Open Office compile mingw32 error
aZiXx
Post by aZiXx » Wed Mar 18, 2009 12:53
I get this error when trying to compile OOo_3.0.1_src_core.tar.bz2:
checking for external/unowinreg/unowinreg.dll... configure: WARNING: not found, will be cross-built using mingw32
configure: error: for rebuilding unowinreg.dll you need the mingw32 C++ compiler.
         Specify mingw32 g++ executable name with --with-mingwin.
         Or use prebuilt one from http://tools.openoffice.org/unowinreg_prebuild/680/ and
         put it into external/unowinreg
If I specify the config as: "./configure --with-mingwin=i586-mingw32msvc-g++", I get:
configure: error: specified MinGW32 C++ cross-compiler not found. Install it or correct name.
I looked into this mingw32, and its a port for windows to have c++ or gcc compile capability I think. So it shouldn't be needed on a linux distro.
I am on Sabayon 4 r1 x64.
This is the config.log:
This file contains any messages produced by compilers while
running configure, to aid debugging if configure makes a mistake.
It was created by configure, which was
generated by GNU Autoconf 2.61.  Invocation command line was
  $ ./configure
## Platform. ##
hostname = localhost
uname -m = x86_64
uname -r = 2.6.27-sabayon
uname -s = Linux
uname -v = #1 SMP Sat Dec 20 16:15:56 UTC 2008
/usr/bin/uname -p = Intel(R) Core(TM)2 Duo CPU E8400 @ 3.00GHz
/bin/uname -X     = unknown
/bin/arch              = unknown
/usr/bin/arch -k       = unknown
/usr/convex/getsysinfo = unknown
/usr/bin/hostinfo      = unknown
/bin/machine           = unknown
/usr/bin/oslevel       = unknown
/bin/universe          = unknown
PATH: /sbin
PATH: /bin
PATH: /usr/sbin
PATH: /usr/bin
## Core tests. ##
configure:3561: checking for grep that handles long lines and -e
configure:3635: result: /bin/grep
configure:3640: checking for egrep
configure:3718: result: /bin/grep -E
configure:3727: checking for gawk
configure:3743: found /bin/gawk
configure:3754: result: gawk
configure:3767: checking for gawk
configure:3785: found /bin/gawk
configure:3797: result: /bin/gawk
configure:3815: checking for sed
configure:3833: found /bin/sed
configure:3845: result: /bin/sed
configure:3862: checking for solenv environment
configure:3866: result: default
configure:3930: checking build system type
configure:3948: result: x86_64-unknown-linux-gnu
configure:3970: checking host system type
configure:3985: result: x86_64-unknown-linux-gnu
configure:4007: checking target system type
configure:4022: result: x86_64-unknown-linux-gnu
configure:4222: checking whether to enable crashdump feature
configure:4238: result: no
configure:4268: checking whether to turn warnings to errors
configure:4281: result: no
configure:4286: checking whether to do a debug build
configure:4297: result: no
configure:4302: checking whether to build with additional debug utilities
configure:4314: result: no, full product build
configure:4321: checking whether to include symbols into final build
configure:4345: result: no
configure:4350: checking whether to strip the solver or not.
configure:4372: checking whether to enable native CUPS support
configure:4376: result: yes
configure:4385: checking whether to enable fontconfig support
configure:4389: result: yes
configure:4399: checking whether to enable filters for legacy binary file formats (StarOffice 5.2)
configure:4403: result: no
configure:4455: checking whether to use RPATH in shared libraries
configure:4462: result: yes
configure:4466: checking whether to include MySpell dictionaries
configure:4469: result: yes
configure:4525: checking which shell to use
configure:4572: result: tcsh
configure:4594: checking for tcsh
configure:4612: found /bin/tcsh
configure:4624: result: /bin/tcsh
configure:4694: checking gcc home
configure:4701: result: /usr
configure:4760: checking for gcc
configure:4776: found /usr/bin/gcc
configure:4787: result: gcc
configure:5025: checking for C compiler version
configure:5032: gcc --version >&5
gcc (Gentoo 4.3.2 p1.1) 4.3.2
Copyright (C) 2008 Free Software Foundation, Inc.
This is free software; see the source for copying conditions.  There is NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
configure:5035: $? = 0
configure:5042: gcc -v >&5
Using built-in specs.
