I have troubles starting K3B, It just wont start, I have to reboot. And then it will usually work. When it does work sometimes it will lock up, I've tried to kill the process with kill -9 pid#, and that does not work. The only way I can restart is to reboot. Does anyone have any ideas ?
I am on an AMD64 dual core, and running 2.6.26-sabayon.
thanks for your help!
