Do I need to uninstall HAL? [Solved]
adsicks
Post by adsicks » Sat Sep 01, 2012 21:35
I have a setup that has been upgraded and hopped from Sabayon 5...Do I still need HAL? I did an rc-update -s and noticed hald is started at boot.
Re: Do I need to uninstall HAL?
Post by Fitzcarraldo » Sun Sep 02, 2012 6:12
HAL is obsolete, and you can get rid of it. You can uninstall it (if you're upgraded to current then the package should not even exist anymore) and also remove its initscript from the boot runlevel:
# rc-update del hald boot
# rm /etc/init.d/hald
adsicks
Post by adsicks » Sun Sep 02, 2012 7:23
Thanks. I did that and am about to reboot. I think right after it was obsolete, I did a equo remove hal --pretend and there were still many packages that were dependent. Must have jumped the gun. But, even if the files are there, that will disable it for sure...I'll mark as Solved when I come back up...
adsicks
Re: Do I need to uninstall HAL? [Solved]
Post by adsicks » Sun Sep 02, 2012 7:31
Boots faster and loads KDE fast (imagine that :lol: )...will proll solve some of the glitches I've been having too :wink: ...Thanks man!!!
