chm viewer [Solved]
chm viewer [Solved]
Postby andreas_g » Sat May 02, 2009 14:27
Hi!!!!!
This is my first post!!!!!!!!!!!! :P :P
I have a little problem with my Sabayon 4.1
I can not find kchmviewer in spritz or the konsole(equo install kchmviewer)
What can I do????????????
Sorry for my bad english!!!!!!!
andreas_g
Re: chm viewer
Postby asygxwrhtos » Sat May 02, 2009 18:53
You can install kchmviewer via emerge. First update emerge userland
# sudo emerge --sync && sudo layman -S
then install kchmviewer
# sudo emerge kchmviewer
Another alternative is xchm (that I am using)
-asygxwrhtos
asygxwrhtos
Re: chm viewer
Postby mobilehunter » Sat May 02, 2009 22:59
Or you can use okular.
If you are using Sabayon 4.1 kde x86 version, you can use directly.
But for x86_64, you have to upgrade your okular.
mobilehunter
Re: chm viewer
Postby andreas_g » Sun May 03, 2009 4:13
Thank you guys for your answers!!!!!
Okular finally works! :)
&asygxwrhtos:
I couldn't install kchmviewer because okular package block it!!!
<Greek>
Παντως φιλε asygxwrhtos εχει πλακα γιατι στο πρωτο μου post εκτος ελλαδας μου απαντησε ελληνας!!!!!
Ευχαριστω παντως! :D :wink:
</Greek>
andreas_g
