dolphin doesn't always show what happens when F4 [Solved]
batvink
Post by batvink » Mon Aug 15, 2011 23:42
hi all.
it's not happening always, but sometimes
when i open Dolphin filemanager and hit F4 (build-in terminal)
and say, run a script to move or sort files, the job gets done,
but in the main window of Dolphin, nothing happens.
The files/folders are still there.
when i close Dolphin and reopen, or hit F5 (reload)
then the actual changes are visible.
now, it's not really a 'problem'
but is there a way to fix this?
does anyone know why the changes made at the build-in commandline
sometimes are not inmidiately visible in the main window of Dolphin?
thanks in advance..
Thev00d00
Generally Awesome (tm)
Re: dolphin doesn't always show what happens when using F4
Post by Thev00d00 » Tue Aug 16, 2011 7:51
There isn't a fix for this as far as I could find, its strange as you would think that dolphin would watch for changes in the current directory, but it doesnt seem to, I assume for performance issues, I see they have started a major rewrite of Dolphin ready for 4.8 so that might fix it?
Website / Blog : v00d00.net
twitter: Follow Me
G+: Circle Me
batvink
Post by batvink » Tue Aug 16, 2011 18:08
thanks for the answer.
Well i just sit back then and wait for releaase 4.8
like i said, it's not a big issue.
i KNOW that the job gets done.
it's not solved, but i'll add it anyway...
