Problem with libpython3.2mu.so.1.0
bls
Post by bls » Wed Oct 19, 2011 17:04
Hi all
I 'm a new sabayon user.I'm having some problems trying to run a blender build from Graphicall.org.
I have allready installed blender official succesfully in my system but I downloaded a new build from Graphicall for testing.
So when I trying to run blender I have some missing libs.
I installed some of them but now I have this error:
./blender: error while loading shared libraries: libpython3.2mu.so.1.0: cannot open shared object file: No such file or directory
I can't figure out how to install this lb, so anyone has a solution?
Thanx in advance!
Oh I run sabayon 7 kdex64
Sisko43
Re: Problem with libpython3.2mu.so.1.0
Post by Sisko43 » Thu Oct 20, 2011 18:15
Sabayon runs python in version 2.7.2. Your Blender-Version needs 3.2. That's the reason it won't start. Python 3.2 is not available for sabayon at the moment. It's a available through gentoo-portage, so you could install it on sabayon. But I don't know how this would affect your installation. Furthermore it's categorized as "not stable"...
What version of blender do you want to use?
bls
Post by bls » Thu Oct 20, 2011 19:46
Thanks for reply.
I want to use a 2.59 cycles build.
I know that blender use python 2.6 from 2.49b version.
Anyway I will try to install it as you told me.
Thanks again.
Sisko43
Post by Sisko43 » Fri Oct 21, 2011 9:43
I downloaded a 2.59 build from the site you mentioned, and was able to start it without needing any python 3:
http://graphicall.org/62
I just had to install "jpeg6", "libpng 1.2" and in addition to that a softlink:
ln -s /usr/lib/libtiff.so.3 /usr/lib/libtiff.so.4
