Problems after remvoing kernel 2.6.31
xfighterx
Post by xfighterx » Mon May 10, 2010 19:11
Hi. I switched to 2.6.32, and i was really happy. Everything was working fine so I decided to remove 2.6.31 because I got very tiny hdd. I did it. No problems. No warnings. Ok. But after couple of days, updates and reboots I found out that some bad things occure. First died chromium
./chrome: error while loading shared libraries: libnss3.so.1d: cannot open shared object file: No such file or directory
than maxima
fatal error encountered in SBCL pid 17228(tid 3085097744):
can't load .core for different runtime, sorry
The system is too badly corrupted or confused to continue at the Lisp
level. If the system had been compiled with the SB-LDB feature, we'd drop
into the LDB low-level debugger now. But there's no LDB in this build, so
we can't really do anything but just exit, sorry.
now rhythmbox.. it dies completly quietly. no messages. nothing. its too much!
i tried libtets, deptest. revdep-rebuild shows lots of broken libraries but compilation dies at first package. normally i'm using sulphur so i thought it's not fault of emerge.
i tried reinstalling nss, lisp, sbcl, maxima.. everything that could do the work. bu it doesnt. and now rhythmbox. i really need it!
does anyone got any guessing?
edit
i found rhythmbox -d but it doesnt look very helpful for me
(20:21:19) [0x82abf70] [rb_debug_init_match] rb-debug.c:213: Debugging enabled
(20:21:19) [0x82abf70] [main] main.c:176: initializing Rhythmbox 0.12.6
(20:21:19) [0x82abf70] [rb_threads_init] rb-util.c:388: GMutex isn't recursive
(20:21:19) [0x82abf70] [main] main.c:184: going to create DBus object
(20:21:19) [0x82abf70] [main] main.c:266: Going to create a new shell
(20:21:19) [0x82abf70] [rb_shell_constructed] rb-shell.c:1322: Constructing shell
(20:21:19) [0x82abf70] [construct_db] rb-shell.c:974: creating database object
(20:21:19) [0x82abf70] [rb_find_user_file] rb-file-helpers.c:193: found user dir path for 'rhythmdb.xml': /home/fight/.local/share/rhythmbox/rhythmdb.xml
(20:21:19) [0x82abf70] [construct_widgets] rb-shell.c:1041: shell: initializing shell services
(20:21:19) [0x82abf70] [gconf_network_buffer_size_changed] rb-shell-player.c:3792: network buffer size changed
(20:21:19) [0x82abf70] [rb_header_sync] rb-header.c:439: syncing with entry = <null>
(20:21:19) [0x82abf70] [rb_header_sync] rb-header.c:515: not playing
(20:21:19) [0x82abf70] [rb_shell_player_set_playing_source_internal] rb-shell-player.c:3066: setting playing source to (nil)
(20:21:19) [0x82abf70] [rb_shell_player_sync_with_source] rb-shell-player.c:2890: playing source: (nil), active entry: (nil)
(20:21:19) [0x82abf70] [rb_shell_player_sync_control_state] rb-shell-player.c:2390: syncing control state
(20:21:19) [0x82abf70] [rhythmdb_query_model_chain] rhythmdb-query-model.c:779: query model 0x835bde0 chaining to base model (nil)
(20:21:19) [0x82abf70] [rhythmdb_query_model_chain] rhythmdb-query-model.c:779: query model 0x835be50 chaining to base model (nil)
(20:21:19) [0x82abf70] [rhythmdb_query_model_dispose] rhythmdb-query-model.c:654: disposing query model 0x835bde0
(20:21:19) [0x82abf70] [rhythmdb_query_model_finalize] rhythmdb-query-model.c:702: finalizing query model 0x835bde0
