.WM, .WMA, .WMV -files and watching them in Firefox
Pontux
Post by Pontux » Fri Apr 24, 2009 20:04
Those files aren't working out of box and haven't found solution yet to watch em in Firefox.
Web TV's like http://areena.yle.fi doesn't work at all in firefox. Have you been able to make these formats to work. I have Sabayon 4.1 Gnome installed on my laptop and this is so far only mediafile probleam, I've had. So I don't want to change distro cause of this.
Re: .WM, .WMA, .WMV -files and watching them in Firefox
Post by joost » Fri Apr 24, 2009 20:39
they work here. (i use vlc)
My blog | Twitter
Please support Sabayon: Image
Pontux
Post by Pontux » Fri Apr 24, 2009 21:22
Nice. Should I do something for my plugins or programs? I have plenty of plugins(also VLC) in use when i check them from firefox add-on menu. But how do I configure VLC for example to be default?
kodiakmax
Post by kodiakmax » Fri Apr 24, 2009 22:03
try opening the stream in totem it should prompt you for the correct plugin package to install.
failing that try to install all gst-plugin packages
Pontux
Post by Pontux » Sat Apr 25, 2009 7:42
First one didn't work, but when I installed all gst-plugin packages, videos started workin BUT sounds still won't work in totem. What should i do? Could i use vlc in firefox and how can i change that?
pepe999
Post by pepe999 » Sat May 09, 2009 14:28
For playing windows media formats I recommend vlc and an addon for Firefox called mediaplayerconnectivity.
https://addons.mozilla.org/en-US/firefo ... ty&cat=all
Very usefull plugin and works with Mplayer too..:)
Dell L502X - Core i7-2840QM/8GB DDR3/GF 540M 2GB/Corsair GT 240GB/Full HD
Debian 7
Win 7 still installed
Linux user no. 491024