Target: x86_64-pc-linux-gnu
Configured with: /var/tmp/portage/sys-devel/gcc-4.3.2/work/gcc-4.3.2/configure --prefix=/usr --bindir=/usr/x86_64-pc-linux-gnu/gcc-bin/4.3.2 --includedir=/usr/lib/gcc/x86_64-pc-linux-gnu/4.3.2/include --datadir=/usr/share/gcc-data/x86_64-pc-linux-gnu/4.3.2 --mandir=/usr/share/gcc-data/x86_64-pc-linux-gnu/4.3.2/man --infodir=/usr/share/gcc-data/x86_64-pc-linux-gnu/4.3.2/info --with-gxx-include-dir=/usr/lib/gcc/x86_64-pc-linux-gnu/4.3.2/include/g++-v4 --host=x86_64-pc-linux-gnu --build=x86_64-pc-linux-gnu --disable-altivec --disable-fixed-point --enable-nls --without-included-gettext --with-system-zlib --disable-checking --disable-werror --enable-secureplt --enable-multilib --enable-libmudflap --disable-libssp --enable-libgomp --enable-cld --enable-objc-gc --enable-languages=c,c++,java,objc,obj-c++,treelang,fortran --enable-shared --enable-threads=posix --enable-__cxa_atexit --enable-clocale=gnu --with-bugurl=http://bugs.gentoo.org/ --with-pkgversion='Gentoo 4.3.2 p1.1'
Thread model: posix
gcc version 4.3.2 (Gentoo 4.3.2 p1.1)
configure:5045: $? = 0
configure:5052: gcc -V >&5
gcc: '-V' option must have argument
configure:5055: $? = 1
configure:5078: checking for C compiler default output file name
configure:5105: gcc    conftest.c  >&5
configure:5108: $? = 0
configure:5146: result: a.out
configure:5163: checking whether the C compiler works
configure:5173: ./a.out
configure:5176: $? = 0
configure:5193: result: yes
configure:5200: checking whether we are cross compiling
configure:5202: result: no
configure:5205: checking for suffix of executables
configure:5212: gcc -o conftest    conftest.c  >&5
configure:5215: $? = 0
configure:5239: result:
configure:5245: checking for suffix of object files
configure:5271: gcc -c   conftest.c >&5
configure:5274: $? = 0
configure:5297: result: o
configure:5301: checking whether we are using the GNU C compiler
configure:5330: gcc -c   conftest.c >&5
configure:5336: $? = 0
configure:5353: result: yes
configure:5358: checking whether gcc accepts -g
configure:5388: gcc -c -g  conftest.c >&5
configure:5394: $? = 0
configure:5493: result: yes
configure:5510: checking for gcc option to accept ISO C89
configure:5584: gcc  -c -g -O2  conftest.c >&5
configure:5590: $? = 0
configure:5613: result: none needed
configure:5639: checking for gcc
configure:5657: found /usr/bin/gcc
configure:5669: result: /usr/bin/gcc
configure:5685: checking the GNU gcc compiler version
configure:5705: result: checked (gcc 4.3.2)
configure:5721: checking whether to enable pch feature
configure:5739: result: no
configure:5744: checking for GNU make
configure:5753: result: make
configure:5756: checking the GNU make version
configure:5766: result: make 3.81
configure:5858: checking for --hash-style=both linker support
configure:5888: gcc -o conftest -g -O2   -Wl,--hash-style=both conftest.c  >&5
configure:5894: $? = 0
configure:5911: result: found
configure:6059: checking for perl
configure:6077: found /usr/bin/perl
configure:6089: result: /usr/bin/perl
configure:6112: checking the Perl version
configure:6121: result: checked (perl 5)
configure:6130: checking for required Perl modules
configure:6133: result: all modules found
configure:6548: checking how to run the C preprocessor
configure:6588: gcc -E  conftest.c
configure:6594: $? = 0
configure:6625: gcc -E  conftest.c
conftest.c:8:28: error: ac_nonexistent.h: No such file or directory
configure:6631: $? = 1
configure: failed program was:
| /* confdefs.h.  */
| #define PACKAGE_NAME ""
| #define PACKAGE_TARNAME ""
| #define PACKAGE_VERSION ""
| #define PACKAGE_STRING ""
| #define PACKAGE_BUGREPORT ""
| /* end confdefs.h.  */
| #include <ac_nonexistent.h>
configure:6664: result: gcc -E
configure:6693: gcc -E  conftest.c
configure:6699: $? = 0
configure:6730: gcc -E  conftest.c
configure:6736: $? = 1
| /* confdefs.h.  */
configure:6774: checking for ANSI C header files
configure:6804: gcc -c -g -O2  conftest.c >&5
configure:6810: $? = 0
configure:6909: gcc -o conftest -g -O2   conftest.c  >&5
configure:6912: $? = 0
configure:6918: ./conftest
configure:6921: $? = 0
configure:6938: result: yes
configure:7009: checking for g++
configure:7025: found /usr/bin/g++
configure:7036: result: g++
configure:7067: checking for C++ compiler version
configure:7074: g++ --version >&5
g++ (Gentoo 4.3.2 p1.1) 4.3.2
configure:7077: $? = 0
configure:7084: g++ -v >&5
Thread model: posix
configure:7087: $? = 0
configure:7094: g++ -V >&5
g++: '-V' option must have argument
configure:7097: $? = 1
configure:7100: checking whether we are using the GNU C++ compiler
