Firefox make my system very sluggish! [Solved]
Postby eor2004 » Thu Apr 24, 2014 3:09
I'm using Sabayon Mate 64 fully updated.
The issue with Firefox is that whenever I open a new tab and try to go to a new webpage, the system gets very sluggish, the PC led light for disk activity goes crazy, blinking like if the hard disk where doing some intensive work, the cpu goes 100%, the swap goes 100% too, all this last from 3 to 5 minutes, then like I said, after 3 or 5 minutes the system gets normal again!
Does anyone using sabayon and firefox have experienced something like this?
Sabayon Linux MATE 64-bit
Gigabyte G41M-ES2L-->2gb ram
Intel Pentium Dual Core 2.60ghz-->E5300
WD-6400AAKS-Caviar-SE16-640gb-->XFS filesystem
eor2004
Re: Firefox make my system very sluggish!
Postby eor2004 » Tue Apr 29, 2014 18:24
Here's a video I made using recordmydesktop showing the problem, please download if you want more clear video!
https://www.dropbox.com/s/7gfbso936i7ua ... %202-2.ogv
eor2004
Postby Fitzcarraldo » Wed Apr 30, 2014 12:46
Try starting Firefox in Safe Mode to see if one of the Add-ons is causing the problem.
Re: Firefox make my system very sluggish! [Solved]
Postby Fitzcarraldo » Wed Apr 30, 2014 17:06
You've marked the thread as solved. Which Add-on was it?
Postby eor2004 » Wed Apr 30, 2014 17:08
@ Fitzcarraldo: Thank you Fitz, disabling Adblock Plus 2.5.1 solved the problem, apparently Adblock Plus was the culprit, I never tought ABP could make my Firefox unstable, Than you again man! :salut:
eor2004
