install eclipse and flashplayer on sabayon
kalgan
Post by kalgan » Thu Mar 27, 2014 20:17
Hy guys!sorry for my bad english...
i have a problem with the installation of the IDE eclipse....if i write on my therminal "equo install eclipse",this package is not found....sabayon's therminal advise me to install other package,for example eclipse-ecj:4.2.i think that this package is the 4.2 release of eclipse.but if i install it i can't to perform this software...what's i wrong?
i'm not able to install flashplugin-nonfree....how i do it?
Re: install eclipse and flashplayer on sabayon
Post by sabayonino » Thu Mar 27, 2014 21:30
search package name with :
All "eclipse"
# equo s eclipse
╠  @@ Cercando...
╠      @@ Pacchetto: dev-java/ant-eclipse-ecj-3.3.0-r1 branch: 5, [sabayon-weekly]
╠          Disponibile:   versione: 3.3.0-r1 ~ tag: NoTag ~ revisione: 1
╠          Installato:    versione: Non installato ~ tag: n/d ~ revisione: n/d
╠          Slot:          3.3
╠          Homepage:      http://www.eclipse.org/
╠          Descrizione:   Ant Compiler Adapter for Eclipse
╠                         Java Compiler
╠          Licenza:       EPL-1.0
╠      @@ Pacchetto: dev-java/ant-eclipse-ecj-3.4 branch: 5, [sabayon-weekly]
╠          Disponibile:   versione: 3.4 ~ tag: NoTag ~ revisione: 0
╠          Slot:          3.4
╠                         Java Compiler
╠          Licenza:       EPL-1.0
╠      @@ Pacchetto: dev-java/ant-eclipse-ecj-3.5.2 branch: 5, [sabayon-weekly]
╠          Disponibile:   versione: 3.5.2 ~ tag: NoTag ~ revisione: 0
╠          Slot:          3.5
╠                         Java Compiler
╠          Licenza:       EPL-1.0
╠      @@ Pacchetto: dev-java/ant-eclipse-ecj-3.6-r1 branch: 5, [sabayon-weekly]
╠          Disponibile:   versione: 3.6-r1 ~ tag: NoTag ~ revisione: 0
╠          Slot:          3.6
╠                         Java Compiler
╠          Licenza:       EPL-1.0
╠      @@ Pacchetto: dev-java/ant-eclipse-ecj-3.7.2 branch: 5, [sabayon-weekly]
╠          Disponibile:   versione: 3.7.2 ~ tag: NoTag ~ revisione: 0
╠          Slot:          3.7
╠                         Java Compiler
╠          Licenza:       EPL-1.0
╠      @@ Pacchetto: dev-java/ant-eclipse-ecj-4.2.1 branch: 5, [sabayon-weekly]
╠          Disponibile:   versione: 4.2.1 ~ tag: NoTag ~ revisione: 0
╠          Slot:          4.2
╠                         Java Compiler
╠          Licenza:       EPL-1.0
╠      @@ Pacchetto: dev-java/eclipse-ecj-3.3.0-r4 branch: 5, [sabayon-weekly]
╠          Disponibile:   versione: 3.3.0-r4 ~ tag: NoTag ~ revisione: 0
╠          Slot:          3.3
╠          Descrizione:   Eclipse Compiler for Java
╠          Licenza:       EPL-1.0
╠      @@ Pacchetto: dev-java/eclipse-ecj-3.4-r5 branch: 5, [sabayon-weekly]
╠          Disponibile:   versione: 3.4-r5 ~ tag: NoTag ~ revisione: 0
╠          Slot:          3.4
╠          Licenza:       EPL-1.0
╠      @@ Pacchetto: dev-java/eclipse-ecj-3.5.2-r1 branch: 5, [sabayon-weekly]
╠          Disponibile:   versione: 3.5.2-r1 ~ tag: NoTag ~ revisione: 0
╠          Slot:          3.5
╠          Licenza:       EPL-1.0
╠      @@ Pacchetto: dev-java/eclipse-ecj-3.6-r1 branch: 5, [sabayon-weekly]
╠          Slot:          3.6
╠          Licenza:       EPL-1.0
╠      @@ Pacchetto: dev-java/eclipse-ecj-3.7.2-r1 branch: 5, [sabayon-weekly]
╠          Disponibile:   versione: 3.7.2-r1 ~ tag: NoTag ~ revisione: 0
╠          Slot:          3.7
╠          Licenza:       EPL-1.0
╠      @@ Pacchetto: dev-java/eclipse-ecj-4.2.1 branch: 5, [sabayon-weekly]
╠          Slot:          4.2
╠          Licenza:       EPL-1.0
╠      @@ Pacchetto: games-fps/redeclipse-1.4 branch: 5, [sabayon-weekly]
╠          Disponibile:   versione: 1.4 ~ tag: NoTag ~ revisione: 0
╠          Slot:          0
╠          Homepage:      http://www.redeclipse.net/
╠          Descrizione:   First-person ego-shooter, built
╠                         as a total conversion of Cube Engine
╠                         2
╠          Licenza:       CC-BY-SA-3.0 HPND ZLIB
╠   Keyword:  eclipse
╠   Trovati:  13 voci
All "eclipse" installed
# equo s --installed eclipse
All "eclipse" available
# equo s --available eclipse
please see "equo --help" command and its options
#  equo -h
every "sub command/option" has its "help"
# equo query -h
Example for "equo query -h"
equo query -h
