Firefox stability [Solved]
Postby Jajo » Thu Mar 19, 2009 16:13
hi, i'd like to know if firefox is so unstable only in my SL installation or if is a general issue.
i've SL4.r2 MCE and i updated firefox to 3.07 compiling with emerge, but still some pages make it crash..
what can i do?
PS: i'm on a amd64 machine with a x86_64 version of SL
I've just installed the 32 bit version of firefox..
Jajo
Re: Firefox stability
Postby Thev00d00 » Thu Mar 19, 2009 20:21
its probably your addon / plugin combination, disable any you dont use
also try the 64bit flash, unistall nspluginwrapper emerge with USE="-32bit"
Website / Blog : v00d00.net
twitter: Follow Me
G+: Circle Me
Thev00d00
Generally Awesome (tm)
Postby Fitzcarraldo » Fri Mar 20, 2009 19:26
I'm using 64-bit Firefox 3.0.7 in SL x86_64 on an Intel Core 2 Duo laptop with no instability. You can see exactly what I have installed below:
# eselect java-nsplugin list
Available 32-bit Java browser plugins
Available 64-bit Java browser plugins
  [1]   icedtea6-bin
  [2]   sun-jdk-1.6  current
# eix -I sun-jdk
[I] dev-java/sun-jdk
     Available versions:
        (1.4)   *1.4.2.19!f!s
        (1.5)   1.5.0.17!s
        (1.6)   1.6.0.11!s 1.6.0.12!s
        {X alsa doc examples jce nsplugin odbc}
     Installed versions:  1.6.0.12(1.6)!s(01:55:54 14/03/09)(X alsa nsplugin -doc -examples -jce -odbc)
     Homepage:            http://java.sun.com/javase/6/
     Description:         Sun's J2SE Development Kit, version 1.6.0.12
# eix -I icedtea
[I] dev-java/icedtea6-bin
     Available versions:  (~)1.3.1-r1!s!t (~)1.4!s {X alsa doc examples nsplugin source}
     Installed versions:  1.4!s(02:02:29 14/03/09)(X alsa nsplugin -doc -examples -source)
     Homepage:            http://icedtea.classpath.org
     Description:         A Gentoo-made binary build of the icedtea6 JDK
# eix mozilla-firefox
[I] www-client/mozilla-firefox
     Available versions:  2.0.0.19 3.0.7 {bindist custom-optimization dbus debug filepicker gnome iceweasel ipv6 java linguas_af linguas_ar linguas_be linguas_bg linguas_bn linguas_bn_IN linguas_ca linguas_cs linguas_cy linguas_da linguas_de linguas_el linguas_en linguas_en_GB linguas_en_US linguas_eo linguas_es linguas_es_AR linguas_es_ES linguas_et linguas_eu linguas_fi linguas_fr linguas_fy linguas_fy_NL linguas_ga linguas_ga_IE linguas_gl linguas_gu linguas_gu_IN linguas_he linguas_hi linguas_hi_IN linguas_hu linguas_id linguas_is linguas_it linguas_ja linguas_ka linguas_kn linguas_ko linguas_ku linguas_lt linguas_lv linguas_mk linguas_mn linguas_mr linguas_nb linguas_nb_NO linguas_nl linguas_nn linguas_nn_NO linguas_oc linguas_pa linguas_pa_IN linguas_pl linguas_pt linguas_pt_BR linguas_pt_PT linguas_ro linguas_ru linguas_si linguas_sk linguas_sl linguas_sq linguas_sr linguas_sv linguas_sv_SE linguas_te linguas_th linguas_tr linguas_uk linguas_zh linguas_zh_CN linguas_zh_TW mozdevelop moznopango restrict-javascript startup-notification xforms xinerama xprint xulrunner}