(20:21:19) [0x82abf70] [rb_entry_view_insert_column_custom] rb-entry-view.c:1745: appending column: 0x85ae2a8 ()
(20:21:19) [0x82abf70] [rb_entry_view_insert_column_custom] rb-entry-view.c:1745: appending column: 0x85ae228 (Ścieżka)
(20:21:19) [0x82abf70] [rb_entry_view_insert_column_custom] rb-entry-view.c:1745: appending column: 0x8613810 (Tytuł)
(20:21:19) [0x82abf70] [rb_entry_view_insert_column_custom] rb-entry-view.c:1745: appending column: 0x8613910 (Gatunek)
(20:21:19) [0x82abf70] [rb_entry_view_insert_column_custom] rb-entry-view.c:1745: appending column: 0x8613a10 (Wykonawca)
(20:21:19) [0x82abf70] [rb_entry_view_insert_column_custom] rb-entry-view.c:1745: appending column: 0x8613b10 (Album)
(20:21:19) [0x82abf70] [rb_entry_view_insert_column_custom] rb-entry-view.c:1745: appending column: 0x8613c10 (Rok)
(20:21:19) [0x82abf70] [rb_entry_view_insert_column_custom] rb-entry-view.c:1745: appending column: 0x85ae628 (Długość)
(20:21:19) [0x82abf70] [rb_entry_view_insert_column_custom] rb-entry-view.c:1745: appending column: 0x8613e90 (Jakość)
(20:21:19) [0x82abf70] [rb_entry_view_insert_column_custom] rb-entry-view.c:1745: appending column: 0x8616a40 (Ocena)
(20:21:19) [0x82abf70] [rb_entry_view_insert_column_custom] rb-entry-view.c:1745: appending column: 0x8616940 (Liczba odtworzeń)
(20:21:19) [0x82abf70] [rb_entry_view_insert_column_custom] rb-entry-view.c:1745: appending column: 0x8613d10 (Położenie)
(20:21:19) [0x82abf70] [rb_entry_view_insert_column_custom] rb-entry-view.c:1745: appending column: 0x8613f10 (Ostatnio odtwarzany)
(20:21:19) [0x82abf70] [rb_entry_view_insert_column_custom] rb-entry-view.c:1745: appending column: 0x86168c0 (Data dodania)
(20:21:19) [0x82abf70] [rebuild_child_model] rb-library-browser.c:689: no selection for browser 0 - reusing parent model
(20:21:19) [0x82abf70] [rebuild_child_model] rb-library-browser.c:689: no selection for browser 1 - reusing parent model
(20:21:19) [0x82abf70] [rebuild_child_model] rb-library-browser.c:689: no selection for browser 2 - reusing parent model
(20:21:19) [0x82abf70] [rb_property_view_selection_changed_cb] rb-property-view.c:830: selection changed
(20:21:19) [0x82abf70] [rhythmdb_query_model_chain] rhythmdb-query-model.c:779: query model 0x835bec0 chaining to base model (nil)
(20:21:19) [0x82abf70] [rhythmdb_query_model_chain] rhythmdb-query-model.c:779: query model 0x835bec0 chaining to base model 0x835be50
(20:21:19) [0x82abf70] [rb_entry_view_insert_column_custom] rb-entry-view.c:1745: appending column: 0x861c1a8 (Kolejka odtwarzania)
(20:21:19) [0x82abf70] [rb_sourcelist_append] rb-sourcelist.c:1122: inserting source 0x85e9148 to group library
(20:21:19) [0x82abf70] [rb_shell_constructed] rb-shell.c:1342: shell: adding gconf notification
(20:21:19) [0x82abf70] [rb_shell_constructed] rb-shell.c:1375: shell: syncing with gconf
(20:21:19) [0x82abf70] [rb_source_set_property] rb-source.c:623: Setting Kolejka odtwarzania visibility to 0
(20:21:19) [0x82abf70] [visibility_notify_cb] rb-sourcelist.c:1028: Source visibility changed: Kolejka odtwarzania
(20:21:19) [0x82abf70] [rhythmdb_query_model_chain] rhythmdb-query-model.c:779: query model 0x8635c08 chaining to base model (nil)
(20:21:19) [0x82abf70] [rb_entry_view_insert_column_custom] rb-entry-view.c:1745: appending column: 0x8634950 (Ścieżka)
