util/idea-12.1.2.129.354::fw-overlay (masked by: corruption)
- dev-util/idea-12.1.1.129.239::fw-overlay (masked by: corruption)
- dev-util/idea-12.1.0.129.161::fw-overlay (masked by: corruption)
- dev-util/idea-12.0.4.123.169::fw-overlay (masked by: corruption)
- dev-util/idea-12.0.3.123.155::fw-overlay (masked by: corruption)
- dev-util/idea-12.0.2.123.123::fw-overlay (masked by: corruption)
- dev-util/idea-12.0.1.123.94::fw-overlay (masked by: corruption)
- dev-util/idea-12.0.0.123.72::fw-overlay (masked by: corruption)
- dev-util/idea-11.1.5.117.1037::fw-overlay (masked by: corruption)
- dev-util/idea-11.1.4.117.963::fw-overlay (masked by: corruption)
- dev-util/idea-10.5.4.107.777::fw-overlay (masked by: corruption)
Roelof
roelof
Re: intelij idea
Postby svantoviit » Sat Apr 26, 2014 15:04
The ebuild from fw-overlay installs just fine using a local overlay.
# ebuild idea-13.1.1.135.480.ebuild manifest
>>> Downloading 'http://download.jetbrains.com/idea/ideaIU-13.1.1.tar.gz'
--2014-04-26 15:14:50--  http://download.jetbrains.com/idea/ideaIU-13.1.1.tar.gz
Resolving download.jetbrains.com... 54.217.236.18
Connecting to download.jetbrains.com|54.217.236.18|:80... connected.
HTTP request sent, awaiting response... 302 Moved Temporarily
Location: http://download-cf.jetbrains.com/idea/ideaIU-13.1.1.tar.gz [following]
--2014-04-26 15:14:50--  http://download-cf.jetbrains.com/idea/ideaIU-13.1.1.tar.gz
Resolving download-cf.jetbrains.com... 54.230.45.209, 54.230.46.66, 54.230.45.235, ...
Connecting to download-cf.jetbrains.com|54.230.45.209|:80... connected.
HTTP request sent, awaiting response... 200 OK
Length: 278124714 (265M) [application/x-tar]
Saving to: ‘/usr/portage/distfiles/ideaIU-13.1.1.tar.gz’
100%[======================================>] 278,124,714 3.83MB/s   in 2m 10s
2014-04-26 15:17:00 (2.04 MB/s) - ‘/usr/portage/distfiles/ideaIU-13.1.1.tar.gz’ saved [278124714/278124714]
>>> Creating Manifest for /usr/local/portage/dev-util/idea
# emerge -1a idea
[ebuild  N     ] dev-util/idea-13.1.1.135.480
Would you like to merge these packages? [Yes/No] y
>>> Verifying ebuild manifests
>>> Emerging (1 of 1) dev-util/idea-13.1.1.135.480 from local
 * ideaIU-13.1.1.tar.gz SHA256 SHA512 WHIRLPOOL size ;-) ...             [ ok ]
>>> Unpacking source...
>>> Unpacking ideaIU-13.1.1.tar.gz to /var/tmp/portage/dev-util/idea-13.1.1.135.480/work
>>> Source unpacked in /var/tmp/portage/dev-util/idea-13.1.1.135.480/work
>>> Preparing source in /var/tmp/portage/dev-util/idea-13.1.1.135.480/work/idea-IU-135.480 ...
 * Applying idea-13.sh.patch ...                                         [ ok ]
>>> Source prepared.
>>> Configuring source in /var/tmp/portage/dev-util/idea-13.1.1.135.480/work/idea-IU-135.480 ...
>>> Source configured.
>>> Compiling source in /var/tmp/portage/dev-util/idea-13.1.1.135.480/work/idea-IU-135.480 ...
>>> Source compiled.
>>> Test phase [not enabled]: dev-util/idea-13.1.1.135.480
>>> Install idea-13.1.1.135.480 into /var/tmp/portage/dev-util/idea-13.1.1.135.480/image/ category dev-util
>>> Completed installing idea-13.1.1.135.480 into /var/tmp/portage/dev-util/idea-13.1.1.135.480/image/
>>> Installing (1 of 1) dev-util/idea-13.1.1.135.480
>>> Auto-cleaning packages...
>>> No outdated packages were found on your system.
 * GNU info directory index is up-to-date.
Even installing the latest version idea-13.1.2.135.690 just by renaming the ebuild works.
You should start to mess with portage first when you understand what you are doing: recommend you to start with the Sabayon Portage Guide.
svantoviit
Re: intelij idea
Postby roelof » Sat Apr 26, 2014 17:39
I understand exactly what im doing.
I followed the tutorial how to enable a overlay and saw this error message.
Why should I learn portage first when I want to use equo.
This sort of answers make my go away from a distro.
Roelof
roelof
Re: intelij idea
Postby svantoviit » Sat Apr 26, 2014 19:44
roelof wrote:I followed the tutorial…
Seems you made something wrong. But you don't provide enough info to spot your error. I can only say it works here.
What I did to install dev-util/idea:
0. Synced portage and overlays
1. Created a local overlay
2. Downloaded the ebuild and patch-files from the fw-overlay
3. Put them into appropriate places
[3a. Optional: Renamed the ebuild to reflect the latest version - 13.1.2.135.690]
4. Created manifest
5. Emerged (without any errors)
roelof wrote:…I want to use equo.
Make a package request then.
roelof wrote:This sort of answers make my go away from a distro.
Don't feel obliged to use Sabayon…
roelof wrote:Why should I learn…?
If you don't want to learn new things, are you definitely on the wrong place!
svantoviit
