Miro miro-2.0.3-r1.ebuild HOWTO (advanced)
Postby chickpea » Tue Apr 21, 2009 19:06
NOTE: Now a WIKI PAGE http://wiki.sabayonlinux.org/index.php?title=HOWTO:_Install_Miro_2.0.3_before_it_finds_its_way_into_Entropy
Ok so I got sick of Miro 1.2.4 not working anymore and wanted to try the new Miro2.0.3
It actually emerged without much difficulty.
Here's my setup. I run a fully updated x86-64 entropy install (so all binary) with kde4.2. For this you will need:
1. A recently synced portage tree,
2. The latest miro ebuild here: http://bugs.gentoo.org/attachment.cgi?id=187487
3. A custom layman repository
4. A decent working knowledge of how to create a custom local repo (so be able to set up something in /usr/portage/local/layman with proper portage tree structure)
Ok, let's get started:
First do a
equo update && equo world
Now we will
 emerge --sync
ok now create our custom repo
 mkdir /usr/portage/local/layman/customebuilds
cd /usr/portage/local/layman/customebuilds
mkdir media-tv/
cd media-tv/
mkdir miro
cp /whereever/miro-2.0.3-r1.ebuild /usr/portage/local/layman/customebuilds/media-tv/miro
Ok now update your make.conf
 nano /usr/portage/local/layman/make.conf
add a line for /usr/portage/local/layman/customebuilds
alright, now
 cd /usr/portage/local/layman/customebuilds/media-tv/miro
ebuild miro-2.0.3-r1.ebuild digest
Ok now we will need to clean up some GNOME typos and assorted other issues.
FIrst,
nano /usr/lib/pkgconfig/pm-utils.pc
you need to change
pm_powerhooks=${pm_libdir)/power.d
to
pm_powerhooks=${pm_libdir}/power.d
save and close
next
equo install dri2proto
a build dependency that is not pulled in by the ebuild.
Now the fun part
 emerge -av miro
use ask to make sure you got your ebuild ready to compile and if it's right, let er rip!
Should compile fine now and run like a charm.
chickpea
Re: Miro miro-2.0.3-r1.ebuild HOWTO (advanced)
Postby wolfden » Wed Apr 22, 2009 6:01
can u please put this in the wiki
thanks
Postby Thev00d00 » Wed Apr 22, 2009 11:28
make a patch and call epatch or use sed to change the gnome line, then add the missing dep to the ebuild?
Website / Blog : v00d00.net
twitter: Follow Me
G+: Circle Me
Thev00d00
Generally Awesome (tm)
Postby chickpea » Wed Apr 22, 2009 13:41
wolfden wrote:can u please put this in the wiki
thanks
sure. I'll try to do that today.
chickpea
Postby chickpea » Wed Apr 22, 2009 13:47
Thev00d00 wrote:make a patch and call epatch or use sed to change the gnome line, then add the missing dep to the ebuild?
Errm, well, I'm not sure how to write a patch (although I do know how to mod an ebuild to call epatch). Maybe I should learn . . . just don't have the time right now.
Sure, I could sed it, but that would require me to know how to use sed. :P I know, I know, it's like the top three in terms of CLI MUST commands to know, but I have always put off learning how to use it, because, well I don't generally need to change that many lines or automate any sort of corrections. I did read the man page at one point, does that count?
Don't know how to add a missing DEPEND or RDEPEND to an ebuild, as I don't really know the difference between the two. all I know is emerge errored out when config script was looking for dri2proto, checked and it wasn't installed, so I installed it.
chickpea
Postby Thev00d00 » Wed Apr 22, 2009 14:33
DEPEND is a build dependency, i.e must be installed before the package
RDEPEND is a runtime dependency, i.e must be installed for the package to run
to make a patach use diff, however I notice you are changing a system file so you will need to patch package that owns this file instead (can be found with equery f path/to/file)
twitter: Follow Me
G+: Circle Me
Thev00d00
Postby chickpea » Wed Apr 22, 2009 16:36
Thev00d00 wrote:DEPEND is a build dependency, i.e must be installed before the package
awesome. Thanks for that quick lesson. So therefore (as I suspected) dri2proto is a build-time dep, therefore DEPEND must include dri2proto.
For the patch, as I said, probably just easier to do this by hand and then just file a bug for the package upstream.
New fancy wiki on this topic. :D May not be perfect but it's the best I could do in 30 min.
chickpea
Postby Thev00d00 » Wed Apr 22, 2009 16:54
Ebuilds ftw, you could also have a "lil hack" on the live filesystem in pkg_preinst to fix the issue
pkg_preinst() {
sed  -i s/"pm_libdir\)"/"pm_libdir\}"/g /path/to/file << needs regex, can be improved (/me is at work)
or
patch /path/to/file ${FILESDIR}/path/topatch.patch
(epatch wont work here)
twitter: Follow Me
G+: Circle Me
Thev00d00
Postby croweland01 » Sat Jun 06, 2009 15:27
Are you sure about this?
I haven't sub dir local under portage but I have /usr/local/portage.
Normally in my make.conf I add:
PORTDIR_OVERLAY=/usr/local/portage
Now I must create subdir under portage; /local/layman/customebuilds, what I shoud add in my make.conf?
PORTDIR_OVERLAY=/usr/local/layman/customebuilds? :oops:
croweland01
Postby wolfden » Sat Jun 06, 2009 16:07
/usr/local/layman/customebuilds isn't the normal way of doing it, you can use the correct way, just change it around