(20:21:19) [0x82abf70] [rb_entry_view_sync_sorting] rb-entry-view.c:1140: Updating EntryView sort order to Track:0
(20:21:19) [0x82abf70] [rb_entry_view_sync_sorting] rb-entry-view.c:1151: emitting sort order changed
(20:21:19) [0x82abf70] [rb_entry_view_insert_column_custom] rb-entry-view.c:1745: appending column: 0x8634b50 (Tytuł)
(20:21:19) [0x82abf70] [rb_entry_view_insert_column_custom] rb-entry-view.c:1745: appending column: 0x8634c50 (Gatunek)
(20:21:19) [0x82abf70] [rb_entry_view_insert_column_custom] rb-entry-view.c:1745: appending column: 0x8634d50 (Wykonawca)
(20:21:19) [0x82abf70] [rb_entry_view_insert_column_custom] rb-entry-view.c:1745: appending column: 0x8634a50 (Album)
(20:21:19) [0x82abf70] [rb_entry_view_insert_column_custom] rb-entry-view.c:1745: appending column: 0x8634e50 (Rok)
(20:21:19) [0x82abf70] [rb_entry_view_insert_column_custom] rb-entry-view.c:1745: appending column: 0x8638158 (Długość)
(20:21:19) [0x82abf70] [rb_entry_view_insert_column_custom] rb-entry-view.c:1745: appending column: 0x86383d8 (Jakość)
(20:21:19) [0x82abf70] [rb_entry_view_insert_column_custom] rb-entry-view.c:1745: appending column: 0x8638058 (Liczba odtworzeń)
(20:21:19) [0x82abf70] [rb_entry_view_insert_column_custom] rb-entry-view.c:1745: appending column: 0x8638258 (Położenie)
(20:21:19) [0x82abf70] [rb_browser_source_state_prefs_sync] rb-browser-source.c:778: syncing state
(20:21:19) [0x82abf70] [rhythmdb_query_model_chain] rhythmdb-query-model.c:779: query model 0x8635c78 chaining to base model (nil)
(20:21:19) [0x82abf70] [rhythmdb_query_model_dispose] rhythmdb-query-model.c:654: disposing query model 0x8635c08
(20:21:19) [0x82abf70] [rhythmdb_query_model_finalize] rhythmdb-query-model.c:702: finalizing query model 0x8635c08
(20:21:19) [0x82abf70] [rhythmdb_query_model_chain] rhythmdb-query-model.c:779: query model 0x8635ce8 chaining to base model (nil)
(20:21:19) [0x82abf70] [rb_entry_view_insert_column_custom] rb-entry-view.c:1745: appending column: 0x8638458 (Ocena)
(20:21:19) [0x82abf70] [songs_view_sort_order_changed_cb] rb-browser-source.c:642: sort order changed
(20:21:19) [0x82abf70] [rb_entry_view_insert_column_custom] rb-entry-view.c:1745: appending column: 0x86384d8 (Ostatnio odtwarzany)
(20:21:19) [0x82abf70] [rb_entry_view_insert_column_custom] rb-entry-view.c:1745: appending column: 0x8638758 (Data dodania)
(20:21:19) [0x82abf70] [rb_sourcelist_append] rb-sourcelist.c:1122: inserting source 0x8504140 to group library
(20:21:19) [0x82abf70] [rhythmdb_query_model_chain] rhythmdb-query-model.c:779: query model 0x8635dc8 chaining to base model (nil)
(20:21:19) [0x82abf70] [rb_entry_view_insert_column_custom] rb-entry-view.c:1745: appending column: 0x863daa0 (Data)
(20:21:19) [0x82abf70] [rb_entry_view_insert_column_custom] rb-entry-view.c:1745: appending column: 0x86385d8 (Tytuł)
(20:21:19) [0x82abf70] [rb_entry_view_sync_sorting] rb-entry-view.c:1140: Updating EntryView sort order to Title:0
(20:21:19) [0x82abf70] [rb_entry_view_insert_column_custom] rb-entry-view.c:1745: appending column: 0x863d820 (Źródło)
(20:21:19) [0x82abf70] [rb_entry_view_insert_column_custom] rb-entry-view.c:1745: appending column: 0x863db20 (Długość)
