No password protection in Open Office Save As.. dialog
Postby xipi » Sun Mar 15, 2009 21:11
I have OO 3.0.1 on SL4r1 and had trouble saving my documents with password protection: No "Save with password" option appears in the "Save As.." dialog.
I've tried http://user.services.openoffice.org/en/ ... &sk=t&sd=a but still no success.
Any idea?
xipi
Re: No password protection in Open Office Save As.. dialog
Postby infasoft » Mon Mar 16, 2009 1:55
Strange.... Because i have Sabayon 4.0DVD and i have the "Save with password" option. The problem is most likely that you dont have a up-to date version. If not, just click on the Open Office Writer icon...Not the Open Office icon.
If you must update it, then run these commands.....
su
equo update --force
equo install openoffice
Good luck :D
infasoft