usage: equo query [-h] [--verbose] [--quiet]
                  {belongs,changelog,revdeps,description,files,installed,license,list,mimetype,associate,needed,orphans,required,sets,slot,tags,revisions,graph,revgraph,updates}
strumenti di interrogazione della repository
optional arguments:
  -h, --help            show this help message and exit
  --verbose, -v         output verbose
  --quiet, -q           output silenzioso
action:
                        Comandi disponibili
    belongs             risolvi il pacchetto a cui un file appartiene
    changelog           mostra il changelog del pacchetto
    revdeps             mostra le dipendenze inverse del pacchetto
    description         cerca pacchetto dalla descrizione
    files               mostra file di proprietà del pacchetto
    installed           cerca pacchetti installati
    license             mostra i pacchetti che usano la licenza indicata
    list                elenca pacchetti
    mimetype            mostra i pacchetti in grado di gestire il mimetype
                        indicato
    associate           associa file ai pacchetti in grado di occuparsene
    needed              mostra le librerie di runtime che il pacchetto
                        indicato necessita
    orphans             cerca i file che non appartengono ad alcun pacchetto
    required            mostra i pacchetti che richiedono il nome della
                        libreria indicato
    sets                cerca insiemi di pacchetti
    slot                mostra i pacchetti che possiedono lo slot fornito
    tags                mostra pacchetti che possiedono il tag fornito
    revisions           mostra i pacchetti con la revisione indicata
    graph               mostra il grafo diretto delle dipendenze per il
                        pacchetto indicato
    revgraph            mostra il grafo inverso delle dipendenze per il
                        pacchetto indicato
    updates             mostra il numero di aggiornamenti disponibili
flashplayer
# equo s adobe-flash
╠  @@ Cercando...
╠      @@ Pacchetto: www-plugins/adobe-flash-11.2.202.341 branch: 5, [sabayon-weekly]
╠          Disponibile:   versione: 11.2.202.341 ~ tag: NoTag ~ revisione: 0
╠          Installato:    versione: 11.2.202.341 ~ tag: NoTag ~ revisione: 0
╠          Slot:          0
╠          Homepage:      http://www.adobe.com/products/flashplayer.html
╠          Descrizione:   Adobe Flash Player
╠          Licenza:       AdobeFlash-11.x
╠   Keyword:  adobe-flash
╠   Trovati:  1 voce
to install flashplayer
# equo i adobe-flash
sabayon packages name could be different than *buntu & C.
:wink:
kalgan
Post by kalgan » Thu Mar 27, 2014 22:20
thanks!!!! i installed flash player,but when i play a movie i cant'see the video but only i hear the audio...why??
kalgan
Post by kalgan » Thu Mar 27, 2014 22:29
for eclipse:
i write this: equo i dev-java/eclipse-ecj:4.2
thisi is the output:
╠  @@ calcolo delle dipendenze...
╠  ## [R] [sabayon-weekly] dev-java/eclipse-ecj-4.2.1|0   [4.2.1|0]
╠  @@ Pacchetti che richiedono di essere installati/aggiornati/retrocessi: 1
╠  @@ Pacchetti da rimuovere: 0
╠  @@ Dimensione download: 0b
╠  @@ Spazio su disco liberato: 0.0b
╠  @@ Hai bisogno di almeno: 3.0MB di spazio libero
╠  ::: >>>  (1/1) 1 pacchetto
╠    ## Scaricamento: 1 pacchetto
╠    ## ( mirror #1 ) [dev-java:eclipse-ecj-4.2.1~0.tbz2] @ http://na.mirror.garr.it
╠   ## Download aggregato: 1 elemeto
╠    ## Controllo firma pacchetto...
╠    # [1] na.mirror.garr.it => dev-java:eclipse-ecj-4.2.1~0.tbz2
╠    ## ( mirror #1 ) [dev-java:eclipse-ecj-4.2.1~0.tbz2] successo @ http://na.mirror.garr.it
╠  +++ >>>  (1/1) dev-java/eclipse-ecj-4.2.1
╠    ## Scompattamento: dev-java:eclipse-ecj-4.2.1~0.tbz2
╠    ## Fase pacchetto: setup
╠    ## Fase pacchetto: preinstall
╠    ## Installazione pacchetto: dev-java/eclipse-ecj-4.2.1
╠    ## [Eclipse Compiler for Java]
╠    ## Aggiornamento della repository dei pacchetti installati: dev-java/eclipse-ecj-4.2.1
╠    ## Pulizia dei dati dell'applicazione precedente.
╠    ## Fase pacchetto: postremove
╠    ## Fase pacchetto: postinstall
 * To select between slots of ECJ...
 *  # eselect ecj
╠    ## Pulizia: dev-java/eclipse-ecj-4.2.1
╠  @@ Installazione completata.
╠  @@ Nessun file di configurazione da aggiornare.
but when i try to run it sabayon don't find it.....why?
