GCC version bump, without software [Solved]
notzippy
Post by notzippy » Wed Apr 10, 2013 22:25
Hi
On my system gcc-config -l reported that it was using "x86_64-pc-linux-gnu-4.7.2-vanilla" even though that version was not installed on my system. Not sure how that occurred noticed when running gcc gave the following error
gcc-config: error: could not run/locate 'gcc'
Manually changing the gcc-config back to the installed version fixed the issue, any reason why this would occur ?
Re: GCC version bump, without software
Post by sabayonino » Wed Apr 10, 2013 22:40
Install full gcc:4.7.2
# equo i gcc:4.7
I think you've only installed gcc-base that has some libs not full gcc
Ryuno-Ki
Post by Ryuno-Ki » Wed Apr 10, 2013 23:02
It's a Known Issue
notzippy
Post by notzippy » Wed Apr 10, 2013 23:11
Thanks, sorry didnt know about the known issue wiki
Nz
Ryuno-Ki
Re: GCC version bump, without software [Solved]
Post by Ryuno-Ki » Thu Apr 11, 2013 19:21
No problem. I'm trying to report solutions to recent faq there in the future :)