configure:7129: g++ -c   conftest.cpp >&5
configure:7135: $? = 0
configure:7152: result: yes
configure:7157: checking whether g++ accepts -g
configure:7187: g++ -c -g  conftest.cpp >&5
configure:7193: $? = 0
configure:7292: result: yes
configure:7320: checking how to run the C++ preprocessor
configure:7356: g++ -E  conftest.cpp
configure:7362: $? = 0
configure:7393: g++ -E  conftest.cpp
conftest.cpp:9:28: error: ac_nonexistent.h: No such file or directory
configure:7399: $? = 1
| /* confdefs.h.  */
| #define STDC_HEADERS 1
configure:7432: result: g++ -E
configure:7461: g++ -E  conftest.cpp
configure:7467: $? = 0
configure:7498: g++ -E  conftest.cpp
configure:7504: $? = 1
| /* confdefs.h.  */
configure:7550: checking how to run the C preprocessor
configure:7666: result: gcc -E
configure:7695: gcc -E  conftest.c
configure:7701: $? = 0
configure:7732: gcc -E  conftest.c
conftest.c:9:28: error: ac_nonexistent.h: No such file or directory
configure:7738: $? = 1
| /* confdefs.h.  */
configure:7792: checking for sys/types.h
configure:7813: gcc -c -g -O2  conftest.c >&5
configure:7819: $? = 0
configure:7835: result: yes
configure:7792: checking for sys/stat.h
configure:7792: checking for stdlib.h
configure:7792: checking for string.h
configure:7792: checking for memory.h
configure:7792: checking for strings.h
configure:7792: checking for inttypes.h
configure:7792: checking for stdint.h
configure:7792: checking for unistd.h
configure:7847: checking for long
configure:7877: gcc -c -g -O2  conftest.c >&5
configure:7883: $? = 0
configure:7898: result: yes
configure:7905: checking size of long
configure:8207: gcc -o conftest -g -O2   conftest.c  >&5
configure:8210: $? = 0
configure:8216: ./conftest
configure:8219: $? = 0
configure:8242: result: 8
configure:8254: checking whether byte ordering is bigendian
configure:8287: gcc -c -g -O2  conftest.c >&5
configure:8293: $? = 0
configure:8325: gcc -c -g -O2  conftest.c >&5
conftest.c: In function 'main':
conftest.c:26: error: 'not' undeclared (first use in this function)
conftest.c:26: error: (Each undeclared identifier is reported only once
conftest.c:26: error: for each function it appears in.)
conftest.c:26: error: expected ';' before 'big'
configure:8331: $? = 1
| /* confdefs.h.  */
| #define HAVE_SYS_TYPES_H 1
| #define HAVE_SYS_STAT_H 1
| #define HAVE_STDLIB_H 1
| #define HAVE_STRING_H 1
| #define HAVE_MEMORY_H 1
| #define HAVE_STRINGS_H 1
| #define HAVE_INTTYPES_H 1
| #define HAVE_STDINT_H 1
| #define HAVE_UNISTD_H 1
| #define SIZEOF_LONG 8
| #include <sys/types.h>
| #include <sys/param.h>
| int
| main ()
| #if BYTE_ORDER != BIG_ENDIAN
|  not big endian
| #endif
|   return 0;
configure:8471: result: no
configure:8500: checking for special C compiler options needed for large files
configure:8593: result: no
configure:8599: checking for _FILE_OFFSET_BITS value needed for large files
configure:8634: gcc -c -g -O2  conftest.c >&5
configure:8640: $? = 0
configure:8708: result: no
configure:8851: checking whether to disable vba feature
configure:8858: result: no
configure:8865: checking how to package the vba compatibility api
configure:8887: result: defaulting to build into installset
configure:8908: checking cups/cups.h usability
configure:8925: gcc -c -g -O2  conftest.c >&5
configure:8931: $? = 0
configure:8945: result: yes
configure:8949: checking cups/cups.h presence
configure:8964: gcc -E  conftest.c
configure:8970: $? = 0
configure:8984: result: yes
configure:9012: checking for cups/cups.h
configure:9019: result: yes
configure:9035: checking whether to enable pam support
configure:9038: result: yes
configure:9051: checking security/pam_appl.h usability
configure:9068: gcc -c -g -O2  conftest.c >&5
configure:9074: $? = 0
configure:9088: result: yes
configure:9092: checking security/pam_appl.h presence
configure:9107: gcc -E  conftest.c
configure:9113: $? = 0
configure:9127: result: yes
configure:9155: checking for security/pam_appl.h
configure:9162: result: yes
configure:9175: checking whether to link to libpam
configure:9257: result: no, dynamically open it
configure:9508: checking whether to link to libcrypt
configure:9511: result: yes
configure:9515: checking for crypt in -lcrypt
configure:9550: gcc -o conftest -g -O2   conftest.c -lcrypt   >&5
configure:9556: $? = 0
configure:9574: result: yes
configure:9726: checking for C++ compiler version
configure:9733: g++ --version >&5
configure:9736: $? = 0
configure:9743: g++ -v >&5
Thread model: posix
configure:9746: $? = 0
configure:9753: g++ -V >&5
configure:9756: $? = 1