(20:21:19) [0x82abf70] [rb_entry_view_insert_column_custom] rb-entry-view.c:1745: appending column: 0x863dda0 (Ocena)
(20:21:19) [0x82abf70] [rb_entry_view_insert_column_custom] rb-entry-view.c:1745: appending column: 0x863dea0 (Liczba odtworzeń)
(20:21:19) [0x82abf70] [rb_entry_view_insert_column_custom] rb-entry-view.c:1745: appending column: 0x8642098 (Ostatnio odtwarzany)
(20:21:19) [0x82abf70] [rb_entry_view_insert_column_custom] rb-entry-view.c:1745: appending column: 0x863dba0 (Stan)
(20:21:19) [0x82abf70] [rhythmdb_query_model_chain] rhythmdb-query-model.c:779: query model 0x8635e38 chaining to base model (nil)
(20:21:19) [0x82abf70] [rhythmdb_read_enter] rhythmdb.c:1223: counter: 1
(20:21:19) [0x82abf70] [rhythmdb_query_internal] rhythmdb.c:4077: doing query
(20:21:19) [0x82abf70] [do_query_recurse] rhythmdb-tree.c:2243: doing recursive query, 1 conjunctions
(20:21:19) [0x82abf70] [rhythmdb_query_model_add_results] rhythmdb-query-model.c:2018: adding 0 entries
(20:21:19) [0x82abf70] [idle_process_update] rhythmdb-query-model.c:1060: inserting 0 rows
(20:21:19) [0x82abf70] [rhythmdb_query_internal] rhythmdb.c:4083: completed
(20:21:19) [0x82abf70] [rb_podcast_source_state_prefs_sync] rb-podcast-source.c:978: syncing state
(20:21:19) [0x82abf70] [rhythmdb_query_model_chain] rhythmdb-query-model.c:779: query model 0x8635ea8 chaining to base model (nil)
(20:21:19) [0x82abf70] [rhythmdb_query_model_dispose] rhythmdb-query-model.c:654: disposing query model 0x8635dc8
(20:21:19) [0x82abf70] [rhythmdb_query_model_finalize] rhythmdb-query-model.c:702: finalizing query model 0x8635dc8
(20:21:19) [0x82abf70] [rhythmdb_read_enter] rhythmdb.c:1223: counter: 2
(20:21:19) [0x82abf70] [rb_sourcelist_append] rb-sourcelist.c:1122: inserting source 0x85a9328 to group library
(20:21:19) [0x82abf70] [rhythmdb_query_model_chain] rhythmdb-query-model.c:779: query model 0x8635f18 chaining to base model (nil)
(20:21:19) [0x82abf70] [rhythmdb_query_model_chain] rhythmdb-query-model.c:779: query model 0x8636080 chaining to base model (nil)
(20:21:19) [0x82abf70] [rhythmdb_query_model_dispose] rhythmdb-query-model.c:654: disposing query model 0x8636080
(20:21:19) [0x82abf70] [rhythmdb_query_model_finalize] rhythmdb-query-model.c:702: finalizing query model 0x8636080
(20:21:19) [0x82abf70] [rb_entry_view_insert_column_custom] rb-entry-view.c:1745: appending column: 0x8642518 (Ścieżka)
(20:21:19) [0x82abf70] [rb_entry_view_insert_column_custom] rb-entry-view.c:1745: appending column: 0x8642718 (Tytuł)
(20:21:19) [0x82abf70] [rb_entry_view_insert_column_custom] rb-entry-view.c:1745: appending column: 0x8642598 (Wykonawca)
(20:21:19) [0x82abf70] [rb_entry_view_insert_column_custom] rb-entry-view.c:1745: appending column: 0x8650098 (Album)
(20:21:19) [0x82abf70] [rb_entry_view_insert_column_custom] rb-entry-view.c:1745: appending column: 0x8650198 (Położenie)
(20:21:19) [0x82abf70] [rb_entry_view_insert_column_custom] rb-entry-view.c:1745: appending column: 0x8650298 (Ostatnio widziany)
(20:21:19) [0x82abf70] [rb_source_set_property] rb-source.c:623: Setting Brakujące pliki visibility to 0
(20:21:19) [0x82abf70] [rb_sourcelist_append] rb-sourcelist.c:1122: inserting source 0x83bc120 to group library
