Libusb problem [Solved]
tek640
Post by tek640 » Mon Apr 08, 2013 7:04
I am trying to use Flashtool, which is for flashing kernels and others stuff in Xperia phones. The problem is when I try to run it, I get a message which says that libusb version is 1.0.9 and the minimum requirement is 1.0.14. I tried to compile libusbx 1.0.14 but still flashtool cannot find it. After a little more searching I discover that flashtool search for libusb in directory /usr/local but sabayon put libusbx in directory /usr/portage. Is there a way to change the directory so Flashtool runs correctly? Or another way to made it run somehow?
colock
Re: Libusb problem
Post by colock » Mon Apr 08, 2013 11:06
Your findings are quite imprecise:
  • Sabayon does clearly NOT put anything in /usr/portage.
  • Maybe you found an ebuild for libusb in /usr/portage, where it is expected to be.
is Flashtool a precompiled binary? if so, it is compiled for x86 or x86_64 (i.e. 32bit or 64bit?). At any rate, libusb is 1.0.9, either a) wait for an upgrade from sabayon, b) install a new version of libusb with portage and the recompile any program linking to it [very not recommended] c) see if Flashtool relaly needs 1.0.14 or it was just compiled against it, in the latter case, see if you can find the sources and recompile Flashtool yourself against your current libusb.
Good luck!
belcocco
Re: Libusb problem
Post by belcocco » Mon Apr 08, 2013 11:45
@colock +1
in addition, I do not know what flashtool, I'll tell you the general method, then see how to act.
If the library you want is in /usr/portage/ named 'libusbx', while the program looks for it in /usr/local directory, open a terminal as root and create a symbolic link with the command (general syntax):
#ln -s source_file target_file
In your case would be (only to see):
#ln -s /usr/portage/libusbx /usr/local/libusb
Ciao
Re: Libusb problem
Post by sabayonino » Mon Apr 08, 2013 17:50
portage put its .ebuild in /usr/portage/<category>/name.ebuild
.ebuilds are not libraries !
all libreries are stored in /lib /lib32 /lib64 and /usr/lib /usr/lib32 /usr/lib64
tek640
Re: Libusb problem
Post by tek640 » Mon Apr 08, 2013 17:59
@colock, sabayonino
Sorry, my mistake, it's ebuild and not library. But still I cannot find libusbx in lib64.
Flashtool is precompiled and it's compiled x86_64 as my system.
From your answers, I think I 'll wait for new version of libusb or I will search for older version of flashtool.
Thanks.