configure:9759: checking whether we are using the GNU C++ compiler
configure:9811: result: yes
configure:9816: checking whether g++ accepts -g
configure:9951: result: yes
configure:9977: checking the GNU C++ compiler version
configure:9984: result: checked (g++ 4.3.2)
configure:10070: checking for g++ include path
configure:10088: result: /usr/lib/gcc/x86_64-pc-linux-gnu/4.3.2/include/g++-v4
configure:10181: checking exception type
configure:10218: g++ -o conftest -g -O2   conftest.cpp -lcrypt  >&5
/tmp/ccP5HUxa.o: In function `main':
/media/X/KDXClient1400-Win/Downloads/OOO300_m15/config_office/conftest.cpp:29: undefined reference to `__sjthrow'
collect2: ld returned 1 exit status
configure:10224: $? = 1
| /* confdefs.h.  */
| #define HAVE_LIBCRYPT 1
| #include <iostream>
| extern "C" void __sjthrow(void) __attribute__ ((__noreturn__));
| int
| main ()
| __sjthrow()
|   return 0;
configure:10244: result: dwarf2
configure:10371: checking what the default STL should be
configure:10390: result: gcc
configure:10397: checking for STL providing headers
configure:10410: result: using system STL
configure:10548: checking whether gcc supports -fvisibility=hidden
configure:10573: gcc -o conftest -g -O2 -fvisibility=hidden   conftest.c -lcrypt  >&5
configure:10579: $? = 0
configure:10597: result: yes
configure:10606: checking if hash_map will be in __gnu_cxx namespace
configure:10638: g++ -c -g -O2  conftest.cpp >&5
In file included from /usr/lib/gcc/x86_64-pc-linux-gnu/4.3.2/include/g++-v4/ext/hash_map:64,
                 from conftest.cpp:20:
/usr/lib/gcc/x86_64-pc-linux-gnu/4.3.2/include/g++-v4/backward/backward_warning.h:33:2: warning: #warning This file includes at least one deprecated or antiquated header which may be removed without further notice at a future date. Please use a non-deprecated interface with equivalent functionality instead. For a listing of replacement headers and interfaces, consult the file backward_warning.h. To disable this warning use -Wno-deprecated.
configure:10644: $? = 0
configure:10664: result: yes
configure:10669: checking if STL headers are visibility safe
configure:10689: result: yes
configure:10703: checking if gcc is -fvisibility-inlines-hidden safe with STL headers
configure:10728: g++ -o conftest -g -O2   -fvisibility-inlines-hidden -fpic -shared conftest.cpp -lcrypt  >&5
configure:10734: $? = 0
configure:10751: result: yes
configure:10764: checking if gcc has a visibility bug with class-level attributes (GCC bug 26905)
configure:10785: result: no
configure:10805: checking which memory allocator to use
configure:10995: result: internal
configure:11001: checking whether to add custom build version
configure:11009: result: no
configure:11014: checking whether to build with Java support
configure:11017: result: yes
configure:11053: checking for java
configure:11071: found /usr/bin/java
configure:11083: result: /usr/bin/java
configure:11112: checking the installed JDK
configure:11203: result: checked (JDK 1.6.0_11)
configure:11236: checking for javac
configure:11254: found /usr/bin/javac
configure:11266: result: /usr/bin/javac
configure:11322: checking for javadoc
configure:11340: found /usr/bin/javadoc
configure:11352: result: /usr/bin/javadoc
configure:11524: WARNING: JAVA_HOME was not explicitly informed with --with-jdk-home. the configure script
configure:11526: WARNING: attempted to find JAVA_HOME automatically, but apparently it failed
configure:11528: WARNING: in case JAVA_HOME is incorrectly set, some projects with not be built correctly
configure:11542: checking for jawt lib name
configure:12039: result: -ljawt
configure:12045: checking whether to enable gcj aot compilation
configure:12110: result: no
configure:12127: checking for dmake
configure:12158: result: no
configure:12207: checking whether to enable EPM for packing
configure:12210: result: yes
configure:12218: checking for epm
configure:12249: result: no
configure:12310: checking which package format to use
configure:12401: result: rpm
configure:12404: checking for rpm
configure:12425: result: /usr/bin/rpmbuild
configure:12592: checking for gperf
configure:12610: found /usr/bin/gperf
configure:12622: result: /usr/bin/gperf
configure:12635: checking gperf version
configure:12638: result: OK
configure:12646: checking whether to build the ODK
configure:12649: result: yes
configure:12652: checking for external/unowinreg/unowinreg.dll
configure:12668: WARNING: not found, will be cross-built using mingw32
configure:12678: error: for rebuilding unowinreg.dll you need the mingw32 C++ compiler.
