xbmc error [Solved]
xbmc error [Solved]
Postby Miles C. » Wed May 06, 2009 21:37
I'm not sure if this is where this is supposed to go, but I guess it's a good a guess as anything.
I just installed Sabayon 4.1 G. Everything worked great. Specifically, xbmc worked great.
I then opened up Spritz, and updated the hundred and some packages it had for me. I restarted, tried to run xbmc, and get this:
X Error of failed request:  BadValue (integer parameter out of range for operation)
  Major opcode of failed request:  157 (GLX)
  Minor opcode of failed request:  3 (X_GLXCreateContext)
  Value in failed request:  0x21
  Serial number of failed request:  19
  Current serial number in output stream:  19
Any idea how to solve? Or what information should I go fetch to better determine the problem?
Miles C.
Re: xbmc error
Postby kodiakmax » Wed May 06, 2009 21:44
that error leads me to believe that something is amiss with your graphics setup.
check your
eselect opengl list
make sure it is set correctly
check your glxinfo and glxgears output
and
check your xorg.conf for the correct options.
kodiakmax
Re: xbmc error
Postby Miles C. » Wed May 06, 2009 22:09
Solved!
eselect opengl set nvidia
did the trick. Thanks for your help!
Miles C.
