What happened with Gambas IDE?
raregazz
Post by raregazz » Sat Apr 17, 2010 5:57
Gambas IDE 2.16 is in the repos but nothing happens when installs in Sabayon 5.2. :shock:
Spanish forum doesn't know anything, please tell me how to install this app.
http://forum.sabayon.org/viewtopic.php? ... fb108dbf2e
Thanks in advance.
Re: What happened with Gambas IDE?
Post by Fitzcarraldo » Sat Apr 17, 2010 9:20
Hola, raregazz. ¿Que tal?
The Portage maintainers pulled the Gambas ebuild from Portage. :(
However, you can get the latest ebuild as follows:
Download the ebuild for gambas-2.16.0.ebuild from the following mirror:
http://piotrkosoft.net/pub/mirrors/gent ... 6.0.ebuild
Then go to the Gentoo Bugzilla Bug Report No. 302136 page and download the diff file gambas-2.20.0.ebuild.diff and use it to create the new ebuild for version 2.20.0 in a local overlay:
/usr/local/portage/dev-lang/gambas/gambas-2.20.0.ebuild
Then download from the same Gentoo Bugzilla page the file gambas-2.20.0-FLAGS.patch and put it in the directory:
/usr/local/portage/dev-lang/gambas/files/
Then create a manifest for the package using the ebuild command, and finally merge the package using the emerge command. Don't forget to do an emerge --sync && layman -S beforehand.
raregazz
Post by raregazz » Sat Apr 17, 2010 19:38
Hello Fitzcarraldo.
I downloaded the file http://piotrkosoft.net/pub/mirrors/gent ... 6.0.ebuild and the diff file with the patch, but I don't know how to do to make the new ebuild for version 2.20.0 in a local overlay.
I make the /usr/local/portage/dev-lang/gambas/ directory and I put the 3 files inside.
raregazz-laptop gambas # ls
files  gambas-2.16.0.ebuild  gambas-2.20.0.ebuild.diff  Manifest
I add this line to make.conf
PORTDIR_OVERLAY="/usr/local/portage"
I create de manifest with
raregazz-laptop gambas # ebuild gambas-2.16.0.ebuild manifest
Also...
and then, I don't know more to do... :cry: (How should I create the gambas-2.20.0.ebuild?)
raregazz-laptop gambas # emerge -pv gambas
WARNING: One or more repositories have missing repo_name entries:
        /usr/local/portage/profiles/repo_name
NOTE: Each repo_name entry should be a plain text file containing a
unique name for the repository on the first line.
[ebuild  N    ] dev-lang/gambas-2.16.0  USE="bzip2 gtk opengl pcre pdf sdl svg v4l xml zlib -corba -curl -debug -doc -examples -firebird -mysql -odbc -postgres -qt3 -smtp -sqlite -sqlite3" 0 kB [1]
Total: 1 package (1 new), Size of downloads: 0 kB
Portage tree and overlays:
 [0] /usr/portage
 [1] /usr/local/portage
!!! The following installed packages are masked:
- net-wireless/broadcom-sta-5.60.48.36 (masked by: Broadcom license(s))
A copy of the 'Broadcom' license is located at '/usr/portage/licenses/Broadcom'.
- dev-java/sun-jre-bin-1.6.0.19 (masked by: dlj-1.1 license(s))
A copy of the 'dlj-1.1' license is located at '/usr/portage/licenses/dlj-1.1'.
- games-fps/quake3-data-1.32b (masked by: Q3AEULA license(s))
A copy of the 'Q3AEULA' license is located at '/usr/portage/licenses/Q3AEULA'.
- dev-java/sun-jdk-1.6.0.19 (masked by: dlj-1.1 license(s))
- games-fps/enemy-territory-2.60b (masked by: RTCW-ETEULA license(s))
A copy of the 'RTCW-ETEULA' license is located at '/usr/portage/licenses/RTCW-ETEULA'.
 * IMPORTANT: 4 news items need reading for repository 'gentoo'.
 * Use eselect news to read news items.
Many thanks and sorry for my poor English
Post by Fitzcarraldo » Sat Apr 17, 2010 20:33
Well, you could have used Google to find out how to apply a diff file, which is what I have just done now. Actually, if you look inside the diff file, this particular diff file is so simple that you could edit the ebuild file manually. See the line with the minus sign in front of it? That means "replace this line in gambas-2.16.0.ebuild with the line after it here with the plus sign in front of it". See the the line with the plus sign in front of it? That means "put this line in gambas-2.16.0.ebuild to replace the line shown here with the minus sign in front of it".
But, to do it automatically (I'm assuming you downloaded the files to your Desktop), you could use the commands:
# cd /home/raregazz/Desktop
# patch < gambas-2.20.0.ebuild.diff
# mv gambas-2.16.0.ebuild gambas-2.20.0.ebuild
Delete the diff file that you copied to the /usr/local/portage/dev-lang/gambas/ directory, as that should not be there. The purpose of the diff file is to show the difference between the files gambas-2.16.0.ebuild and gambas-2.20.0.ebuild.
You need to build the latest version of Gambas (gambas-2.20.0) so why did you create a manifest for the old version 2.16.0?
Here's what you should have done after you created the file gambas-2.20.0.ebuild, either by manually editing it or by applying the diff file, assuming the files are on your Desktop:
# mkdir -p /usr/local/portage/dev-lang/gambas/files/
# cp /home/raregazz/Desktop/gambas-2.20.0.ebuild /usr/local/portage/dev-lang/gambas/
# cp /home/raregazz/Desktop/gambas-2.20.0-FLAGS.patch /usr/local/portage/dev-lang/gambas/files/
# cd /usr/local/portage/dev-lang/gambas
# ebuild gambas-2.20.0.ebuild manifest
# emerge -1v gambas
Before you do the above, make sure that the file /etc/make.conf contains the line:
PORTDIR_OVERLAY="${PORTDIR_OVERLAY} /usr/local/portage/"
While you're at it, also add the following line in case Gambas requires a licence agreement:
ACCEPT_LICENSE="*"
And, just to get rid of Portage's nagging about a missing name for your local overlay:
# mkdir /usr/local/portage/profiles
# echo "local_overlay" > /usr/local/portage/profiles/repo_name
I have not tried to build Gambas myself, so I don't know if it will build.
raregazz
Post by raregazz » Sat Apr 17, 2010 21:05
Thanks for yor reply and sorry for "diff patch".
I' ve make all you said but impossible to install.
raregazz-laptop gambas # emerge -1v gambas
This is the log file...
[33;01m*[0m Please fix your ebuild to not inherit the deprecated qt3.eclass
 [32;01m*[0m CPV:  dev-lang/gambas-2.20.0
 [32;01m*[0m REPO:
 [32;01m*[0m USE:  bzip2 elibc_glibc gtk kernel_linux opengl pcre pdf sdl svg userland_GNU v4l x86 xml zlib
 [32;01m*[0m
 [33;01m*[0m The Gambas IDE currently cannot be be build without Qt being enabled.
 [32;01m*[0m
 [33;01m*[0m You are using the USE flag gtk, but not qt3.  Attempting to use GTK instead
 [33;01m*[0m of Qt for certain components.  This is considered EXPERIMENTAL and the
 [33;01m*[0m resulting components may not function.
 [32;01m*[0m
>>> Unpacking source...
>>> Unpacking gambas2-2.20.0.tar.bz2 to /var/tmp/portage/dev-lang/gambas-2.20.0/work
>>> Source unpacked in /var/tmp/portage/dev-lang/gambas-2.20.0/work
>>> Preparing source in /var/tmp/portage/dev-lang/gambas-2.20.0/work/gambas2-2.20.0 ...
 [32;01m*[0m Applying sed no-Qt-use-GTK-workaround-patch (EXPERIMENTAL) ...
[A[136C  [34;01m[ [32;01mok[34;01m ][0m
 [32;01m*[0m Applying sed no-automagic-patch ...