## Cache variables. ##
ac_cv_build=x86_64-unknown-linux-gnu
ac_cv_c_bigendian=no
ac_cv_c_compiler_gnu=yes
ac_cv_cxx_compiler_gnu=yes
ac_cv_cxx_have_ext_hash_map=yes
ac_cv_env_CCC_set=
ac_cv_env_CCC_value=
ac_cv_env_CC_set=
ac_cv_env_CC_value=
ac_cv_env_CFLAGS_set=
ac_cv_env_CFLAGS_value=
ac_cv_env_CPPFLAGS_set=
ac_cv_env_CPPFLAGS_value=
ac_cv_env_CPP_set=
ac_cv_env_CPP_value=
ac_cv_env_CXXCPP_set=
ac_cv_env_CXXCPP_value=
ac_cv_env_CXXFLAGS_set=
ac_cv_env_CXXFLAGS_value=
ac_cv_env_CXX_set=
ac_cv_env_CXX_value=
ac_cv_env_LDFLAGS_set=
ac_cv_env_LDFLAGS_value=
ac_cv_env_LIBS_set=
ac_cv_env_LIBS_value=
ac_cv_env_XMKMF_set=
ac_cv_env_XMKMF_value=
ac_cv_env_build_alias_set=
ac_cv_env_build_alias_value=
ac_cv_env_host_alias_set=
ac_cv_env_host_alias_value=
ac_cv_env_target_alias_set=
ac_cv_env_target_alias_value=
ac_cv_header_cups_cups_h=yes
ac_cv_header_inttypes_h=yes
ac_cv_header_memory_h=yes
ac_cv_header_security_pam_appl_h=yes
ac_cv_header_stdc=yes
ac_cv_header_stdint_h=yes
ac_cv_header_stdlib_h=yes
ac_cv_header_string_h=yes
ac_cv_header_strings_h=yes
ac_cv_header_sys_stat_h=yes
ac_cv_header_sys_types_h=yes
ac_cv_header_unistd_h=yes
ac_cv_host=x86_64-unknown-linux-gnu
ac_cv_lib_crypt_crypt=yes
ac_cv_objext=o
ac_cv_path_AWK=/bin/gawk
ac_cv_path_COMPATH=/usr/bin/gcc
ac_cv_path_DMAKE=no
ac_cv_path_EGREP='/bin/grep -E'
ac_cv_path_EPM=no
ac_cv_path_GPERF=/usr/bin/gperf
ac_cv_path_GREP=/bin/grep
ac_cv_path_JAVACOMPILER=/usr/bin/javac
ac_cv_path_JAVADOC=/usr/bin/javadoc
ac_cv_path_JAVAINTERPRETER=/usr/bin/java
ac_cv_path_PERL=/usr/bin/perl
ac_cv_path_SED=/bin/sed
ac_cv_path_SHELLPATH=/bin/tcsh
ac_cv_prog_AWK=gawk
ac_cv_prog_CPP='gcc -E'
ac_cv_prog_CXXCPP='g++ -E'
ac_cv_prog_ac_ct_CC=gcc
ac_cv_prog_ac_ct_CXX=g++
ac_cv_prog_cc_c89=
ac_cv_prog_cc_g=yes
ac_cv_prog_cxx_g=yes
ac_cv_sizeof_long=8
ac_cv_sys_file_offset_bits=no
ac_cv_sys_largefile_CC=no
ac_cv_target=x86_64-unknown-linux-gnu
ac_cv_type_long=yes
## Output variables. ##
ABOUT_BITMAPS=''
AGG_CFLAGS=''
AGG_LIBS=''
AGG_VERSION=''
ALLOC=''
ANT=''
ANT_HOME=''
ANT_LIB=''
ASM_HOME=''
AWK='/bin/gawk'
AWTLIB='-ljawt'
BISON=''
BSH_JAR=''
BUILD_DMAKE='YES'
BUILD_EPM='YES'
BUILD_MOZAB=''
BUILD_TYPE='OOo DICTIONARIES EPM'
BUILD_UNOWINREG='YES'
BUILD_VER_STRING=''
BZIP2=''
CAIRO_CFLAGS=''
CAIRO_LIBS=''
CC='gcc'
CFLAGS='-g -O2'
COMEX=''
COMMONS_CODEC_JAR=''
COMMONS_HTTPCLIENT_JAR=''
COMMONS_LANG_JAR=''
COMMONS_LOGGING_JAR=''
COMPATH='/usr/bin'
CPP='gcc -E'
CPPFLAGS=''
CRYPT_LINK='YES'
CSC_PATH=''
CURLCONFIG=''
CURL_CFLAGS=''
CURL_LIBS=''
CXX='g++'
CXXCPP='g++ -E'
CXXFLAGS='-g -O2'
CYGWIN_PATH=''
DBUS_CFLAGS=''
DBUS_LIBS=''
DB_INCLUDES=''
DB_JAR=''
DB_VERSION=''
DEFS=''
DICT_SYSTEM_DIR=''
DIRECTXSDK_HOME=''
DIRECTXSDK_LIB=''
DISABLE_ACTIVEX=''
DISABLE_ATL=''
DISABLE_NEON=''
DISABLE_STRIP=''
DISABLE_XAW=''
DMAKE='no'
DPKG=''
ECHO_C=''
ECHO_N='-n'
ECHO_T=''
ENABLE_AGG=''
