problem installing VirtualBox following Sab.'s wiki [Solved]
vienswuer
Post by vienswuer » Fri Apr 18, 2014 10:38
I followed this wiki: https://wiki.sabayon.org/index.php?titl ... Virtualbox in order to install VirtualBox, but when I reach the step where I have to do "# modprobe vboxdrv" in terminal, I receive this message: "modprobe: ERROR: could not insert 'vboxdrv': Exec format error". How can I fix this? Thks in advance. I am running Sabayon 14.01, 64-bits.
vienswuer
Re: problem installing VirtualBox following Sabayon's wiki
Post by vienswuer » Fri Apr 18, 2014 23:44
The solution was easier than I'd have thought. I complete upgraded Sabayon, via Rigo Application Browser. After that, I did not have any trouble with these commands:
# modprobe vboxdrv
# modprobe vboxnetadp
# modprobe vboxnetflt
and could successfuly install VBox.
So, to summarize, before following sabayon's wiki on VirtualBox setup, do upgrade. At least it worked for me.
eor2004
Re: problem installing VirtualBox following Sab.'s wiki [Sol
Post by eor2004 » Sat Apr 19, 2014 0:33
On your first install always follow the instructions here before doing anything else on your first install of Sabayon:
https://wiki.sabayon.org/index.php?titl ... t_to_do.3F
https://wiki.sabayon.org/index.php?title=Entropy#Fresh_Install_-_What_to_do.3F
Sabayon Linux MATE 64-bit
Gigabyte G41M-ES2L-->2gb ram
Intel Pentium Dual Core 2.60ghz-->E5300
WD-6400AAKS-Caviar-SE16-640gb-->XFS filesystem
