Problem with KDEnlive
vfafou
Post by vfafou » Sun Mar 31, 2013 21:41
Hello!
I' m an openshot user since it was appeared to Ubuntu. Now I'm a Sabayon KDE user and I needed to use a video editor. I decided to give KDEnlive a try, but I can run it only as root. The console error I get when trying to run it as user is:
libDeckLinkAPI.so: cannot open shared object file: No such file or directory
QCoreApplication::postEvent: Unexpected null receiver
detected format: YUV 4:2:2 (YUYV): YUYV
The library libDeckLinkAPI.so exist in /usr/lib.
Does anyone have solved this issue?
Thank you in advance!
Re: Problem with KDEnlive
Post by Stupot » Sun Mar 31, 2013 22:08
Looks like somebody else has this problem over in gentoo just like you.
http://forums.gentoo.org/viewtopic-p-7257912.html
Can you try what was tried here: http://www.kdenlive.org/mantis/view.php?id=3001
After few days, in my case the solution was (I think so) to delete everything in /var/tmp/kdecache-user. After this both kdenlive 0.9.4 and from Daily Builds works fine. As I said before deleting just config files like kdenliverc in /home/user wasn't enough.
So everything works fine - solved.
vfafou
Post by vfafou » Mon Apr 01, 2013 21:26
Hello Stupot!
Thank you for replying!
I tried your suggestion but it didn't work.
I don't understand why I have to be root in order to run KDEnlive. Note that I hadn't tried to run it before...
Post by Stupot » Mon Apr 01, 2013 22:33
I can run KDEnlive on my system as my usual user with no errors.
But the fact that you haven't run it before could be helpful in figuring out what is going on.
vfafou
Post by vfafou » Tue Apr 02, 2013 20:11
Any idea??? :cry: :cry: :cry:
Post by Stupot » Wed Apr 03, 2013 17:35
Try deleting
$HOME/.kde/share/config/kdenliverc
Other than that, I can't really think of anything else with the information you've provided.
Ryuno-Ki
Post by Ryuno-Ki » Wed Apr 03, 2013 21:01
Stupot wrote:Try deleting
Or moving away
mv $HOME/.kde/share/config/kdenliverc $HOME/.kde/share/config/kdenliverc-backup
vfafou
Post by vfafou » Wed Apr 03, 2013 22:58
Hello again and thank you for your replies!
It will drive me crazy!!! There is not any kdenliverc file in ~/.kde4/share/config!
What can I do?
Matte88
Location: @/etc/entropy/repositories.conf.d/entropy_sabayon-limbo
Post by Matte88 » Fri Apr 05, 2013 0:51
Try
equo lt && equo dt && equo i kdenlive
When I became the sun,
I shone life into the man's hearts.