     Installed versions:  3.0.7(21:55:12 13/03/09)(dbus gnome linguas_en mozdevelop startup-notification xulrunner -bindist -custom-optimization -iceweasel -java -linguas_af -linguas_ar -linguas_be -linguas_bg -linguas_bn -linguas_bn_IN -linguas_ca -linguas_cs -linguas_cy -linguas_da -linguas_de -linguas_el -linguas_en_GB -linguas_en_US -linguas_eo -linguas_es -linguas_es_AR -linguas_es_ES -linguas_et -linguas_eu -linguas_fi -linguas_fr -linguas_fy -linguas_fy_NL -linguas_ga -linguas_ga_IE -linguas_gl -linguas_gu -linguas_gu_IN -linguas_he -linguas_hi -linguas_hi_IN -linguas_hu -linguas_id -linguas_is -linguas_it -linguas_ja -linguas_ka -linguas_kn -linguas_ko -linguas_ku -linguas_lt -linguas_lv -linguas_mk -linguas_mn -linguas_mr -linguas_nb -linguas_nb_NO -linguas_nl -linguas_nn -linguas_nn_NO -linguas_oc -linguas_pa -linguas_pa_IN -linguas_pl -linguas_pt -linguas_pt_BR -linguas_pt_PT -linguas_ro -linguas_ru -linguas_si -linguas_sk -linguas_sl -linguas_sq -linguas_sr -linguas_sv -linguas_sv_SE -linguas_te -linguas_th -linguas_tr -linguas_uk -linguas_zh -linguas_zh_CN -linguas_zh_TW -restrict-javascript)
     Homepage:            http://www.mozilla.com/firefox
     Description:         Firefox Web Browser
* www-client/mozilla-firefox-bin
     Available versions:  2.0.0.19!s 3.0.7!s [M](~)3.1_beta2!s [M](~)3.1_beta3!s {linguas_af linguas_ar linguas_be linguas_bg linguas_bn linguas_bn_IN linguas_ca linguas_cs linguas_cy linguas_da linguas_de linguas_el linguas_en linguas_en_GB linguas_en_US linguas_eo linguas_es linguas_es_AR linguas_es_ES linguas_et linguas_eu linguas_fa linguas_fi linguas_fr linguas_fy linguas_fy_NL linguas_ga linguas_ga_IE linguas_gl linguas_gu linguas_gu_IN linguas_he linguas_hi linguas_hi_IN linguas_hu linguas_id linguas_is linguas_it linguas_ja linguas_ka linguas_kn linguas_ko linguas_ku linguas_lt linguas_lv linguas_mk linguas_ml linguas_mn linguas_mr linguas_nb linguas_nb_NO linguas_nl linguas_nn linguas_nn_NO linguas_oc linguas_pa linguas_pa_IN linguas_pl linguas_pt linguas_pt_BR linguas_pt_PT linguas_ro linguas_ru linguas_si linguas_sk linguas_sl linguas_sq linguas_sr linguas_sv linguas_sv_SE linguas_te linguas_th linguas_tr linguas_uk linguas_vi linguas_zh linguas_zh_CN linguas_zh_TW restrict-javascript}
Found 2 matches.
# eix -I nspluginwrapper
No matches found.
# eix -I netscape-flash
[I] net-www/netscape-flash
     Available versions:  (~)9.0.159.0!m!s 10.0.15.3!m!s 10.0.22.87!m!s {32bit multilib}
     Installed versions:  10.0.22.87!m!s(01:48:47 14/03/09)(multilib)
     Homepage:            http://www.adobe.com/
     Description:         Adobe Flash Player
Result of typing about:plugins into the Firefox address bar:
Installed plugins
Find more information about browser plugins at mozilla.org.
Help for installing plugins is available from plugindoc.mozdev.org.
