Truecrypt Readonly
Amak
Truecrypt Readonly
Post by Amak » Fri May 28, 2010 0:27
Arg, 2nd issue I can't find a solution to. Whenever I mount my NTFS drive with Truecrypt, I cannot delete or write to it. Truecrypt shows Read Only as "No", but Sabayon is showing something else. I tried chmod and using Dolphin as root and nothing works.
Amak
Re: Truecrypt Readonly
Post by Amak » Sun Jun 06, 2010 18:27
*Bump* nothing? Ubuntu never had the read only problem:|
diddlebug
Post by diddlebug » Sat Jul 03, 2010 19:48
Amak, I had issues with the Sulfur-based installation of Truecrypt. Try downloading the binary from Truecrypt's website and installing that way (very easy, simply unzip and run the executable installer). It work flawlessly now.
Hope this helps!
Amak
Post by Amak » Wed Jul 07, 2010 21:20
Thanks but that didn't solve my issue... I may have to swap to Fedora or back to Windows... seems Sabayon simply may not like my setup:\
gggg
Post by gggg » Mon Jun 27, 2011 13:55
Has anyone managed to mount truecrypt with read write? When ever I mount I get it mounted as read-only.
/dev/mapper/truecrypt2 on /media/truecrypt2 type ntfs (ro,uid=1000,gid=1001,umask=077)
