convert flac to mp3? [Solved]
gav989
Post by gav989 » Tue Jun 08, 2010 8:47
i've used grip to rip all my cds to flac to enjoy when using my computer, but my mp3 player doesn't support flac, so i was looking for some software to convert from flac to mp3
i know there are programs on linux for this, but i was hoping someone could tell me what they use on sabayon, i can't seem to find anything in sulfur or portage
what do you use for this?
thanks
dannii2
Re: convert flac to mp3?
Post by dannii2 » Tue Jun 08, 2010 9:16
soundkonverter is what I use. I find it a little shakey at times though and it really doesn't like pulling stuff from my network drive.
I'm pretty sure it's in Entropy.
D2
svantoviit
Post by svantoviit » Tue Jun 08, 2010 10:02
You can try SoundConverter for Gnome.
If you prefer command line, check ffmpeg, the basic way to use it is:
ffmpeg -i Audio.flac Audio.mp3
gav989
Post by gav989 » Tue Jun 08, 2010 14:00
soundconverter did the job nicely, thanks for your help
Post by Fitzcarraldo » Tue Jun 08, 2010 15:26
When you have solved your problem, please mark the thread solved. To do this click on the EDIT button in the first post and append " [Solved]" to the Subject text. Thanks. I'll do it for you this time.
:arrow: Why, and how to add "[Solved]" to your post. Please read.
