DropBox Client crashes [Solved]
Post by albfneto » Tue Mar 18, 2014 20:15
In all of my installations of Sabayon, the DropBox Client no more works.
this is the error message:
$ dropbox start -i
Starting Dropbox...Traceback (most recent call last):
  File "dropbox/client/main.py", line 13, in <module>
  File "autogen_explicit_imports.py", line 13, in <module>
  File "ui/common/selective_sync.py", line 6, in <module>
  File "arch/__init__.py", line 28, in <module>
  File "arch/linux/tracing.py", line 8, in <module>
  File "hard_trace.py", line 6, in <module>
  File "client_api/connection_hub.py", line 21, in <module>
  File "client_api/kv_connection.py", line 23, in <module>
  File "pylinux/__init__.py", line 71, in <module>
  File "cffi/api.py", line 311, in verify
  File "dropbox/overrides.py", line 398, in load_library
  File "cffi/verifier.py", line 69, in load_library
  File "cffi/verifier.py", line 154, in _load_library
  File "cffi/vengine_cpy.py", line 124, in load_library
VerificationError: importing '/home/albfneto/pylinux/__pycache__/_cffi__xa0c4f46bx1d95b4de.so': No module named _cffi__xa0c4f46bx1d95b4de
then remains as "opened" but not appears in the "Panel"
Re: DropBox Client crashes [Solved]
Post by albfneto » Sat Mar 22, 2014 20:52
Seems that this occurred because the support (packages) and dependencies of the DropBox package was old.
I simply recompiled Dropbox and their support, with the Portage versions, and now it works.
I suggest to the Sabayon's Team to recompile DropBox and their acessory packages.
If you have expertise in mix Entropy with Portage:
1. Remove the old DropBox:
# equo rm --configfiles dropbox
2. Update the Portage database and the Overlays
# emerge --sync
# layman -S
3. Upgrade the support of GCC, (needed to sucessfully recompile nautilus-dropbox)
# emerge -av autoconf automake make cmake
4. Directly in your language, recompile DropBox and theis support:
# LINGUAS="your language code" emerge -av --nodeps net-misc/dropbox thunar-dropbox nautilus-dropbox kfilebox
In my system, now, all is working:
http://i.imgur.com/JepKkCx.png
Post by sabayonino » Sat Mar 22, 2014 21:13
KDE users
I followed this post
tnx fitz :roll:
