CPU Meter from LiveCD
seagoj
Post by seagoj » Thu May 28, 2009 21:02
Sorry for the lame question, but I can't seem to find the cpu meter that's running on the LiveCD version of Sabayon 4.1. Does anyone know the name of the program?
kodiakmax
Re: CPU Meter from LiveCD
Post by kodiakmax » Thu May 28, 2009 22:33
I don't have 4.1 disk laying around at the moment and my Virtualbox is on the fritz, but I imagine that you are probably refering to either conky or superkaramba
joeoden
Location: Back in the 'swamp land' Moe, Australia 38°10′20″S 146°16′04″E
Post by joeoden » Fri May 29, 2009 1:47
There are a few
Do you mean System Monitor, if so you can find it by clicking on
Kickoff Application Launcher-Applicataions-System-System Monitor
Click on the System Load tab
Also have a look at Add Widget for the Desktop or Taskbar
Have fun
Joe
Desktop ASUS M2N-MX SE Plus, AMD 64 X2 Dual Core 5200, 4 Gb RAM, GeForce 9500 1GB
Notebook HP CQ61-311AX, AMD CPU M320, 4 Gb RAM, Radeon HD 4300 512 MB
Wireless AR9285, Audio ATI SBx00 (IDT 92hd75B2x5)
Some mistakes are too much fun to only make once!