VLC Multimedia Plug-in
    File name: libvlcplugin.so
    Version 0.9.8a Grishenko, copyright 1996-2007 The VideoLAN Team
    http://www.videolan.org/
MIME Type    Description    Suffixes    Enabled
audio/mpeg    MPEG audio    mp2,mp3,mpga,mpega    Yes
audio/x-mpeg    MPEG audio    mp2,mp3,mpga,mpega    Yes
video/mpeg    MPEG video    mpg,mpeg,mpe    Yes
video/x-mpeg    MPEG video    mpg,mpeg,mpe    Yes
video/mpeg-system    MPEG video    mpg,mpeg,mpe,vob    Yes
video/x-mpeg-system    MPEG video    mpg,mpeg,mpe,vob    Yes
audio/x-mpegurl    MPEG audio    m3u    Yes
video/mp4    MPEG-4 video    mp4,mpg4    Yes
audio/mp4    MPEG-4 audio    mp4,mpg4    Yes
audio/x-m4a    MPEG-4 audio    m4a    Yes
application/mpeg4-iod    MPEG-4 video    mp4,mpg4    Yes
application/mpeg4-muxcodetable    MPEG-4 video    mp4,mpg4    Yes
video/x-msvideo    AVI video    avi    Yes
video/quicktime    QuickTime video    mov,qt    Yes
application/x-ogg    Ogg stream    ogg    Yes
application/ogg    Ogg stream    ogg    Yes
application/x-vlc-plugin    VLC plug-in    vlc    Yes
video/x-ms-asf-plugin    Windows Media Video    asf,asx    Yes
video/x-ms-asf    Windows Media Video    asf,asx    Yes
application/x-mplayer2    Windows Media       Yes
video/x-ms-wmv    Windows Media    wmv    Yes
video/x-ms-wvx    Windows Media Video    wvx    Yes
audio/x-ms-wma    Windows Media Audio    wma    Yes
application/x-google-vlc-plugin    Google VLC plug-in       Yes
audio/wav    WAV audio    wav    Yes
audio/x-wav    WAV audio    wav    Yes
audio/3gpp    3GPP audio    3gp,3gpp    Yes
video/3gpp    3GPP video    3gp,3gpp    Yes
audio/3gpp2    3GPP2 audio    3g2,3gpp2    Yes
video/3gpp2    3GPP2 video    3g2,3gpp2    Yes
video/divx    DivX video    divx    Yes
video/flv    FLV video    flv    Yes
video/x-flv    FLV video    flv    Yes
video/x-matroska    Matroska video    mkv    Yes
audio/x-matroska    Matroska audio    mka    Yes
application/xspf+xml    Playlist xspf    xspf    Yes
Shockwave Flash
    File name: libflashplayer.so
    Shockwave Flash 10.0 r22
application/x-shockwave-flash    Shockwave Flash    swf    Yes
application/futuresplash    FutureSplash Player    spl    Yes
libnpjp2.so
    File name: libnpjp2.so
application/x-java-vm    Java       Yes
application/x-java-applet    Java       Yes
application/x-java-applet;version=1.1    Java       Yes
application/x-java-applet;version=1.1.1    Java       Yes
application/x-java-applet;version=1.1.2    Java       Yes
application/x-java-applet;version=1.1.3    Java       Yes
application/x-java-applet;version=1.2    Java       Yes
application/x-java-applet;version=1.2.1    Java       Yes
application/x-java-applet;version=1.2.2    Java       Yes
application/x-java-applet;version=1.3    Java       Yes
application/x-java-applet;version=1.3.1    Java       Yes
application/x-java-applet;version=1.4    Java       Yes
application/x-java-applet;version=1.4.1    Java       Yes
application/x-java-applet;version=1.4.2    Java       Yes
application/x-java-applet;version=1.5    Java       Yes
application/x-java-applet;version=1.6    Java       Yes
application/x-java-applet;jpi-version=1.6.0_12    Java       Yes
application/x-java-bean    Java       Yes
application/x-java-bean;version=1.1    Java       Yes
application/x-java-bean;version=1.1.1    Java       Yes
application/x-java-bean;version=1.1.2    Java       Yes
application/x-java-bean;version=1.1.3    Java       Yes
application/x-java-bean;version=1.2    Java       Yes
application/x-java-bean;version=1.2.1    Java       Yes
application/x-java-bean;version=1.2.2    Java       Yes
application/x-java-bean;version=1.3    Java       Yes
application/x-java-bean;version=1.3.1    Java       Yes
application/x-java-bean;version=1.4    Java       Yes
application/x-java-bean;version=1.4.1    Java       Yes
application/x-java-bean;version=1.4.2    Java       Yes
application/x-java-bean;version=1.5    Java       Yes
application/x-java-bean;version=1.6    Java       Yes
application/x-java-bean;jpi-version=1.6.0_12    Java       Yes
Totem Web Browser Plugin 2.24.3
    File name: libtotem-basic-plugin.so
    The Totem 2.24.3 plugin handles video and audio streams.