ENABLE_CAIRO=''
ENABLE_CRASHDUMP=''
ENABLE_CUPS='TRUE'
ENABLE_DBUS=''
ENABLE_DEBUG='FALSE'
ENABLE_DIRECTX=''
ENABLE_EVOAB2=''
ENABLE_FONTCONFIG='TRUE'
ENABLE_GIO=''
ENABLE_GNOMEVFS=''
ENABLE_GTK=''
ENABLE_KAB=''
ENABLE_KDE=''
ENABLE_LAYOUT=''
ENABLE_LOCKDOWN=''
ENABLE_MEDIAWIKI=''
ENABLE_MINIMIZER=''
ENABLE_OPENGL=''
ENABLE_PCH=''
ENABLE_PDFIMPORT=''
ENABLE_PRESENTER_SCREEN=''
ENABLE_RANDR=''
ENABLE_REPORTBUILDER=''
ENABLE_RPATH='yes'
ENABLE_STATIC_GTK=''
ENABLE_SYMBOLS=''
ENABLE_SYSTRAY_GTK=''
ENABLE_VBA='YES'
ENABLE_WERROR='FALSE'
EPM='no'
EXCEPTIONS='dwarf2'
EXEEXT=''
FLEX=''
FLUTE_JAR=''
FRAME_HOME=''
FREETYPE_CFLAGS=''
FREETYPE_LIBS=''
GCCVER='40302'
GCC_HOME='/usr'
GCONF_CFLAGS=''
GCONF_LIBS=''
GIO_CFLAGS=''
GIO_LIBS=''
GNOMEVFS_CFLAGS=''
GNOMEVFS_LIBS=''
GNUCP=''
GNUMAKE='make'
GNUPATCH=''
GOBJECT_CFLAGS=''
GOBJECT_LIBS=''
GPERF='/usr/bin/gperf'
GREP='/bin/grep'
GTK_CFLAGS=''
GTK_LIBS=''
GXX_INCLUDE_PATH='/usr/lib/gcc/x86_64-pc-linux-gnu/4.3.2/include/g++-v4'
HAVE_GCC_VISIBILITY_FEATURE='TRUE'
HAVE_LD_HASH_STYLE='TRUE'
HOME='/root'
HSQLDB_JAR=''
HUNSPELL_CFLAGS=''
HUNSPELL_LIBS=''
HYPHEN_LIB=''
HYPH_SYSTEM_DIR=''
INTRO_BITMAPS=''
JAVAAOTCOMPILER=''
JAVACISGCJ=''
JAVACOMPILER='/usr/bin/javac'
JAVADOC='/usr/bin/javadoc'
JAVAFLAGS=''
JAVAINTERPRETER='/usr/bin/java'
JAVA_HOME='run-java-tool'
JCOMMON_JAR=''
JCOMMON_SERIALIZER_JAR=''
JDK='sun'
JFREEREPORT_JAR=''
KDE_CFLAGS=''
KDE_LIBS=''
LDFLAGS=''
LFS_CFLAGS='-D_FILE_OFFSET_BITS=no'
LIBFONTS_JAR=''
LIBFORMULA_JAR=''
LIBLAYOUT_JAR=''
LIBLOADER_JAR=''
LIBOBJS=''
LIBREPOSITORY_JAR=''
LIBS='-lcrypt '
LIBWPD_CFLAGS=''
LIBWPD_LIBS=''
LIBXML_CFLAGS=''
LIBXML_JAR=''
LIBXML_LIBS=''
LIBXSLT_CFLAGS=''
LIBXSLT_LIBS=''
LOCAL_SOLENV='DEFAULT'
LOCAL_SOLVER=''
LTLIBOBJS=''
LUCENE_ANALYZERS_JAR=''
LUCENE_CORE_JAR=''
MIDL_PATH=''
MINGWCXX=''
MINGWSTRIP=''
MINGW_LIB_INCLUDE_PATH=''
ML_EXE=''
MOC=''
MOZGTK2_CFLAGS=''
MOZGTK2_LIBS=''
MOZILLAXPCOM_CFLAGS=''
MOZILLAXPCOM_LIBS=''
MOZILLA_TOOLKIT=''
MOZILLA_VERSION=''
MOZLIBREQ_CFLAGS=''
MOZLIBREQ_LIBS=''
MOZ_FLAVOUR=''
MOZ_INC=''
MOZ_LDAP_CFLAGS=''
MOZ_LIB=''
MOZ_LIB_XPCOM=''
MOZ_NSPR_CFLAGS=''
MOZ_NSPR_LIBS=''
MOZ_NSS_CFLAGS=''
MOZ_NSS_LIBS=''
MSPDB_PATH=''
NEON_CFLAGS=''
NEON_LIBS=''
NEON_VERSION=''
NEW_SHADOW_API=''
NSIS_PATH=''
NSPR_LIB=''
NSS_LIB=''
OBJEXT='o'
OOO_VENDOR=''
OPENSSL_CFLAGS=''
OPENSSL_LIBS=''
OSVERSION=''
PACKAGE_BUGREPORT=''
PACKAGE_NAME=''
PACKAGE_STRING=''
PACKAGE_TARNAME=''
PACKAGE_VERSION=''
PAM='YES'
PAM_LINK='NO'
PATCH=''
PATH_SEPARATOR=':'
PERL='/usr/bin/perl'
PKGFORMAT='rpm'
PKGMK=''
PKG_CONFIG=''
PRODUCT='full'
PROEXT='.pro'
PROFULLSWITCH='product=full'
PSDK_HOME=''
PTHREAD_CFLAGS='-DNPTL'
PTHREAD_LIBS=''
PYTHON=''
PYTHON_CFLAGS=''
PYTHON_EXEC_PREFIX=''
PYTHON_LIBS=''
PYTHON_PLATFORM=''
PYTHON_PREFIX=''
PYTHON_VERSION=''
REDLAND_CFLAGS=''
REDLAND_LIBS=''
RPM='rpmbuild'
SAC_JAR=''
