Decibel Audio Player Crazy Behavior! [Solved]
Postby eor2004 » Wed Dec 18, 2013 5:03
Everytime I try to play my mp3 collection using Decibel Audio Player it starts to open multiple instances instead of one, for example, if I try to play 30 mp3 songs, it opens 30 audio player instances making my system very sluggish, sometimes my system freezes, I had to press the reset button! :evil:
So I was wondering if anyone knows how to make decibel to open only one player at a time when trying to play multiple audio files???
Sabayon Linux MATE 64-bit
Gigabyte G41M-ES2L-->2gb ram
Intel Pentium Dual Core 2.60ghz-->E5300
WD-6400AAKS-Caviar-SE16-640gb-->XFS filesystem
eor2004
Re: Decibel Audio Player Crazy Behavior!
Postby batvink » Sun Dec 22, 2013 13:33
I believe this is a known bug.
This is due to a lacking
argument in the Exec entry in the desktop file. In fact, the Freedesktop
specifications
(http://standards.freedesktop.org/deskto ... 01s06.html) mentions
that with %f, the system should assume that the application can't manage
multiple files on its command line, and should run multiple instances,
whereas with %F, all files can be pushed to the same single instance.
It's fixed from version 1.07, but Entropy, as well as Portage provides only version 1.04
You could request a version bump to 1.07 or latest: 1.08
batvink
Postby eor2004 » Sun Dec 22, 2013 18:33
Thank you very much for your answer and merry christmas!
Bug report here: https://bugs.sabayon.org/show_bug.cgi?id=4522
eor2004
Postby eor2004 » Sun Apr 06, 2014 5:54
I'm using Sabayon MATE 64 right now and cannot reproduce this bug, so I think it has been fixed, thanks! :D
eor2004