application/x-ogg    Ogg multimedia file    ogg    Yes
application/ogg    Ogg multimedia file    ogg    Yes
audio/ogg    Ogg Audio    oga    Yes
audio/x-ogg    Ogg Audio    ogg    Yes
video/ogg    Ogg Video    ogv    Yes
video/x-ogg    Ogg Video    ogg    Yes
application/annodex    application/annodex type    anx    Yes
audio/annodex    audio/annodex type    axa    Yes
video/annodex    video/annodex type    axv    Yes
video/mpeg    MPEG video    mpg, mpeg, mpe    Yes
audio/mpeg    MP3 audio    mp3    Yes
application/x-nsv-vp3-mp3    NullSoft video    nsv    Yes
video/flv    Flash video    flv    Yes
application/x-totem-plugin    Totem Multimedia plugin       Yes
VLC Multimedia Plugin (compatible Totem 2.24.3)
    File name: libtotem-cone-plugin.so
application/x-vlc-plugin    VLC Multimedia Plugin       Yes
application/vlc    VLC Multimedia Plugin       Yes
video/x-google-vlc-plugin    VLC Multimedia Plugin       Yes
Windows Media Player Plug-in 10 (compatible; Totem)
    File name: libtotem-gmp-plugin.so
application/x-mplayer2    AVI video    avi, wma, wmv    Yes
video/x-ms-asf-plugin    ASF video    asf, wmv    Yes
video/x-msvideo    AVI video    asf, wmv    Yes
video/x-ms-asf    ASF video    asf    Yes
video/x-ms-wmv    Windows Media video    wmv    Yes
video/x-wmv    Windows Media video    wmv    Yes
video/x-ms-wvx    Windows Media video    wmv    Yes
video/x-ms-wm    Windows Media video    wmv    Yes
video/x-ms-wmp    Windows Media video    wmv    Yes
application/x-ms-wms    Windows Media video    wms    Yes
application/x-ms-wmp    Windows Media video    wmp    Yes
application/asx    Microsoft ASX playlist    asx    Yes
audio/x-ms-wma    Windows Media audio    wma    Yes
DivX® Web Player
    File name: libtotem-mully-plugin.so
    DivX Web Player version 1.4.0.233
video/divx    AVI video    divx    Yes
QuickTime Plug-in 7.2.0
    File name: libtotem-narrowspace-plugin.so
video/quicktime    QuickTime video    mov    Yes
video/mp4    MPEG-4 video    mp4    Yes
image/x-macpaint    MacPaint Bitmap image    pntg    Yes
image/x-quicktime    Macintosh Quickdraw/PICT drawing    pict, pict1, pict2    Yes
video/x-m4v    MPEG-4 video    m4v    Yes
DivX Browser Plug-In
    File name: mplayerplug-in-dvx.so
    mplayerplug-in 3.55
    Video Player Plug-in for QuickTime, RealPlayer and Windows Media Player streams using MPlayer
    JavaScript Enabled and Using X Widgets
video/divx    DivX Media Format    divx    Yes
video/vnd.divx    DivX Media Format    divx    Yes
Google VLC multimedia plugin 1.0
    File name: mplayerplug-in-gmp.so
    mplayerplug-in 3.55
application/x-google-vlc-plugin    Google Video       Yes
QuickTime Plug-in 7.4.5
    File name: mplayerplug-in-qt.so
    mplayerplug-in 3.55
video/quicktime    Quicktime    mov    Yes
video/x-quicktime    Quicktime    mov    Yes
image/x-quicktime    Quicktime    mov    Yes
video/quicktime    Quicktime    mp4    Yes
video/quicktime    Quicktime - Session Description Protocol    sdp    Yes
application/x-quicktimeplayer    Quicktime    mov    Yes
application/smil    SMIL    smil    Yes
RealPlayer 9
    File name: mplayerplug-in-rm.so
    mplayerplug-in 3.55
audio/x-pn-realaudio    RealAudio    ram,rm    Yes
application/vnd.rn-realmedia    RealMedia    rm    Yes
application/vnd.rn-realaudio    RealAudio    ra,ram    Yes