(20:21:19) [0x82abf70] [rhythmdb_query_model_chain] rhythmdb-query-model.c:779: query model 0x86360f0 chaining to base model (nil)
(20:21:19) [0x8646ae8] [query_thread_main] rhythmdb.c:4100: entering query thread
(20:21:19) [0x8646ae8] [rhythmdb_query_internal] rhythmdb.c:4077: doing query
(20:21:19) [0x8646ae8] [do_query_recurse] rhythmdb-tree.c:2243: doing recursive query, 1 conjunctions
(20:21:19) [0x8646ae8] [rhythmdb_query_model_add_results] rhythmdb-query-model.c:2018: adding 0 entries
(20:21:19) [0x8646ae8] [rhythmdb_query_internal] rhythmdb.c:4083: completed
(20:21:19) [0x82abf70] [rhythmdb_query_model_chain] rhythmdb-query-model.c:779: query model 0x86361d0 chaining to base model (nil)
(20:21:19) [0x82abf70] [rhythmdb_query_model_dispose] rhythmdb-query-model.c:654: disposing query model 0x86361d0
(20:21:19) [0x82abf70] [rhythmdb_query_model_finalize] rhythmdb-query-model.c:702: finalizing query model 0x86361d0
(20:21:19) [0x82abf70] [rb_entry_view_insert_column_custom] rb-entry-view.c:1745: appending column: 0x8650598 (Położenie)
(20:21:19) [0x82abf70] [rb_entry_view_insert_column_custom] rb-entry-view.c:1745: appending column: 0x8650318 (Błąd)
(20:21:19) [0x82abf70] [rb_source_set_property] rb-source.c:623: Setting Błędy importowania visibility to 0
(20:21:19) [0x82abf70] [rb_sourcelist_append] rb-sourcelist.c:1122: inserting source 0x83bc1b0 to group library
(20:21:19) [0x82abf70] [rb_find_user_file] rb-file-helpers.c:193: found user dir path for 'playlists.xml': /home/fight/.local/share/rhythmbox/playlists.xml
(20:21:19) [0x82abf70] [construct_sources] rb-shell.c:1213: shell: creating playlist manager
(20:21:19) [0x82abf70] [construct_sources] rb-shell.c:1225: shell: creating removable media manager
(20:21:19) [0x82abf70] [construct_load_ui] rb-shell.c:1247: shell: loading ui
(20:21:19) [0x82abf70] [rb_shell_select_source] rb-shell.c:1926: selecting source 0x8504140
(20:21:19) [0x82abf70] [rb_shell_clipboard_set_source_internal] rb-shell-clipboard.c:342: selected source 0x8504140
(20:21:19) [0x82abf70] [rb_shell_clipboard_sync] rb-shell-clipboard.c:562: syncing clipboard
(20:21:19) [0x82abf70] [rebuild_playlist_menu] rb-shell-clipboard.c:991: rebuilding add-to-playlist menu
(20:21:19) [0x82abf70] [rb_shell_player_set_source_internal] rb-shell-player.c:1043: selected source 0x8504140
(20:21:19) [0x82abf70] [rb_shell_player_sync_with_selected_source] rb-shell-player.c:3339: syncing with selected source: 0x8504140
(20:21:19) [0x82abf70] [rb_shell_player_sync_with_selected_source] rb-shell-player.c:3342: no playing source, new source is 0x8504140
(20:21:19) [0x82abf70] [rb_shell_set_window_title] rb-shell.c:1978: clearing title
(20:21:19) [0x82abf70] [rb_shell_player_sync_buttons] rb-shell-player.c:2985: syncing with source 0x8504140
(20:21:19) [0x82abf70] [rb_source_header_set_source_internal] rb-source-header.c:487: selected source 0x8504140
(20:21:19) [0x82abf70] [rb_source_header_view_browser_changed_cb] rb-source-header.c:813: got view browser toggle
(20:21:19) [0x82abf70] [rb_source_header_view_browser_changed_cb] rb-source-header.c:826: got view browser toggle
(20:21:19) [0x82abf70] [rb_statusbar_set_property] rb-statusbar.c:327: selected source 0x8504140
(20:21:19) [0x82abf70] [rb_statusbar_sync_status] rb-statusbar.c:446: updating status with: '0 utworów', '', -1,000000