 [31;01m*[0m Cannot find $EPATCH_SOURCE!  Value for $EPATCH_SOURCE is:
 [31;01m*[0m
 [31;01m*[0m   /usr/local/portage/dev-lang/gambas/files/gambas-2.8.0-libtool.patch
 [31;01m*[0m   ( gambas-2.8.0-libtool.patch )
 [31;01m*[0m ERROR: dev-lang/gambas-2.20.0 failed:
 [31;01m*[0m
 [31;01m*[0m Call stack:
 [31;01m*[0m     ebuild.sh, line   48:  Called src_prepare
 [31;01m*[0m   environment, line 3123:  Called epatch '/usr/local/portage/dev-lang/gambas/files/gambas-2.8.0-libtool.patch'
 [31;01m*[0m   environment, line 1727:  Called die
 [31;01m*[0m The specific snippet of code:
 [31;01m*[0m               die "Cannot find \$EPATCH_SOURCE!";
 [31;01m*[0m
 [31;01m*[0m If you need support, post the output of 'emerge --info =dev-lang/gambas-2.20.0',
 [31;01m*[0m the complete build log and the output of 'emerge -pqv =dev-lang/gambas-2.20.0'.
 [31;01m*[0m This ebuild is from an overlay: '/usr/local/portage/'
 [31;01m*[0m The complete build log is located at '/var/lib/entropy/logs/dev-lang:gambas-2.20.0:20100417-194306.log'.
 [31;01m*[0m The ebuild environment file is located at '/var/tmp/portage/dev-lang/gambas-2.20.0/temp/environment'.
 [31;01m*[0m S: '/var/tmp/portage/dev-lang/gambas-2.20.0/work/gambas2-2.20.0'
And downloading and copying the file gambas-2.8.0-libtool.patch in files directory...
 [32;01m*[0m REPO:
 [32;01m*[0m
 [32;01m*[0m
 [32;01m*[0m
>>> Unpacking source...
 [32;01m*[0m Applying gambas-2.8.0-libtool.patch ...
 [31;01m*[0m Failed Patch: gambas-2.8.0-libtool.patch !
 [31;01m*[0m  ( /usr/local/portage/dev-lang/gambas/files/gambas-2.8.0-libtool.patch )
 [31;01m*[0m
 [31;01m*[0m Include in your bugreport the contents of:
 [31;01m*[0m
 [31;01m*[0m   /var/tmp/portage/dev-lang/gambas-2.20.0/temp/gambas-2.8.0-libtool.patch.out
 [31;01m*[0m   Failed Patch: gambas-2.8.0-libtool.patch!
 [31;01m*[0m
 [31;01m*[0m   environment, line 1842:  Called die
 [31;01m*[0m               die "Failed Patch: ${patchname}!";
 [31;01m*[0m
 [31;01m*[0m The complete build log is located at '/var/lib/entropy/logs/dev-lang:gambas-2.20.0:20100417-195817.log'.
I am desperate, I don't know more to try.
Thanks man!
Post by Fitzcarraldo » Sat Apr 17, 2010 22:40
Just to see what happens, before we try to sort through the problem with the 2.20.0 version, try to build the 2.16.0 version using the original gambas-2.16.0.ebuild downloaded from the site I gave the link for earlier:
# cd ebuild /usr/local/portage/dev-lang/gambas
# cp /home/raregazz/Desktop/gambas-2.16.0.ebuild /usr/local/portage/dev-lang/gambas/
# emerge -1v gambas
Post by Fitzcarraldo » Sat Apr 17, 2010 22:45
Looking quickly at your error messages, some other things to try:
# USE="-gtk qt3" emerge -1v gambas
# USE="-gtk" emerge -1v gambas
# USE="-qt3" emerge -1v gambas
# USE="qt3" emerge -1v gambas
Post by Fitzcarraldo » Sat Apr 17, 2010 23:13
Looking at your error message again and Comment #6 in the Gentoo Bugzilla Report that I linked to earlier, you also have to switch off the xml USE flag, so add "-xml" into the list of USE flags before the emerge command.
raregazz
Post by raregazz » Sun Apr 18, 2010 0:52
Thanks Fitzcarraldo for your answers...
I tried all possible combinations that you told but it's impossible.
Neither 2.16 , 2.20. I think that the problem resides in qt3 libraries that aren't available (¿incompatibility?) in Sabayon 5.2 version.
Otherwise many thanks for your comprehension and help.
I desist of installing this great IDE in Sabayon. The solution will be to install another distribution with VBox to work there with Gambas 2.20.
Thanks and best regards from Spain.
Post by Fitzcarraldo » Sun Apr 18, 2010 5:58
OK. Due to the Eyjafjallajokull volcano eruption I'm stuck half way around the world from home, so it's not a good time for me to look at it in more detail at the moment. When I eventually manage to get home I'll have another try, to see if I can find a way to get it to build. Until then, saludos.