video/vnd.rn-realvideo    RealVideo    rv    Yes
audio/x-realaudio    RealAudio    ra    Yes
audio/x-pn-realaudio-plugin    RealAudio    rpm    Yes
    File name: mplayerplug-in-wmp.so
    mplayerplug-in 3.55
application/asx    Media Files    *    Yes
video/x-ms-asf-plugin    Media Files    *    Yes
video/x-msvideo    AVI    avi,*    Yes
video/msvideo    AVI    avi,*    Yes
application/x-mplayer2    Media Files    *    Yes
application/x-ms-wmv    Microsoft WMV video    wmv,*    Yes
video/x-ms-asf    Media Files    asf,asx,*    Yes
video/x-ms-wm    Media Files    wm,*    Yes
video/x-ms-wmv    Microsoft WMV video    wmv,*    Yes
audio/x-ms-wmv    Windows Media    wmv,*    Yes
video/x-ms-wmp    Windows Media    wmp,*    Yes
application/x-ms-wmp    Windows Media    wmp,*    Yes
video/x-ms-wvx    Windows Media    wvx,*    Yes
audio/x-ms-wax    Windows Media    wax,*    Yes
audio/x-ms-wma    Windows Media    wma,*    Yes
application/x-drm-v2    Windows Media    asx,*    Yes
audio/wav    Microsoft wave file    wav,*    Yes
audio/x-wav    Microsoft wave file    wav,*    Yes
mplayerplug-in 3.55
    File name: mplayerplug-in.so
    mplayerplug-in 3.55
video/mpeg    MPEG    mpg,mpeg    Yes
audio/mpeg    MPEG    mpg,mpeg    Yes
video/x-mpeg    MPEG    mpg,mpeg    Yes
video/x-mpeg2    MPEG2    mpv2,mp2ve    Yes
audio/x-mpeg    MPEG    mpg,mpeg    Yes
audio/mpeg2    MPEG audio    mp2    Yes
audio/x-mpeg2    MPEG audio    mp2    Yes
video/mp4    MPEG 4 Video    mp4    Yes
video/3gpp    MPEG 4 Video    mp4,3gp    Yes
audio/mpeg3    MPEG audio    mp3    Yes
audio/x-mpeg3    MPEG audio    mp3    Yes
audio/x-mpegurl    MPEG url    m3u    Yes
audio/mp3    MPEG audio    mp3    Yes
application/x-ogg    Ogg Vorbis Media    ogg    Yes
audio/ogg    Ogg Vorbis Audio    ogg    Yes
audio/x-ogg    Ogg Vorbis Audio    ogg    Yes
application/ogg    Ogg Vorbis / Ogg Theora    ogg    Yes
audio/flac    FLAC Audio    flac    Yes
audio/x-flac    FLAC Audio    flac    Yes
video/fli    FLI animation    fli,flc    Yes
video/x-fli    FLI animation    fli,flc    Yes
video/x-flv    Flash Video    flv    Yes
video/vnd.vivo    VivoActive    viv,vivo    Yes
application/x-nsv-vp3-mp3    Nullsoft Streaming Video    nsv    Yes
audio/x-mod    Soundtracker    mod    Yes
audio/basic    Basic Audio File    au,snd    Yes
audio/x-basic    Basic Audio File    au,snd    Yes
DjVuLibre-3.5.21
    File name: nsdejavu.so
    This is the DjVuLibre-3.5.21 version of the DjVu plugin.
    See DjVuLibre.
image/x-djvu    DjVu File    djvu,djv    Yes
image/x.djvu    DjVu File       Yes
image/djvu    DjVu File       Yes
image/x-dejavu    DjVu File       Yes
image/x-iw44    DjVu File       Yes
image/vnd.djvu    DjVu File       Yes
Postby Jajo » Fri Mar 20, 2009 19:35
i'm gonna try the new flash plug for 64 bit but i don't know 'cause i tried to disable it (flash plugin) but i had no improvements..
ps: i've upgraded to 4.1 but still no changes
news: i unistalled flash and firefox is stable! now the question is: how to install flash 64bit as i put it in /opt/netscape/plugins , the directory written in pluginsreq.dat, but firefox doesn't see it...
Jajo
Postby Fitzcarraldo » Sat Mar 21, 2009 19:28
As root in a Terminal window:
emerge -C nspluginwrapper
emerge -1v netscape-flash