SAXON_JAR=''
SCPDEFS=''
SED='/bin/sed'
SERIALIZER_JAR=''
SERVLETAPI_JAR=''
SHELL='/bin/sh'
SHELLPATH='/bin'
SIZEOF_LONG='8'
SOLAR_JAVA='TRUE'
SOURCEVERSION='OOO300'
STLPORT4='NO_STLPORT4'
STLPORT_VER='400'
SYSTEM_AGG=''
SYSTEM_APACHE_COMMONS=''
SYSTEM_BOOST=''
SYSTEM_BSH=''
SYSTEM_CAIRO=''
SYSTEM_CURL=''
SYSTEM_DB=''
SYSTEM_DICTS=''
SYSTEM_EXPAT=''
SYSTEM_GENBRK=''
SYSTEM_GENCCODE=''
SYSTEM_GENCMN=''
SYSTEM_HSQLDB=''
SYSTEM_HUNSPELL=''
SYSTEM_HYPH=''
SYSTEM_ICU=''
SYSTEM_JFREEREPORT=''
SYSTEM_JPEG=''
SYSTEM_LIBWPD=''
SYSTEM_LIBXML=''
SYSTEM_LIBXSLT=''
SYSTEM_LPSOLVE=''
SYSTEM_LUCENE=''
SYSTEM_MOZILLA=''
SYSTEM_MSPACK=''
SYSTEM_MYTHES=''
SYSTEM_NEON=''
SYSTEM_ODBC_HEADERS=''
SYSTEM_OPENSSL=''
SYSTEM_PYTHON=''
SYSTEM_REDLAND=''
SYSTEM_SANE_HEADER=''
SYSTEM_SAXON=''
SYSTEM_SERVLETAPI=''
SYSTEM_STDLIBS=''
SYSTEM_VIGRA=''
SYSTEM_XRENDER_HEADERS=''
SYSTEM_ZLIB=''
THES_SYSTEM_DIR=''
UNIXWRAPPERNAME=''
UNZIP=''
UPD='300'
USE_FT_EMBOLDEN=''
USE_MINGW=''
USE_SHELL='tcsh'
USE_SYSTEM_STL='YES'
USE_XINERAMA=''
VBA_EXTENSION='NO'
VC_STANDARD=''
VERBOSE=''
WINDOWS_VISTA_PSDK=''
WITHOUT_AFMS=''
WITHOUT_PPDS=''
WITH_BINFILTER='NO'
WITH_DICT=''
WITH_FONTOOO=''
WITH_FONTS=''
WITH_GPC=''
WITH_LANG=''
WITH_LDAP=''
WITH_MINGWIN='0'
WITH_MOZILLA=''
WITH_MYSPELL_DICTS='YES'
WITH_OPENLDAP=''
WITH_POOR_HELP_LOCALIZATIONS=''
WITH_WRITER2LATEX=''
WORDS_BIGENDIAN='no'
XAU_LIBS=''
XINC=''
XINERAMA_LINK=''
XLIB=''
XMKMF=''
XRANDR_CFLAGS=''
XRANDR_DLOPEN=''
XRANDR_LIBS=''
XRENDER_LINK=''
XSLTPROC=''
X_CFLAGS=''
X_EXTRA_LIBS=''
X_LIBS=''
X_PRE_LIBS=''
ZIP=''
ZIP_HOME=''
_cc=''
ac_ct_CC='gcc'
ac_ct_CXX='g++'
bindir='${exec_prefix}/bin'
build='x86_64-unknown-linux-gnu'
build_alias=''
build_cpu='x86_64'
build_os='linux-gnu'
build_vendor='unknown'
datadir='${datarootdir}'
datarootdir='${prefix}/share'
docdir='${datarootdir}/doc/${PACKAGE}'
dvidir='${docdir}'
exec_prefix='NONE'
host='x86_64-unknown-linux-gnu'
host_alias=''
host_cpu='x86_64'
host_os='linux-gnu'
host_vendor='unknown'
htmldir='${docdir}'
includedir='${prefix}/include'
infodir='${datarootdir}/info'
libdir='${exec_prefix}/lib'
libexecdir='${exec_prefix}/libexec'
localedir='${datarootdir}/locale'
localstatedir='${prefix}/var'
mandir='${datarootdir}/man'
oldincludedir='/usr/include'
pdfdir='${docdir}'
pkgpyexecdir=''
pkgpythondir=''
prefix='NONE'
program_transform_name='s,x,x,'
psdir='${docdir}'
pyexecdir=''
pythondir=''
sbindir='${exec_prefix}/sbin'
sharedstatedir='${prefix}/com'
sysconfdir='${prefix}/etc'
target='x86_64-unknown-linux-gnu'
target_alias=''
target_cpu='x86_64'
target_os='linux-gnu'
target_vendor='unknown'
## confdefs.h. ##
configure: exit 1
Thanks for your help :)
I don't want to install using emerge. I want to be able to install using already downloaded files, like if I need to format OS again, I can do this without having to DL all the files again.
