Root cannot connect to x server [Partially Solved]
Ritana
Post by Ritana » Sat Mar 01, 2014 12:27
Hi Everyone,
Today I had to maintain my LVM2 partition and happened to have a sudden problem:
I don't know why but I'm unable to use GUI apps with root privileges , it's refused by the error message:
 No protocol specified
kate: cannot connect to X server :0
I've tried to fix it by exporting .XAUTHORITY from my user folder as well as re-setting DISPLAY env variable and so on but the result seems the same :(
Yesterday I could launch any GUI program from root terminal so I don't really know what could be went wrong. Does anyone any idea? Thanks is advance
R
edit: Ok, I managed to fix it by putting into /root/.bashrc the following command then reboot:
xauth merge /home/ritana/.Xauthority
But still, does anyone know why my root's X window had broken?
(sorry, I'm not really expert in Unix word)
LOVE is the only socially acceptable form of insanity
3.16Ghz Intel(R) Core(TM)2 Duo E8500; 6Gb Kingston DDR2 1066 Mhz,
SAMSUNG 830 SSD, Samsung HD1109 2 Tb, NVIDIA 610gt
Linux 3.12.0-sabayon, KDE 4.12.-64 bit
