KDE and other Login broken after last update
Douglas_E_Knapp
Post by Douglas_E_Knapp » Thu Apr 24, 2014 13:50
I can't log into KDE. If I give my name and password it logs into X but as best I can tell only X. There are no programs, just a little console "window" in the top left of my screen.
Also the sign in to KDE has changed. It now has a list on the left of process and users and then on the right is a sort of normal looking sign in but with a little analog clock there.
I have no idea what to do next to fix this. I am a bit of a newbie but not a totally newbie newbie. :-)
Thanks!
PS I am on the system now from the install DVD from a few years ago.
tollgate
Re: KDE and other Login broken after last update
Post by tollgate » Thu Apr 24, 2014 14:11
Have you updated to systemd?
In the console type as root
eselect init list
And report back here.
Douglas_E_Knapp
Post by Douglas_E_Knapp » Thu Apr 24, 2014 18:56
Here is the rather strange answer.
Can't load module INIT
Exiting
eor2004
Post by eor2004 » Thu Apr 24, 2014 19:11
My system is not having any booting issues, but when I tried to run the command: "eselect init list" I have received the same error message like you: "!!! Error: Can't load module init exiting" and like I said my Sabayon is booting fine!
Sabayon Linux MATE 64-bit
Gigabyte G41M-ES2L-->2gb ram
Intel Pentium Dual Core 2.60ghz-->E5300
WD-6400AAKS-Caviar-SE16-640gb-->XFS filesystem
Post by Stupot » Thu Apr 24, 2014 20:09
I'm pretty sure it went away when openrc support was dropped.
eor2004
Post by eor2004 » Fri Apr 25, 2014 2:52
Stupot wrote:I'm pretty sure it went away when openrc support was dropped.
tollgate
Post by tollgate » Fri Apr 25, 2014 3:01
Douglas_E_Knapp wrote:Here is the rather strange answer.
Exiting
Sounds like you are using systemd.
Can you try as root:
systemctl status kdm
Douglas_E_Knapp
Post by Douglas_E_Knapp » Sat Apr 26, 2014 15:32
Exiting
Sorry that took so long. I tried it and it says that it is running and that it is ok.
Next idea?
tollgate
Post by tollgate » Sun Apr 27, 2014 5:41
Sounds like it might be a display driver problem.
What do you get if as root you type
eselect opengl list
illalien
Post by illalien » Sun Apr 27, 2014 8:25
I had this exact behaviour a while back, something didn't work with the transition to systemd.
The command:
systemctl enable kdm.service
Solved my problem.
(Actually getting to that command involved reading and learning about systemd)
