Problems Rebooting from lxdm logon w/ systemd
sqlpython
Post by sqlpython » Thu Aug 08, 2013 16:50
As the subject says..
I have upgraded to the 13.x Sabayon xfce.
I had been running systemd before the Upgrade but that modified to original system after the the Upgrade.
I believe that Sabayon Xfce is logging in via lxdm as I don't see another login display manager.
Previous to engaging the systemd with
eselect sysvinit set systemd
I was able to Reboot or shutdown from the Login Screen by selecting from the QUIT menu.
Now that selection takes me in a loop back to the Login Screen.
I must do the Reboot or Shutdown logged in from a Desktop for the process to work properly.
Feedback appreciated.
Criticism accepted for Solutions that work. ;^)
Sabayon 13-DEBIAN 8- #! -Sid-Slackware 14-Calculate 13-Bridge
Tedel
Re: Problems Rebooting from lxdm logon w/ systemd
Post by Tedel » Sun Aug 18, 2013 3:26
Hi, I am getting something similar. When I use openrc, KDM loads at the boot screen. When I switched to systemd to try, KDM did not start and I got the other log in screen (lxdm, I think). I'd like to get KDM login screen using systemd, if possible.
I am subscribing here, as seems to be the same problem.