(20:21:19) [0x82abf70] [_uri_handle_recurse] rb-file-helpers.c:611: error enumerating file:///home/fight/.gnome2/rhythmbox/plugins: Nie ma takiego pliku ani katalogu
(20:21:19) [0x82abf70] [_uri_handle_recurse] rb-file-helpers.c:611: error enumerating file:///home/fight/.local/share/rhythmbox/plugins: Nie ma takiego pliku ani katalogu
(20:21:19) [0x82abf70] [rb_plugins_engine_load] rb-plugins-engine.c:116: Loading plugin: /usr/lib/rhythmbox/plugins/python-console/pythonconsole.rb-plugin
(20:21:19) [0x82abf70] [rb_plugins_engine_load] rb-plugins-engine.c:206: Could not find 'Icon' in /usr/lib/rhythmbox/plugins/python-console/pythonconsole.rb-plugin
(20:21:19) [0x82abf70] [rb_plugins_engine_load_cb] rb-plugins-engine.c:299: Plugin Konsola Python loaded
(20:21:19) [0x82abf70] [rb_plugins_engine_load] rb-plugins-engine.c:116: Loading plugin: /usr/lib/rhythmbox/plugins/ipod/ipod.rb-plugin
(20:21:19) [0x82abf70] [rb_plugins_engine_load] rb-plugins-engine.c:206: Could not find 'Icon' in /usr/lib/rhythmbox/plugins/ipod/ipod.rb-plugin
(20:21:19) [0x82abf70] [rb_plugins_engine_load_cb] rb-plugins-engine.c:299: Plugin Przenośne odtwarzacze - iPod loaded
(20:21:19) [0x82abf70] [rb_plugins_engine_load] rb-plugins-engine.c:116: Loading plugin: /usr/lib/rhythmbox/plugins/lyrics/lyrics.rb-plugin
(20:21:19) [0x82abf70] [rb_plugins_engine_load] rb-plugins-engine.c:206: Could not find 'Icon' in /usr/lib/rhythmbox/plugins/lyrics/lyrics.rb-plugin
(20:21:19) [0x82abf70] [rb_plugins_engine_load_cb] rb-plugins-engine.c:299: Plugin Tekst utworu loaded
(20:21:19) [0x82abf70] [rb_python_module_init] rb-python-module.c:420: Init of python module
Sisko43
Re: Problems after remvoing kernel 2.6.31
Post by Sisko43 » Mon May 10, 2010 20:41
Maybe the program "lafilefixer" helps. Install it via emerge or sulfur and execute as root:
lafilefixer --justfixit
This will repair,update or clean ALL libraries(symlinks etc.) Very useful tool especially after kernel-switching.
xfighterx
Post by xfighterx » Tue May 11, 2010 12:11
thx for advice. i did it. it got through files. some updated, some ommited, but none of those apps I mentioned didnt start working.
any other thoughts?
Sisko43
Post by Sisko43 » Tue May 11, 2010 17:22
Did you install the mentioned packages with emerge or sulfur?
xfighterx
Post by xfighterx » Tue May 11, 2010 19:00
with sulphur. i am not using emerge. i just installed it at the beginnig because i migrated from gentoo and thought it will be usefull
xfighterx
Post by xfighterx » Tue May 11, 2010 20:12
Hooray! They just added rhythmbox-0.12.8-r1. Now it works perfect!
but there is still a problem with maxima and chrome.
xfighterx
Post by xfighterx » Sun Jun 06, 2010 12:52
problem with maxima may be caused by different versions of sbcl. I think that there is newer ver of sbcl in portage then maxima was compiled with. i would like to ask somebody responsible to check this lead out.
Post by wolfden » Sun Jun 06, 2010 16:58
xfighterx wrote:problem with maxima may be caused by different versions of sbcl. I think that there is newer ver of sbcl in portage then maxima was compiled with. i would like to ask somebody responsible to check this lead out.
Use the bugzilla and make the request