Thanks again!
Peace.
Re: Open Office compile mingw32 error
Post by wolfden » Wed Mar 18, 2009 13:57
aZiXx
Post by aZiXx » Thu Mar 19, 2009 15:10
wolfden wrote:why not use entropy and install it?
As far as I can tell, entropy just does the same as emerge: downloads the package and installs. Maybe I don't understand the scope you are presenting this info as, but some more explanation on how this would solve my issue of not having to download files again would help.
I mentioned at the end of the original post:
So entropy, emerge, etc, they all download the files, but can I keep them in a HD somewhere, reformat, reinstall OS, and then use those same files to install the app again? Like in Windows .exe, in Fedora/Redhat/Mandriva .rpm, etc.
I want to install OpenOffice via src so that I can always install using already downloaded files. If I can do this with emerge or entropy, please let me know how.
Thank you.
Peace.
Post by joost » Thu Mar 19, 2009 16:18
http://www.sabayonlinux.org/repository/ ... e-3.0.1-r1
Press 1 of the 4 big download icons.
You can use equo to install that package at any time.
(Ofcourse be sure to get the right arch though. x86 or x86_64)
As an alternative, you use entropy to simply install openoffice and create a smartpackage afterwards.
see equo for help about that.
Post by wolfden » Thu Mar 19, 2009 23:12
Thank you.
Peace.
entropy downloads the binary file and stores it locally, plus what joost said. Emerge does the same, stores packages locally
problem with already downloaded files is, they can outdate fast
aZiXx
Post by aZiXx » Thu Mar 19, 2009 23:44
Thanks for the help guys. :)
aZiXx
Post by aZiXx » Fri Mar 20, 2009 0:20
I updated all of entropy/equo.
I downloaded the Open Office 3.0.1-r1 tbz2 package "app-office:openoffice-3.0.1-r1~0.tbz2".
I opened up Spritz manager.
File -> Install from binary package
Selected the file.
Clicked "yes" when asked if I was "supa sure".
Then Spritz came back with empty window, and has the "Update" tab selected. At the bottom left it says: "Showing: 12 items". But there is nothing "showing".
I click on the next tab "Available". Everything is grayed out, can't click on anything except text window with error text below, and "copy" or "clear" are only options. This is displayed:
  File "/usr/lib/entropy/spritz/spritz.py", line 2147, in on_installPackageItem_activate
    status, myaction = self.queue.add(pkgs)
  File "/usr/lib/entropy/spritz/misc.py", line 300, in add
    status = self.elaborateInstall(xlist,action,False,accept,always_ask)
  File "/usr/lib/entropy/spritz/misc.py", line 430, in elaborateInstall
    size += x.disksize
  File "/usr/lib/entropy/spritz/packages.py", line 380, in getDiskSize
    return None
  File "/usr/lib/entropy/libraries/entropy.py", line 34117, in retrieveOnDiskSize
    self.cursor.execute('SELECT size FROM sizes WHERE idpackage = (?)', (idpackage,))
sqlite3.ProgrammingError: Cannot operate on a closed database.
  File "/usr/lib/entropy/spritz/spritz.py", line 2215, in on_pkgFilter_toggled
    self.addPackages()
  File "/usr/lib/entropy/spritz/spritz.py", line 1396, in addPackages
    allpkgs += self.etpbase.getPackages(flt)
  File "/usr/lib/entropy/spritz/packages.py", line 101, in getPackages
    else: return self.doFiltering(self.getRawPackages(flt))
  File "/usr/lib/entropy/spritz/packages.py", line 116, in doFiltering
    return filter(self.filterCallback,pkgs)
  File "/usr/lib/entropy/spritz/filters.py", line 32, in processFilters
    if flt.process(po):
  File "/usr/lib/entropy/spritz/filters.py", line 86, in process
    value = getattr(pkg,field)
  File "/usr/lib/entropy/spritz/packages.py", line 143, in getName
    yp.action = 'r'
  File "/usr/lib/entropy/libraries/entropy.py", line 34059, in retrieveAtom
    self.cursor.execute('SELECT atom FROM baseinfo WHERE idpackage = (?)', (idpackage,))
I am then left to close Spritz as the only option.
Open up Spritz, search "open office", click on "Installed" tab, still shows 3.0.0-r1 as version installed.
Any idea what is going on here?
Thank you once more.
Peace.
Post by joost » Fri Mar 20, 2009 8:29
Looks like a bug to me.
:D
Post by wolfden » Fri Mar 20, 2009 17:46
